Whinge about shit HERE.
See more
See less
Rally Rolla.
    That 2zz box is manual btw incase u havent had a look.
      Did see it.
      Got some stuff off it on the weekend.
      Might go back for a bit more if still there.
      If they scrapped it because it was running rough, then they should have looked in the throttle body. Was blocked closed by green oil paper. Looked like it had been in there for ages.
      Ignitors had gone, and probably first things to go.
        More cage photo's
          Seat test fitting.
          2 Bricks and a 5mm steel plate is about the required height.
            Looking good man.
            Good choice on the floor paint :D
              Needs one more brace joining the foot of the front bar & underneath the bottom door bar level with the Saintz bar.
                A little sideways action.
                Still a couple of bars to go in.
                Downward bar from the A pillar curve to the top of the strut, as well as a bar from the top intrusion bar to the fire wall.
                Behind the firewall where this bar meets is another bar between the front rails. Through this will run the front sway bar. and will also be used to run the rear engine mount off.
                White interior shot is Neal Bates S2000 caged car.
                  We have seats.
                  Almost back in my shed.
                    Camsmanual... Schedule J... Section 17...Drawing J 58 & J 59
                      I can't see anything wrong.
                      All measurements are correct
                        More in reference to Drawing J 58...the shadow line drawing.
                        The 70mm recomendation between the "A" pillar & the Saintz Bar.
                        [I realize photo's do lie]
                        Saintz Bar "should" be straight in side view/bent in front view.
                          Cage is finished.
                          Hopefully truck turns up tomorrow afternoon to help me get it back.
                            Originally posted by smee View Post
                            Cage is finished.
                            Truck turned up.
                            Delivered it home for me.
                            Nice that it is a long weekend and I can start on it.
                            Pictures soon.
                            Quaife responded to my email, so gearbox invoice being raised.
                              Speaking of Bates, I was there today and got a chance to drool over the 1995 ARC Havoline ST205 which he's bought back and is now restoring. Amusingly it's in a similar state to how it was when I did work experience there in '95! There was an S2000 Corolla hiding in the corner of the workshop partially stripped as well, among other tasty treats.
                                Speaking of Bates, I was there today, There was an S2000 Corolla hiding in the corner of the workshop partially stripped.
                                It's still there.
                                I might need to get some more photos of the front end setup around the radiator and engine mounts.
