I've got a couple of pics now so here they are. Car is an 2004 factory turbo SE purchased as a write off from Japan and reborn so to speak as a racer over the past 12 months. So far, I've been lucky enough to win my first ever race at Oran a couple of weeks ago and came 3rd in class at Qld last weekend at the V8 supports. Times so far; Oran was a 1:21 and QR was a 1:22. More to come I suspect.
Brakes: Exige 295mm rotors with Wilwood 4 pots front, stock rears, DTC30 pads front, Porterfield RS4 rear, ABS & EDB enabled, Braided Lines
Engine: Stock internals, 580cc injectors, return rail, electric water pump, PWR radiator, Just Jap cooler, Serck oil cooler, mocal thermostat; 5 puck ceramic clutch
ECU: Haltech E8 with wideband and boost controller
Suspension: Tein Flex with EDFC, Super Pro offset bushes, modified lower control arms front, modified upper control arms rear, racing beat and whiteline sways and RB braces
Wheels: Black racing Pro N1 +35 16x8, 220/610/16 Dunlop Slicks
Fluids: Elf Brake fluid, Elf Oils, Redline Shockproof gearbox
