Results 1 to 17 of 17
Thread: vh45 nissan V8 spes
    Cairns
    538
    vh45 nissan V8 spes
    the vh45 nissan V8 is ment to be a good engine tho does anyone know any spes on it
    i need to know how stronge it is
    how many main bolt bottem end it is
    what is the compression ratio?
    i take it they are efi
    also i know ppl twin turbo the lexus V8 without opening the engine
    can the same be done with these vh45 i know that celica with the twin turbo lexus v8 is ment to be running stock compression and everything esle can the same be done with this vh45?
    Thanks
    93 nissan Silvia Turbo
    Title pending
    2,718
    VH45 can take some boost. I know of a supercharged one. It runs no cooler and only aquamist injection. Its a real screamer considering its still in the Infinity.There is talk of a Z box fitting these.....maybe
    http://www.nissaninfiniticlub.net/vb...?threadid=9565
    http://www.nissaninfiniticlub.net/vb...threadid=11269
    http://www.nissaninfiniticlub.net/ar...ticle_50.shtml
    http://www.nissaninfiniticlub.net/vb...threadid=11033
    The same block is used in Indi and also for the R390 + 391 Lemans car. Destroked to 3.5L and running twin turbos.
    Take a look around the web for engine specs of this.
    VH45
    Type: 4494cc EFI DOHC 32 valve V8
    Power: 208kW @ 6000rpm
    Torque: 400Nm @ 4000rpm
    Compression 10.2:1
    Gearboxes: RWD 4-Speed Auto
    Source: 96-97 Infiniti Q45
    R390 specs
    Twin Turbo V8
    Valvetrain DOHC 4 valves / cyl
    Displacement 3495 cc / 213.3 cu in
    Power 410.1 kw / 549.9 bhp @ 6800 rpm
    Torque 637.2 nm / 470.0 ft lbs @ 4400 rpm
    Bore 85.0 mm / 3.35 in
    Stroke 77.0 mm / 3.03 in
    HP / Liter 157.34 bhp per litre
    Gear Type 6-Speed Sequential
    That should keep you busy for awhile
    Cairns
    538
    so u reckon the lexus v8 is better for taking boost?
    Title pending
    2,718
    Actually I think the Nissan engine will outperform the Lexus
    But if your not going to decompress it then go with the Lexus. If you want horsepower go with the Nissan
    Did you read about the big HP drag motor ?
    Cairns
    538
    well they are both 10:1 compression
    tho can the lexus one handle boost better?
    Title pending
    2,718
    Drop the comp and use the Nissan
    I believe its a stronger engine
    Cairns
    538
    how much would it cost to drop the comp?
    cause we didn't want to spend to much money on internals mainly on tuning
    we are using a sm2 autronic tuned by ray hall
    we only wanted to run 6 - 10 psi thought twin vg30det non ball bearing T03's
    with a 800x250x70 intercooler
    do u have to change the compression? or can u still turbo it with 10:1 and just run low boost n good fuel
    Melb
    7,368
    I don't have a barrow to push with either engine, but the 1uzfe has a lot of nice internals (forged pistons, nice rods and very nice crank) how does the nissan stack up.
    I would be cautious with the indy engine/nissan engine comparo too, I doubt if any parts would interchange, same for the LM engine.
    What are the physical dimensions for the nissan engine?
    Cairns
    538
    i might stick with the lexus V8 cause i know it is a tuff engine and stuff
    and it is alot smaller then the vh45 and i need room to mount the turbo's
    so i think i am going to go with the lexus
    Registered User Bart's Avatar
    180
    Hey guys im trying to identify the year of maufacture of a VH45, i need a 1989-91 model VH45, the only thing i know of this particular engine is its out of a G50, i guess the question is what year did the G50 come out??
    Noodly appendage jizmstr0's Avatar
    sunny coast
    1,534
    have you taken a look at a vh41. As far as I can tell, it is very similar to the 1uz. makes about 190kw in stock form and i know a dude who is about to twin turbo one
    state street drift champion 2003
    Formerly known as bassaholic55
    180
    let us know how it goes when he gets it all running.
    Apr 2004
    Wellington
    1
    I do know the VH45 is bigger thanthe VH41.. deck height is different.
    The VH45 has 6 bolt mains.. not sure on the 41.
    FCKGW-RHQQ2-YXRKT TonyJZX's Avatar
    20,785
    http://board.performanceforums.com/f...eadid=67171437
    Please check out this thread.
    "Plastic tension/guide bodies....good one . Problem can be fixed with the later model tensioners, but not cheap and the parts are hard to get in Oz. Given that the early motors are (apparently) the ones to get from a performance POV and most likely are the ones available to us in Oz, it seems it could turn out to be an expensive conversion in more ways than one. There's also no way to find out from an external inspection if your engine has the problem."
    This is a very big unknown on the earlier units.
    Do you have to pull down the motor to fix this?
    T.
    Quote Originally Posted by boxxx
    2ofdem
    Guest
    I have seen the bottom end of both of these engines and they are most impressive there is a vh45 being built atm here in brisbane which is going into a 180sx. Pics when i visit him next.
    180
    find out what year the engine is if you can
    sick vn is sick Tirlista's Avatar
    Darwin
    854
    As much as I'd like to get a cefiro and put a sr20 in it, the idea of a vh45 (over vh41!!!) sitting between the struts is pure wet dream material!
    I'm taking it that this is possible, since you have other people chucking the '45 in 180s and r31s..?
    A vh45 only costs ~$2200 for a front cut doesn't it?
