Whinge about shit HERE.
See more
See less
The Daily tow rig, V WH Grand Cherokee
    Originally posted by bigshipengine.jpg View Post
    Have rego will travel. Took it for a decent drive and so far so good. All up purchase price plus a few repairs and 12 mths rego it owes me under 5k so im pretry stoked with that.
    I took the Gumby nudge bar off the front as well because gumby. Standard height and rake makes baby 4wd gods sad though.
    Looks much better with the nudge bar off. Won’t take much to get it it very capable and looking good.
      Yeah hopefully soon. Did a couple of little things on the weekend. Found that the air inlet to the Trubro was munted and may have been letting some unfiltered air into the compressor as the hard plastic commonly goes to shit. Fix online is to replace with silicone hose. The cracked section was at the bottom so cant see until its off.
        You’ve got me considering one of these as a tow pig
          The tow rating and power/torque are hard to beat at the price thats for sure.
          Id been looking for awhile and tge seeet spot seemed to be arounf 10k for something with around 180k on it. Saw cheaper with high ks.
          Worth reading up on common faults and fixes but the normal CRD stuff for most cars applies. Catch can and EGR delete etc. The earlier ones 05-08 iirc didnt have a DPF so thats a bonus and all CRD from 05-08 had Quadra Drive 2 standard and it then became an option. Most people want QD2 and its better for resale if you care.
          Easiest way to tell if it has QD2 is by looking at the rear diff housing. Standard open diff has 10 bolts on the rear cover and QD2 locker has 12 bolts.
            Originally posted by meggala View Post
            grab you self nrma roadside just in case but looks like a cracker rig. jeeps are worth nothing so drive it till it drops and enjoy
            Yeah u havent had NRMA for about 25 years but may be worth it with a Jeep just in case.
              Oil catch can fitted. 1 enemy of modern diesels sorted. EGR next.
                make sure you stag paste the new hose/adapter whatever at the turbo inlet. the oil dripping from there is the reason the swirl port motors let go.
                where did you get the catch can from? i require something similar for landroverness
                  Got it from Egay. There's two from this seller one with a paper filter element that requires replacing or this one for $10 more with a washable and reusable stainless element that makes more sense. Also has a built in pressure releif.
                  https://rover.ebay.com/rover/0/0/0?m...2F252402763256
                    ta, ill take a look.
                      Did that link work? Seems to take me to my purchase page now?
                        yep, sure did. thanks.
                          Went past this up the road from my place, looks ok. No idea on Km's because no one was home but :shrugs:
                            I like that colour. Worth checking it out.
                            Had mine out on the nopics families farm at Cowra today. Put it into a couple of spots getting wheels off the ground to test out the QD2 diff locks. Well fuck me its crazy how well they get it moving.
                            Lift needed badly though.
                              I remember when these came out with the QD2, Pewe called it a game changer. Iirc they were the among the first with the trick traction aids that actually worked.
                                Pretty sure other cars have had cross axle diff locks before? Or only after market at that point?
