Whinge about shit HERE.
See more
See less
MA61 Supra - 2JZ-GTE
    From the cross correlation on that site it doesnt look like E30s used the same eccentric washer. That could be for a number of reasons, but doesnt look good for the size of the weld on backing plates
    For a couple of bucks, buy both?
      Nah. The question was whether the brackets for an E30 camber kit would be usable with the longer E39 bolts. Years ago I made my own anyway, so itís a moot point for me.
        Great to see the amount of effort going in to this. Did the stripping reveal anymore women's undergarments?
        Torque sells tow cars.
        Horsepower wins horse races.
          Fortunately none have appeared yet, but I have a ways to go!
          Norbie!
              Just got an update from the engine builder, apparently there was some delay with getting the keyway fixed on the crank, but they estimate it should be all done and ready for pickup by the end of next week.
              That's OK, I have plenty to keep me occupied at the moment. My goal for the week is to get the dash completely out so I can get a look at the rust from the other side. It will probably need to come out for welding etc anyway, so might as well get it done now.
              Norbie!
                Right, so the dash is mostly out, still struggling with some of the HVAC stuff though:
                Starting to get worried about getting all of this back together eventually. The wiring under there is an absolute nightmare, there's the remains of some poorly installed mobiliser, various fuckery with the stereo wiring, some of my own fuckery where I joined the Haltech harness to everything else, and the original harness was pretty fucked to begin with - why are there ten thousand 50-pin connectors under the dash?? Ah well that's a problem for future me. Maybe 10-20 years in the future going by current progress.
                Meanwhile I made another fun discovery. I had to pull the A pillar trims off to get the dash out, and wondered why they felt "crunchy". Well it turns out they're made out of a bare steel plate with foam padding and vinyl over the top. The bit of rust around the windscreen had allowed moisture to get in and the padding in the trims had soaked it up and probably stayed wet indefinitely, so of course the unpainted steel plate rusted away to pretty much nothing. All of this happened invisibly, there was no sign of this happening before it came off. Sigh, old cars...
                The A pillar behind it looks mostly OK, so that's a plus. Not sure what to do about it, I assume getting a replacement trim will be basically impossible. Maybe I can get one 3D printed?? Or I could just leave the A pillars undressed, save some weight. :)
                Norbie!
                  Any similar toyotas with the same design?
                    yup ra60/5 should fit
                      Yes apparently the Celica ones are all plastic which sounds like a better design. But again, finding one in reasonable condition probably won't be easy unless I want to buy a whole car. Which I don't.
                      Norbie!
                        RA60 pillars trims fit, and they are plastic. You can easily retrim them in vinyl to match the MA61 stuff.
                          Got another call from the engine shop, they don't want to balance the bottom end because the dual mass flywheel is just about had it. I was planning to go single mass anyway so decided to go looking for anything I could get my hands on rapidly. Someone from one of my Facebook groups came through for me (Ryley are you on here??) and I now have a used Extreme clutch + flywheel setup on the way. The clutch will probably need upgrading but it's a good start and was a great price. Once the shop have the flywheel they reckon it should come together quickly, everything else is ready to go after the balancing is done. Fingers crossed they don't discover anything else!
                          Norbie!
                            hello sir yes pls enjoy your clutch. I daresay with your power you'll need something with a bit more force... but at least you don't need another SMF :P
                            '84 Supra 7MGTE
                            '86 Supra 2JZGE track
                            '99 Supra GTX35 VVTi
                            '10 C63 AMG
                            PSN: RyleyMA61
                              Aha, don't know how I didn't spot your user name. Thanks again for getting that sorted so quickly, it will be a massive help. Gotta keep this project moving if I ever want to finish!
                              Do you happen to know the specs of the clutch? Does it have a power rating or whatever?
                              Norbie!
                                Oh, i didnt realise that was Ryley either!
