Hi guys,
I am currently re-building my FJ20T which has after market Cams and modified cam wheels to allow for cam timing adjustment. Problem is I have never done this before, and need to learn how to set it up correctly.
Can anyone point me to a site on-line which has a good explanation of how to set up the cam timing? I know I will need a dial indicator and degree wheel, but how exactly do I use these?
Basically, My cam wheels have had the original locating holes drilled out, and an eccentric bush machined up for the holes, by moving the position of the bush, it adjusts the cam timing....... I should have taken some bloody photo's! I was just too keen to get it apart to determine the cause of our other problem - lack of compression!
Any help is appreciated.
Mark
