Results 1 to 20 of 20
Thread: Spongy brakes after misspelling the word Brakes.
    Townsville Australia
    3,341
    GLXi Lancer just got new rear drum pistons, a seal kit in each front caliper and a master cylinder seal kit. No noticable pitting on anything, it actually looked very clean/new.
    The brakes are still very soft however after being bled a handful of times.
    What could cause this guys? I didn't think there was too much to brakes and its beyond me. Can a failed booster cause this?
    Registered User Glenno's Avatar
    Hiding
    6,043
    Failed booster will make the pedal hard.
    Did you bleed the master before you put it on?
    The angle some masters sit on when installed means they will always hold some air if you don't "bench bleed" them first.
    PM me for more info
    Tastes like victory EVOSTi's Avatar
    Copenhagen
    2,180
    poor rear shoe adjustment? bent front caliper sliding pin?
    Where coal meets the sea
    23,832
    you put the calipers back on the wrong sides and the bleed screw is now at the bottom instead of the top.
    Your social better.
    Copenhagen
    2,180
    seen that more than once
    23,832
    Fixed it yet?
    Your social better.
    Hiding
    6,043
    Quote Originally Posted by Secoh View Post
    No one can possibley be this stupid can they?
    I mean yeah you might bolt them up that way but surley when you went to bleed them youd see the fuckup.
    PM me for more info
    23,832
    no, it's an easy mistake, especially if you have never seen the problem before. You'd be surprised how frequently it happens.
    Your social better.
    Copenhagen
    2,180
    +1
    ive had cars come into work like this after the owners have worked on them. had me scratching my head for a while once with a VN statesman, having gone through the motions and not figuring it out why the pedal was spongy. turned out it had two left hand calipers up the front, what a twit. i mean i can understand why you MIGHT put them on the wrong side but to have to left hand calipers on the car?
    3,341
    I will check for him. The car is now going to be a bit of a race hack so I might look at it myself
    Registered User S_E's Avatar
    Dec 2005
    Perth NOR
    731
    Yeh, had a mate put his R32/Z32? calipers on his HR31 the wonrg way, reason being that the HR has the calipers on the rear side of the disc, while the new (s/h) ones in their native location were at the front of the disc, and marked left and right as so, so mate puts them on like so, tears his hair out trying to work out why brakes were soft, bled it a million times, got master cyl rebuilt, THEN realised they were on the wrong way....
    Quote Originally Posted by ALLMTR
    Yes but more power is the solution, even if lack of power isn't the problem...
    Quote Originally Posted by T0nyGTSt View Post
    i wouldn't mind a woman who didn't speak
    what are they gonna converse with you about? your fucking feelings and aspirations?
    i'm only interested in xbox360, VB raw, skids and LCDs...
    Hiding
    6,043
    Quote Originally Posted by EVOSTi View Post
    +1
    Because when he went to pull the replacement right hand caliper off the VN at the wreckers he found that it was jammed up against another shitbox and he mighta damged his mullet getting to it so he took the left one instead.
    PM me for more info
    Jun 2006
    Ararat
    2,928
    +1
    morgs would have no problem bleeding them when on wrong side...
    3,341
    LOL
    Calipers are on the correct side. Still spongy.
    Hiding
    6,043
    I still reckon the master has air trapped in the end.
    Doesn't have ABS does it?
    PM me for more info
    23,832
    yes indeed. Bleed it at the master cyl, then bleed it at both sides of the ABS with the motor running, then bleed it at the rear, then bleed the front.
    always, when bleeding brakes, start at the master then at the furtherest point from the master.
    Your social better.
    3,341
    How does one bleed a master cyl?
    Canberra - ACT
    1,217
    Quote Originally Posted by S_E View Post
    Same "trick" with my RX7 calipers, need to be swapped to keep the bleeders up. I wouldn't have thought someone "smart" enough to do a brake conversion woudl be "dumb" enough not to realise it quickly.
    A.
    23,832
    same as you bleed a caliper but instead of a dedicated bleed nipple, you use the pipe fitting. Start at the rear circuit on the MS first.
    Your social better.
    3,341
    I will give it a try this afternoon, thanks. Will let you know how it goes.
