Results 1 to 4 of 4
Thread: 1jz or 2jz into 89 soarer???
    Jul 2002
    1
    my 7m gte has had enough and ive had enough of it ! ( blown head gasket and 4mm movement in the end float) im looking at dropping in a 1jz or 2jz but am unsure as to witch one. im on a bit of a budget so i dont want to change the auto gear box(yet), and am after the engine that will just drop in with minimum fuss and work. chaser or aristo ?? so on so forth , qs i need ansewrs!!
    has anyone done it or know anthing close ! all info is appreciated!! ive been without my beast for a couple off weeks now and am having with drawals!! ahhgh
    Where coal meets the sea
    23,832
    a 1JZGTE auto soarer front cut can be had from between $1500 and $2500 depending on where you go and your luck. this will be more or less a straight swap AFAIK.
    the 2J is by far the better engine, but you will need to do a fair bit of wiring conversion and have to accept that most odds and sods from the aristo wont fit the soarer straight up (intercooler, radiator, wiring etc etc) but an aristo front cut can be found for around the $3k mark.
    these guesstimate prices are all from Zoom magazine advertisers, adelade jap being one of the more conistently cheaper ones.
    Your social better.
    あなたの母親の肛門 Shifty's Avatar
    8,802
    Auto 1J cuts are around $1500-$2000. Manual 1j cuts go for $2500-$2800 if you shop around. An auto 2j is around $4k and a manual one will be $6k-$10k.
    I vote 1j manual
    Registered User MK2_1JZ's Avatar
    NSW
    111
    Check where the sump is located on your original motor. If its a front sump use a Chaser engine and if its a rear sump use a Soarer or JZA70 Supra engine. Remember no conversion is cheap so if your are on a budget fix the old motor. I spent $7000 on my conversion and did all the work except the wiring myself. The cheapest part of the conversion is the front cut!! It adds up real fast.
    Frank
    www.1jzsupra.20m.com
