What pumps are people using to feed swirl pots ie Carter, Holley ect.
Tell me the models and what they are like, noise, reliability, cost.
cheers
cheers
I use a Carter, cost about $100. It's fairly noisy even tho' its rubber mounted, but its nowhere near as bad as the Holley Blue that I had before.....
I used a Facet. Can't remember how much (but less than $100), but its fairly reliable and quiet.
Only two things are infinite, the universe and human stupidity, and I'm not so sure about the former (Albert Einstein)
I'll be using two 'universal pre-pumps' in parrallel to feed my surge tank, they are available from efi.com.au and are part number 11003... I know this because they are sitting on my desk...
Sorry but not sure, if I get the chance I'll check it and let you know. Think it was in the 60-80gph region in turms of capacity.Originally posted by uqeus
Lambs whch model carter did you use?
is facet one of those piston type pumps? if so, have heard some not-so good things. not sure if true or not. i guess the main one being spikes in the fuel pressure, which aint so important if its just filling up a surge tankOriginally posted by gtst4
Im using a Pierberg Pressure pump, about $130 from memory..from Ashdown's in Canberra
