Results 1 to 30 of 35
Thread: HZ 1Ton Cab Chassis (TT1uzfe)
    Registered User Amalgamator's Avatar
    Australia NSW Central Coast
    57
    My Baby
    Specs are.
    1uzfe Twin turbo using Nissan Skyline R34 GTT Turbos with 3inch mandrel bent dumps and separate waste gate pipes
    Custom (by me) steam pipe turbo headers
    Supra 7mgte 440cc injectors
    Modified fuel rail (dual inlet, dual outlet)
    SX fuel pressure regulator
    SX Hi Flow filter
    Bosh motor sport 044 EFI fuel pump with Holley Blue lift pump
    Motorsport surge tank.
    Ported heads with reshaped combustion chambers, heads have been cc’d and blue printed on re-assembly
    3 angle valve grind
    2mm Copper head gaskets
    8.9:1 Cr
    Port matched intake manifold
    Ported, modified, relocated Throttle Body
    Direct fire waste spark multi coil CDI Ignition System.
    Honda CBR600 f4i CDI coil on plugs.
    M&W Pro14 CDI box.
    Wolf 3D version 4 engine management
    Distributers deleted.
    600x300x75 tube and fin front mount cooler.
    Trust type R plumb back Anti Fknwoosh bov.
    Ducted Trust Grex oil cooler with billet remote filter.
    Mocal oil thermostat.
    Everything Speedflow.
    CRS engine mounts, sump, bell-housing, flywheel.
    Jim Berry modified GT4 pressure plate, with 3500lb clamp, 5 puck carbonic sprung hub disk.
    Rack and pinion steering conversion using a modified UC Torana manual rack.
    Custom steering arms.
    CRS 50mm drop stubs with commodore caliper mounts and VT Billet hubs.
    Rebuilt, strengthened and blue printed R154 with an aftermarket intermediate bearing carrier and new cryo treated 1st gear thrust washer, all new bearings and sincro's.
    Front brakes, 330mm X 32mm slotted DBA 40000 series front rotors with Porsche 996 GT3 Brembo monoblock 4 differential piston callipers, on billet steel hubs with custom 6061 T6 caliper adapters.
    Rear, 330 X 28mm slotted DBA 40000 series rotors with Porsche 996 GT3 Brembo monoblock 4 differerential piston callipers, custom calliper adapters.
    Wilwood adjustable brake bias valve.
    About to start the on the rear end. (help needed)
    Poly bushed adjustable four link rear with birdcages and coil over shocks, fitted with a 31 spline Nine inch diff 3.9:1 lsd disc brake with Ford SVO Nodular Iron carrier, billet hat, Mark Williams 31 spline billet axles, daytona pinion support etc,etc.
    And all sorts of other bits and pieces
    Refined Crude lover Jay_G's Avatar
    Donning the Floaties In Ipswich
    2,235
    Nice list of stuff there,
    have you had a chance to get it on a dyno yet? power figures?
    2ofdem
    Guest
    Some coin been spent there looks good mate.
    57
    Thanks guys.
    Gee you blokes are quick, just started uploading pics at this ungodly hour and already replies.
    Cheers,
    Trev.
    57
    No nothin yet, just embarking on the rear end at the moment.
    (ponders and looks, what the fuck am I going to do here)
    Hasn't really cost that much (shhhhhh the wifes near by) just a lot of time really.
    I've done it all myself, and I mean "All", as I couldn't afford to have people work on it (well sort of)and quite frankly I enjoy making stuff.
    Builder by Trade and car nut for life.
    23,353
    One word - Sensational.
    Well done mate, the workmanship is fantastic.
    When you've finished with the setup i'll slot into my lexus, stock 1uzfe's are less than exciting in the cars they come in
    Super Moderator TJ's Avatar
    17,815
    Quote Originally Posted by psi999
    Quoted because theres nothing that I can say that will surpass those simple yet correct words.
    Quote Originally Posted by Uncle View Post
    Did you baguette up as you left the house?
    Loose cannon Captain Fuckhead's Avatar
    653
    fwor, i can't wait to see
    a> dyno figures
    b> pics of skids
    Never Back off.... Ever
    Carbon blob sector 7g Zac's Avatar
    London
    10,175
    very cool
    formerly shinybluesteel Roadsailing's Avatar
    2,948
    very nice work on the exhaust manifolding
    3,279
    Awesome - can't wait to see the finished product.
    Quote Originally Posted by GTS308 View Post
    Just make sure your spelling and grammer is 100% accurate.
    4,645
    Quote Originally Posted by Amalgamator
    Yeah right
    Looks nice man. Crossmember mods are mint. Mine won't be a patch on that!
    Did you have to slice the front crossmember to get the engine forward far enough, or was it for height? I am putting a 1jz into a HJ ute, and it gets tight around the sump, but fits no worries. Didn't have to cut the sump or the crossmember.
    The gearbox crossmember looks exactly like what I will need to do with mine- you didn't make a spare did you
    Sunshine Coast, Qld.
    5,728
    Fantastic work on this car, very very impressive. I was going to ask if you were a boilermaker or machinist, but you're a builder, fark. Let someone else build the houses, we need you modding cars.
    Muz, gearbox x member modding was teh suck for the toyota auto. While it is very compact, the shape of it is so different from any GM stuff that the x member required an absolute raping. 30 year old tonner x members aren't usually real straight to begin with either.
    4,645
    Are you gonna need another support for the LONG input shaft into the rack?
    I know about the trans x member Al, I've got one that needs doing, but I don't need to molest it as much as this one for the 1j and auto.
    4,645
    I won't be able to space my trans mount ANYTHING like that far up. Mine will sit about the same height as the factory mount to be honest. Maybe the 1 tonner floor is a bit roomier, or maybe you get the engine further forward than I can..
    5,728
    It might be an auto manual thing Muz. I had to section and drop the centre of the x member at least 100mm to mount the auto. That was using a holden box mount with adaptor no the toyota mount.
    4,645
    What car was that for mate? 1uz or 1jz?
    5,728
    The 1UZ tonner I did for my mate.
    http://www.performanceforums.com/for...ght=1uz+tonner
    Classy 'n' Shit. Bob Saget's Avatar
    Eagle Street
    1,441
    Quote Originally Posted by Bender
    Yeah, well I'm gonna build my own lunar space lander!
    With blackjack aaaaannd Hookers! Actually, forget the space lander, and the blackjack.
    Quote Originally Posted by JamesB View Post
    What do you get if you cross a negro with a chinese?
    ... A car thief that can't drive.
    Apr 2003
    Roleystone
    2,196
    Good to see.We have one almost finished now in a one tonner but with Powerglide and monster single Turbo.Will post pics soon if it ends up as nice as your car.
    15,611
    Absolutely awesome work!!!!
    57
    Cheers guys.
    Muzz, The only mods to the front crossmember are where the steering shaft comes through. Custom sump alleviated the clearence issues, but still bloody tight down there.
    Engine sits as low and as far back as possible without mods to the fire wall.
    CRS did a pretty good job of the mounts in that regard.
    The adapter just bolts to the block holes and use HT-HG V8 mounts which are a bolt on affair with the HQ Chassis.
    The long steering shaft seems okay, doesn't move with a full lock to lock turn with full weight and no forward or rearward motion of the vehicle but I know where you are coming from Muzz and it is something I will keep an eye on.
    I dumpied the chassis and made up a jig which I used to map the front end geometry using a series of cheap chinese laser pointers mounted on the front hubs. This gave me good base lines from which to work from when setting up the rack and the ability to track changes in geometry from the hub mods etc.
    Bought the wife a new digital camera for Chrissy so I'll try to get my finger out and post up a few more up to date pics.
    Cheers
    Trev
    Eurotrash arcane's Avatar
    Mexico?
    1,306
    Great fabrication work! Looks great - definately sounds like you've done things properly.
    Quick question for you: What external oil thermostat did you end up using?
    57
    Quote Originally Posted by arcane
    Mocal
    57
    Few more pics showing how I did the cooler.
    I completely sealed the front area where it sits in with aluminium sheet to increase efficiency as I have lost a bit of airflow to the radiator.
    15,611
    OK I now have a new favourite in the Rides section!
    9,962
    Turbos are used to 2.5ltr coming 6 way, going down to 2lt coming 4 way, I'm wondering how much lag/low tractability you'll have?
    But certainly a shmick car. More pics please.
    57
    Thanks Allmtr
    Datzed, Not a laggy combo at all, If anything the turbos are a tad on the small size, better manifolding, exhaust outlets, seperate wastegate pipes, etc and head porting will sort out the 500cc short fall per bank from OEM application.
    Okay, more pics, no worries.
    And before anyone says anything, Yes that is a structural grade of pine.
    Below is a shot of the rear vented cover for the oil cooler, which is mounted in the lower front of the PS guard and fed air from the large bumper bar bracket hole.
    It is once again a sealed box, only way out for air is through the core.
    The cover you can see in the pics sits 25mm off the core and has downward facing vents pressed into it.
    It is also completely open at the bottom.
    All to try and stop shit flicking off the tyre from blocking the cooler core, without restricting airflow.
    Cheers
    57
    Shot of the interior.
    Keeping it pretty basic as its going to be a daily driver.
    Below is a pic of an aluminium panel that I made up to hold all of the extra circuits, fuses and relays to run everything.
    It reduces the glovebox depth by about 70mm and is removed with 4 philips head screws.
    It has its own loom and connecters and can be quickly and easily completely removed to add in other circuits etc.
    4,645
    Looks great, dunno if you needed to worry about the ducting under the intercooler- they flow enough air under the front bar I reckon. Is that an ebay intercooler?
    The louvred panel in front of the wheel looks way too good- you're making the rest of us look bad man
    Why did you need to space the wheels out like that?
