The whiteline rear swaybar for the u13 is dodgy in a sense - if on the stiffer setting, with enough suspension travel the link (normally "hanging" down) and swaybar itself will straighten out and sometimes return in the opposite direction, if you get what I mean (MS paint drawings can be arranged).
So I need longer swaybar mounts to prevent this.
They're just a rod with a little ball joint, with the bolts from the ball joints in opposite directions, currently about 3" long so around 5" sounds good........is this how most cars swaybar links are normally setup? Am I likely to have much luck at a wrecker? I've heard some older cars used to have chains instead of a solid link..........that for real?
It would be nice to not have to do that though, in case I fuck up (very very likely).
