Results 1 to 18 of 18
Thread: Starting in drive (VS Ute)
    8
    Today my girlfriends VS ute started while in drive...i know this isn't meant to happen, so why would it have happened? what is meant to stop it?
    Thanks
    JZA80, Turbolax. Stenno's Avatar
    290
    Technical section is your friend
    96' JZA80, Stock.
    8
    sorry mate, new to the forums...thanks for moving it
    Classic Not Plastic steevo's Avatar
    488
    Id hazard a guess and say the neutral park switch has had the royal order.
    Steve
    "I drink to make other people interesting."
    Registered User 08RUT's Avatar
    CLOWNSville Qld
    1,750
    someone has BYPASSED the neutral switch maybe? when they die, the car wont start so people bypass it, then it will start in ANY gear
    8
    where is this switch?
    Where coal meets the sea
    23,794
    dunno on commos. some cars it's on the shifter, and others it's on the side of the gearbox.
    Your social better.
    8
    so could the fact that the handle on the shifter is a bit loose have anything to do with it?
    23,794
    nahh, the inhibitor switch will be inside the console at the base of the mechanism. I have a hunch that it's on the side of the gearbox on the commodore though.
    Your social better.
    8
    thanks for your help man.
    sydney NSW
    70
    The inhibitor switch is under the gearstick.
    Take it to an auto trans specialist and tell them what is wrong,they should be able to fix it without any problems.
    hope this helps.
    vr4gsr.
    Chris Rogers
    Guest
    not a commy. there are two points. one under the shifter and a relay outside in the relay ,fuse panel.
    bypassing the relay will do it. ( should be labelled 'inhibit' or 'start')
    10,173
    My dads XF was having troubles starting. It wouldn't start in about 1 out of 4 goes. So when dad said the prob was occuring I done a few tests with my multimeter. Anyway I done the good old screwdriver across the starter motor terminal trick to start it up. But the reason the car would not start this time was becuase my dad had it in drive!!! Anyway the screwdriver trick bypasses the ignition off switch for drive so the car started up and moved forward 30cm to come to rest on my foot. Shit it hurts having a 1600kg XF parked on your foot.
    10.83 @ 125
    8
    Here is the killer, she started it from outside vehicle...had blown a fuse and were checking lights, the ute started no worries and went through a fence...life is treating us great at moment!
    Chris Rogers
    Guest
    its possesed - run....
    8
    mmm, possessed, that is an option. although all it managed was to hurt itself, and scare the shit out of my girlfriend. is going to mechanic today to get fixed.
    Grumpy Pedant MiG's Avatar
    Bentleigh, Melbourne
    564
    Don't you use the handbrake?
    Arguing with an engineer is a lot like wrestling in the mud with a pig. After a few hours, you realise that he likes it
    PF needs YOU! Help fight the war on rice! - click here to find out how!
    8
    handbrake was on, girlfriend musn't have had it on tight enough
