Whinge about shit HERE.
See more
See less
Open Wheeler Toy
    Yes, Young David started a thread in the 'motorsport' section, and has uploaded a video to youtube, it had been linked to the thread before the outages, I'm not sure what the current position is....
    We are entered for a hillclimb this sunday, but have decided not to compete due to the woeful weather being forcast.
      Just put up a video from last weekend.
      https://www.youtube.com/watch?v=QiVkRf6pSFI
        That's awesome.
          Very rapid
            Originally posted by da9jeff View Post
            That's awesome.
            Quoted for truth
            Sent from my G8141 using Tapatalk
              Fuck me, nice drive! It's got some poke
                It's got some poke, not a whole heap.....I like to think 300 flywheel HP pushing 475 kg = 600hp/tonne
                So, If you've got that in the shed. Why the hell would you leave it in the shed when there is an opportunity to stretch it's legs? Staying at home on sunday was a stupid betrayal of myself and the car, just because it may be cold and wet, harden up princess! You built the damn thing to use, use it!
                The way the car reacts is unlike anything I've experienced, I put it down to the light "flywheel" and severely trimmed harmonic balancer, coupled to the 6 little cylinders and the reasonably light car. The flywheel is barely a mounting disc for the 184 mm clutch ( remember the starter is off car). The harmonic balancer was found to not require any pulleys so they and any extra weight was removed. The pulley that drives the drysump pump and the waterpump is tiny and is actually welded onto a socket that fits over the harmonic balancer bolt, that bolt being drilled and tapped to fit a retaining bolt for that socket. Fit for purpose.
                The engine responds rapidly and the car does as the engine bids, assuming the tyres grip.
                It is certainly an entertaining car to drive, and I trust we can cajole more speed out of it in due course
                  So, we are off to Collingrove tomorrow, again the weather is not predicted to be at all nice, but we will be there to give it a red hot go. If we get a reasonable run at it we should be able to trim a little more time off.
                  I see we have another Porsche 911 GT3 among the PF Racers. I'm afraid I just couldn't bring myself to own a rear engined car. To my mind it is so fundamentally wrong, just like having the entire drivetrain in front of the front axle like a conventional FWD car. For me it is Mid engine or front engine rear transaxle. The front engine rear transaxle is actually the most stable configuration, over on Pistonheads, Flemke,"-Is this your McLaren?", who has owned an impressive selection of supercars, and who's opinion I find worthy, has said the Mercedes SLS is a more stable package up to and beyond the limits than anything else he had driven. This from a guy who is modifying his McLaren F1.......
                  I've reworked the spring pack on the front of my car, we were hitting the ground with the front of the car. so I've added more stiffness at the end of the spring stroke, hopefully it responds as desired.
                  Speaking of Porsches I had to move the 924 today, and am looking forward to getting it onto historic registration soon so I can get a little use out of it when the inkling strikes.
                    What a day, in not the best way. Once again the weather was very disappointing, each of us got only one dry run before I noticed an issue with the car.
                    Another cold day hanging around in the misty rain waiting for a break in the weather and a dry track to emerge, no fun. Then just as it looks like it will clear up I noticed that the start shaft out the back of the gearbox can move in and out about 8 mm, there is supposed to be a nut on there holding it into the bearing, I'm guessing the nut has come loose, it was done up with a couple of Dugga Dugga's. There is however supposed to be a split pin go through it and the shaft, but because F1 that doesn't happen. So I'll have to figure a way of locking that nut on there......
                    David's one dry run was a blinder, he was very excited when he returned and scurried of to find what the time was, only to find that he had clipped a marker ! Apparently his first split was 5.6 sec, I don't recall having ever seen such a quick first split from anybody.
                    We are just hanging out for a clear dry day to try to get some good runs in.
                      Weather is on the turn now mate, you'll get a few good days soon. I can't wait to see some more video of this ting in favourable conditions.
                        Today the weather was absolutely stunning. Making yesterday seem even more galling....
                          Sorry if you’ve answered this before but what diameter tubing did you use for the frame?
                            32 (1 1/4") ERW for the 4 main tubes and 25 (1") for the cross braces...It was a loose copy of the old car, which was a loose copy of an early BT Brabham, and all the BT tube frames were very similar, just evolution of the previous design....
