Page 4 of 12 FirstFirst 12345678 ... LastLast
Results 91 to 120 of 358
Thread: My current racer
  1. #91
    later
    May 2003
    Queanbeyan, Australia
    4,618
    $1200 isn't bad.
  2. #92
    blinks ... Billzilla's Avatar
    Jan 1970
    21,396
    Okay a bit of an update.
    The gearbox is all fixed up and ready to go back together again.
    Rz (Pete) has done some absolutely stunningly good work on it and it's a shame to hide it away so I'll post some photos of it here, before it's all tucked away.
    This is the extension housing, the good welding is by Pete the shit welding is by us. Yes the oil seal isn't in place properly yet.
    Inside the extension housing are a pair of small roller bearings and they run on the tailshaft yoke to locate it. We've had problem with the brass bush getting a hard time so this should fix it. To make sure it's going to get plenty of oil, Pete welded on a couple of small paddles onto the 1st/rev gear synchro ring thingy, and they splash a lot of oil around into the rear of the box.
    The paddles throw the oil around the back of the extension housing and up against the milled plate that Pete welded in the back. The oil runs down that, into a long slot, then into the two roller bearings. There's two oil drains from the bearing tunnel to make sure no pressure builds up and the oil gets changed frequently.
    And just for laffs, here's a stock extension housing, to show you how much different the race box one is. Much shorter eh? And the gearstick is much further forwards.
    ... and the bad news is that with the new job I can't afford to do anything much other than put fuel into the car to go to work. So no more building cars for at least a year or two.
    Contact me for -
    3D printing in ABS plastic.
    http://www.billzilla.org
  3. #93
    Jul 2002
    26
    re differences
    Bill
    could you let me know the following when you get a chance
    1. front mount rack - why the move
    2. the different rack - does it have more travel than a trumpy?, and if so whats is that and whats its from? (mm per turn of pinion)
    3. its not leyland marina!
    4. can you explain "how the move" changes the accerman with travle plse
    thanks and regards
    simon
  4. #94
    Where coal meets the sea
    23,800
    what was involved in shortening the output shaft?
    Your social better.
  5. #95
    Jan 1970
    21,396
    Quote Originally Posted by simon010 View Post
    Bill
    thanks and regards
    simon
    I moved the rack for a few reasons -
    - To make the front of the chassis a bit stiffer.
    - To reduce the angle of the steering links to make them straighter, again to make the whole thing stiffer.
    - I'm not sure about the akerman change, but at least now it'll be more predictable, if only for the above reasons.
    - It's a Triumph Herald rack, just a stock one so whatever they have as a ratio stock is what I have.
    For the old shaft we cut out a ~15cm section towards the rear of the main shaft and welded them together. The first weld was done in the early 90's and it lasted quite a while .... then we got more power from the engine and it broke. So we welded up another one and that broke as well.
    So the final (I hope) fix is that brand-new single-pice one a few posts back. It's larger diameter than than welded ones and of course no weld so hopefully it'll be strong enough this time.
    Contact me for -
  6. #96
    23,800
    I have to say looking at the shaft $1200 for a brand new custom one is awesome cheap!
    Your social better.
  7. #97
    Jan 1970
    21,396
    Yeah I was pretty darn happy about it!
    The engine is nearly back together and the gearbox is also on the way.
    The engine will be off to the dyno soon to get the damn Mikuni's right before it hits the track again.
    Contact me for -
  8. #98
    Jan 1970
    21,396
    Halfway through sorting the engine on the dyno today.
    With the mixtures still all over the place it's making good power but it'll need a lot better before it's really driveable. But very briefly the mixtures were right at about 6,000rpm and according to the dyno guy (who's done a lot of Suzuki engines) it's about 10% better than the previous best engine he's done. Yet to be confirmed with his dyno calibraions, but once it's sorted it will be a very strong engine.
    Contact me for -
  9. #99
    Moderator Cal's Avatar
    Brisbane, Queensland
    16,270
    Quote Originally Posted by Billzilla View Post
    Weren't you meant to be there the previous weekend after I was there?
    1995 Mazda MX5 - 2F Race Car
    1991 Mercedes 300TE
    1990 Mercedes 230E
    1990 BMW E30 318is
    1977 Jaguar XJS V12
    1971 Morris Mini 1100K
    1957 Porsche 356A Speedster Replica
  10. #100
    Jan 1970
    21,396
    Un yeah, but we ran into a few little hiccups. Engine should be off the dyno in a day or two.
    Contact me for -
  11. #101
    Jan 1970
    21,396
    *pouts*
    Was hoping to crack 160hp at the flywheel but didn't make it. Bettered 150hp though and still the best he's seen.
    The engine is back home now, and the gearbox is going back together. Hopefully in a couple of weeks it'll get a test run on the track.
    Contact me for -
  12. #102
    Townsville Australia
    3,322
    Just chuck the dissy a few degrees forward
  13. #103
    Jan 1970
    21,396
    Cracked the shits finally and started the big clean-up in the garage. I did a bit a few days ago, and a lot more this morning.
    I shifted a lot of the gear around so there's effectively more space and the car bays are much better organised.
    Still a huge amount of cleaning up to do, after many years of neglect, and I have to make plenty of shelves on the walls to put various crap.
    But it's a start at least.
    Contact me for -
  14. #104
    I love cable ties. Steve's Avatar
    10,144
    Use the hoist much?
    Auto Electrical Accessory fitting in Brisbane!
    http://securityandaudio.hopout.com.au
  15. #105
    Jan 1970
    21,396
    Before it got covered in crap, yes.
    It'll be in service again in a couple of months.
    Contact me for -
  16. #106
    Jan 1970
    21,396
    Almost all back together now, should be a runner in a day or so.
    I'll try to make the sprints at Willowbank on the weekend.
    Contact me for -
  17. #107
    Refined Crude lover Jay_G's Avatar
    Donning the Floaties In Ipswich
    2,238
    How did you go with getting the glasswork done on it?
    yep
  18. #108
    Jan 1970
    21,396
    Yeah all sorted. Got the guy to finally come around. Just sanding the rear guards now to get them ready for painting.
    Contact me for -
  19. #109
    Registered User Rz's Avatar
    4,668
    jesus christ , it almost looks tidy.
  20. #110
    Jan 1970
    21,396
    Come and help me get it ready Friday night ya stinky poof.
    Contact me for -
  21. #111
    Registered Paedophile Dark Orange's Avatar
    Jun 2007
    Yeppoon
    1,697
    Photoshop.
  22. #112
    4,668
    nah.
    stuff i touch normally blows the fuck up.
  23. #113
    Jan 1970
    21,396
    It's okay, it doesn't have power steering ....
    Contact me for -
  24. #114
    Jan 1970
    21,396
    But seriously ..... All going well I'd like to corner-weight it Friday night and that takes a couple of people. I might have another mate coming around but if he can't make it I put it to a vote and the result was that you have to come and help.
    Oh, and you just happen to have my scales .... !
    Contact me for -
  25. #115
    4,668
    yeh ok ill bring the scales up , and your complimentry punch in the head for the power steering gag.
  26. #116
    Jan 1970
    21,396
    Don't hit me in the head or I'll get my Dad to talk to you.
    Back in my day they weren't called turkeys they were called Walking Birds ....
    Contact me for -
  27. #117
    Hurry The Fuck Up bigmuz's Avatar
    4,688
    Nice job on the cable ties holding the oil tank in place..
    Look at the yellow paint coming off already. Please let me know next time it needs paint man.
  28. #118
    DON'T PANIC Gammaboy's Avatar
    8,435
    If it was good enough for the Works Yoshimura Suzukis...
    No paint is lighter than too much paint :P
  29. #119
    78
    when will it be out and about again ... lovely car mate .
  30. #120
    Jan 1970
    21,396
    I'm hoping to give it a run Monday at QR ..... if there's private practice then.
    Otherwise Friday the 7th at Oran Park.
    Contact me for -
