Whinge about shit HERE.
See more
See less
VL LS3 turbo sleeper
    Then make a fancy bracket with angles and weight reduction slots so it doesn't look like a piece of 80mm flat bar
    Weld the washer thing to the bracket
    Bolt it in
    Weld it to the cage and done. That took me the best part of today. Can't be sure if I'm not overly productive or this sort of work just takes alot longer than it looks like it should
      Good work. Yeah, roll cage looks like finicky PITA work
        It's weird seeing someone doing a fully welded cage in a nice car, I used to guys cutting the roof off to get to the top of the tubes.
          Cheers Chuck!
          Believe me I did consider peeling the roof skin off briefly while I was cursing welding the top of the main hoop, then I remembered Ive made the cage that tight to the roof I'll never get the roof lining back in ever.
            Who bent up the hoop and the rest of the stays? Or did you grab yourself a bender and knock them out yourself from templates etc..? Fucking mint fab work man! You're killing it
              I bought them from JL racecars, His front legs and hoop profile are nice and tight to the bodey, it was quicker and more cost effective for me to buy them from him than waste tube getting it wrong.
              A mate also has a bender, so i could bend what i wasn't happy with from his stuff. Rear legs, taxi bar, window bar.
              His front floor boxes are also shit and i have no idea what rail profile they are designed for, but its not a VL. Had to make them again.
                A bit more progress, works picked up so car time suffers.
                I've had multiple issues over the years with different sorts of the keyed kill switches corroding internally over time creating resistance problems. I didn't want to put a hole in a panel and my old key switch inside the fuel flap setup technically doesn't comply for racing. Best solution I could find was these push rod one switches, highest "rated" for cranking amps I could find. The push rod exits between the bumper trim and the tail light so I can remove it when I want to street it with no visible hole.
                Cars off for a full retrim next week as we can't match the leather unfortunately.
                  Nice and neat man.
                  Shame about the trim :(
                  BF XR6 Turbo - 2L Turbo TE - 75 TX Coupe - Atlas SS
                  - PSN: rotacoupe
                    It's pretty much impossible to colour match interiors due to fade/wear etc. There's also a few issues at the moment with the supply of coloured hide etc, the tannery is having trouble getting his hands on certain colours of hide and sheepskin.
                      Trim was finished last week, just had to get the seats and brackets all powder coated and back in the car. Really happy with the results.
                      I just need to put the the last of the safety bits on and it's good for tech.
                        Dr Hoon
                          Saw that with the gold coloured car on facebook and wondered if it was yours. Looks fantastic.
                            Tidy...was supposed to go back there recently but they had no room.
                              Fuck me, that looks great! Credit to you Dimi
                                That is fucking beautiful.
