Page 1 of 3 123 LastLast
Results 1 to 30 of 73
Thread: TX gemini racecar.
    weirdo F|sh's Avatar
    Bunbury
    4,701
    TX gemini racecar.
    This is my race car build thread. My other thread should get better soon regarding the motor conversion as i almost have everything to restart it!
    (looks at 2Ofdem whereis my bellhousing?)
    Back in 2002 i was giving a racecar. I rang my friend up as it was sitting in his hsed doing nothing and had been sitting under a tree for 7 years. He said he wasn't using it anymore and i could have it. Sweet.
    So i strated on it. It was pretty rough. Had no front end and was covered in dust. had leaves through it and an alloy half cage. And rust. Most of the supports on the side were going and so were the bottom were the guards join the sills.
    This is what the car looked liked before it sat for so long.
    then this is what i got. The rust repairs have been finished and the new cage done this was done after advice was to ditch the alloy cage and go steel and stiffen the whole car up.
    http://groups.msn.com/_Secure/0SQBYD...Q/IM000423.JPG
    http://groups.msn.com/_Secure/0SQA4D...Q/IM000428.JPG
    You can see part of the cage in this photo.
    Royalpurple Oils
    Bunbury
    4,701
    SO you can kind of see how bad the car was when we got it.
    While the car was away getting the cage built and the seams stitched welded at Maitland performance Fabrications. I sent an engine away to get built to these specs. Actually turned out to be two...
    http://groups.msn.com/_Secure/0RgDMG...01220993612423
    The previous two Engine specs as best I can remember -
    1800 bored to 2ltr
    Fully balanced of course
    ASK billet flywheel - got lightened when cage was modified for clearance.
    flat top pistons with valve reliefs
    Mega super duper head work including p+p, valves, springs.
    Stage 5 crow cam
    Twin 44 downdraught webers
    Extractors leading into a 6 foot system
    Both of these motors went bang. So this and my pursuit to catch the pack has lead to teh 3sge being purchased.
    Now we also ordered many many parts. Koni sports (yellow shocks) and gemini series springs. We ended up just using the fronts becuase i fucked up and chopped the rears instead of putting them in the right way (upside down ms jane). Aeroquip 3/8th line and many many speedflow fittings.
    66
    Standard slotted rotors recond master cylinder. 14 inch rims. Harness and window netting.
    So when the car did come back about 6 weeks later we did start to assemble and prime and clean as paint. We cleaned the cage and primed it to stop it rusting and the engien bay too. Then i took the bootlid in to get the paint matched. Came back with all nissan colours........ The engine bay and cage and interior were all painted in basic white.
    Once this was done the dash was modified to fit around the cage and the top section reskinned. That was done at first class motor trimmers in Maddington. Nice bloke les and he is redoing the road car too.
    Royalpurple Oils
    Bunbury
    4,701
    The dash once installed.
    so the car is getting there. Its been around 4 months by now. IIRC. Dash is in Kill switch is in the new 3 core from melville cooling supply's in and we can roll the car around.
    Its about this time the proper koni's rocked up just for the fronts. As it was around 10 months into the build the rears came. (after dealing with one bloke saying the shocks are no longer made and that you should use these. Only to find out whiteline took a month to get another blokes in. So fuck the WA STATE distrubitor of Koni's back in 2003)
    Most of the time was spent just getting parts in and fitted like suspension bushes and brake lines.
    about two months the motor mk1 arrived and we assembled all the other bits on it. The webers, electric dizzy and flywheel. Now this motor threw a rod. could of been becuase the clutch and flywheel werent balanced with this motor? or did just fuck up and over tighten a main bearing.
    so we installed the motor too with our special cable tie bracket for holding the battery down.
    And yes it runs after that pic was taken all the wiring was cleaned up a proper battery clamp was fitted and she ran. Only didn't like being sat around for too long. No engine fan meant 250 degree's f fucking quickly!!!!!!
    After that it was just small things like glass and a wash and a polish.
    We finished it july 2003 becuase i was made redundant and i used about $2000 of my redundancy to finish the car and get it to the track to race. We qualified last and had no corner speed at all (never ever got to have pratice and we bent all the valves a weekend before). After that race we dropped a tensioner and car and i went to maitlands performance fabrication to make it quicker and better in appearance. We removed one of the rollcage bars and changed seats and added bigger brakes and alloy fuel tank. Cut and repaired more rust and lightened even further!
    i think thats enough for tonight. there are large gaps but i will fix them with photo's of the car complete at the 2003 Truck meeting at Barbagallo. This is why the trucks has an appeal to me. It was the very very first race i participated in and i always try to make it to these rounds.
    Royalpurple Oils
    Registered User Teamgemini's Avatar
    Dec 2005
    325
    Looks the goods mate, must get ours out of the garage soon, karts too expensive....
    Something about the TX coupe shape that I love.
    BTW you wouldn't know of anyone with a 1800 or 2000 block that they want to get rid of for cheap??
    Tim
    I have stuff...
    Bunbury
    4,701
    Tim,
    i would ask Dale if his mate pete has one laying around. if not jump on ozgemini.com for a gander.
    Royalpurple Oils
    Bunbury
    4,701
    When i had finally got the car all finsihed this is what she looked like
    It hadn't changed much from the first photo really.
    The car was at maitland performance fabrication for 8 months while i had no income so i traded it for work. IE you work on my car and store it and i'll do all the jobs you hate and still work on my car.
    The first thing we did was clean up the sound deadener and remove the box and fit a decent clutch to the car.
    Then we fitted the new seat and modified the rollcage and new fuel tank and new brakes.
    and then it got dyno'd
    Royalpurple Oils
    Bunbury
    4,701
    Sorry last photo wasn't much chopped.
    this is what i worked on while at steve's workshop and a host other cars ranging from a Group C escort to a MK1 for targa and falcon.
    Royalpurple Oils
    Bunbury
    4,701
    After i got the car back from Steve's workshop and out on to the circut we threw a rod badly.
    i had to repair the sump and do some mods to it so it wouldn't happen again.
    To the sump we added a 100mm bowl about 100mm high. With slots around it to allow oil to flow into it. There was also a bit of angle in the sump that was stopping oil flowing into the sump. we removed it and the engine suddenly stop starving for oil.
    You can see my dodgy welding there too. The new pick up was made becuase the old one got damaged beyound repair.
    Royalpurple Oils
    Bunbury
    4,701
    We also added this. Made by a mate of mine back in perth.
    And it gave the car a more racey feel to it. While doing this all on a budget.
    then the next motor.
    which then came with this
    i then reassembled it in one weekend becuase the V8's were shit! and boring.
    so when on the track it finally got to this.
    Royalpurple Oils
    Bunbury
    4,701
    And then motor number 2 goes bang in a bad way. Not a rod but a valve head. $1000 worth of head down the drain. I think the valve length was incorrect and was stretching. So this is when we decided the 3sge was the goer.
    Royalpurple Oils
    Bunbury
    4,701
    then i got some more cash and bought these too
    Piazza rear disc brakes for $300.
    and shaved 0.5 from my lap time with my best now being a 1:13.9
    Then this is where it stalls. I have spent so much money on it for the 3sge that i am taking a small break from it. Having spent now $7000 for parts and not having the car together is a pain. I was hoping to do it on a budget but its not happening anytime soon.
    Royalpurple Oils
    Opens Grumpy Rooster's Avatar
    WSID
    3,537
    I don't understand how you make so many Isuzu engines go bang. My mate has been flogging the absolute crap out of his for years and its still going. It made about the same power as that shown on your graph and gets driven every day about 50km to and from his workshop.
    I'm not having a go at you, just genuinely intrigued why they are going bang. It must be the circuit work rather than drag and street use???
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    8,173
    I'm intrigued too, I've only lost 1 rally engine, and that was just due to shear blow by- it couldn't keep oil in it. otherwise the things get changed up at valve bounce RPM on every shift. The previous engine had something like 2000 km of flat out abuse on it.
    The new one is only up to about 500 km at the moment but is sweet as a nut
    1986 AE82 Corolla track hack- Silvertop 20V + C56 with Federal FZ-201s, MRP Coilivers, Ultra Racing lower Arm brace, QFM A1RMs, RDA discs.
    Opens Chad's Avatar
    1,449
    Yours and Trave KE 55's datsuns look the same!
    Pull your head in.
    Bunbury
    4,701
    the first one we either over torqued the big end bearing on number 4 or it was due to oil starvation.
    Number 2 was becuase of either incorrect valve length or not enough piston to valve clearance.
    thats rwhp too btw.
    Royalpurple Oils
    WSID
    3,537
    Yep. I know thats rwhp. My mates made just over 120hp at the rears. Similar setup. G200, dual 44IDF's, big cam, extensive headwork etc. It drives really nice. I'm surprised how well it drives actually. Has heaps of usable power throughout the rev range.
    Which rockers did you use? The standard Gemini ones or the lighter Rodeo ones?
    cunt Ze's Avatar
    Newcastle NSW
    1,242
    Why did you choose a 3SGE over building another engine? and being extra careful with the clearances and torques this time?
    Quote Originally Posted by Crash Dummy
    I had reason to believe that the photo could have been of a very well done tranny. I have been fooled in the past :P
    Bunbury
    4,701
    Grumpy,
    We used the standard gemini rockers. If you search for a previous post of mine. we had engine dramas from the start.
    Oh yes the engine was so bloody drivable!!! i couldn't beleive the pick-up and acceleration of out corners!!
    Ze the 2nd motor was better as in the engine lasted more than a full race but the engine having a miss noise at 5000rpm or greater meant coasting down the rear straight and not using the full potentional of the motor. I changed the bent valve instead of getting the engine rebuilder too. So my mistake. I got the correct valve as i was told what it was and i slapped it in. Now the head was rebuilt after the rod let go in engine no1. they repaired the chamber and refaced it.
    Also the 3sge - newer more potent engine and makes more power for the same mods.
    With the E.O.I. i have put in depending on outcome we will build one last G200Z. With everything shotpeened.
    Royalpurple Oils
    Bunbury
    4,701
    well bit of an update.
    The car is now at tony flood mechanical in welshpool. I go down and work on it every tuesday night. I got a tailshaft and a starter motor for it so its going slowly. I finally got to see the manifold with the throttle bodies on it and its the ducks nuts! hopefully guido doesn't cry when he see's what we did to the fiat manifold......
    not bad for a total of $300
    Royalpurple Oils
    Bunbury
    4,701
    finally got a bit more done to the racecar. Repairing the rust.
    this is what i did first. Cut the rusty section out. then made a template. then fitted it to it.
    then we welded that section in.
    then i cut a bit of RHS up and fit that to get the profile of the bootlip. it was to intricent to bend up.
    then this is the finished product.
    Royalpurple Oils
    2,438
    I remember reconstructing a number of areas like this in my first rustbucket.. err.. car.
    It's kind of rewarding, but annoyingly time consuming too.
    Engine's looking good. Tony's a good bloke hey.
    Alex.
    Bunbury
    4,701
    Yes And Very Helpful. I Don't Mind Going There On A Tuesday Just To Watch Him Work And Build Motors. I Hope He Doesn't Mind All The Questions I Ask.
    Royalpurple Oils
    Bunbury
    4,701
    Fuel lines are in and done
    Royalpurple Oils
    Dec 2004
    Country Vic
    813
    Keep at it Fish - you'll be on the track in no time
    Super Moderator TJ's Avatar
    17,944
    Have you ended up going 3S?
    Please tell me your not wasting your time with the shitter motors.
    Quote Originally Posted by Uncle View Post
    Did you baguette up as you left the house?
    Bunbury
    4,701
    yes going 3s and yes its going to go hard. Specially who i have begged to build the motor for me.
    Btw Tj that V6 motor is still there and so is a V4?
    Royalpurple Oils
    17,944
    Out of my price range atm.
    Right now my price range is 0.
    HTH
    13,836
    nice work mate
    if you need a ecu or a logger let me know and ill cut you a good deal for a sticker on the car
    Bunbury
    4,701
    Dale i have the ECU but a logger sounds nice - wish my fuel setup was as nicely set as yours but when your using pre existing stuff not much you can do.
    I know pete looked at a price for me and was supposed to build me another surge tank like the one in the pic. Can you give him a kick in the pants for me?
    Also anyone got an easyway to put those pushlock fittings on? they are cunts of a thing.
    Royalpurple Oils
    13,836
    shoot me a pm of what you need for the logger,
    pete just started a new job so ill see if he has time to do anything for ya
