probably 3 months, depending on time, $ and interest. Wiring everything is going to do my head in.
Originally Posted by Turbo Yoda
2JZ KE20 Corolla 7.97 @ 178
SR20DET Gemini 8.803 @ 155
13s for $1300 FWD: 98 Hyundai Excel Current ET 16.9 @ 78 Total Cost $550
http://www.oke020.com
7.xx is no longer a challenge(sort of)
cheers for that, there shouldn't be anythign I can't sort out, just a combination of moving factory loom, battery in the boot, data logging and completly pissing off the holden factory ignition system and replacing it with MSD, without creating a massive fire hazard.
I am thinking I should use all black wire to minimise its visibility.
Actually, anyone got part numbers / sources for resonably priced:
- Fluid pressure sensors (up to 100 odd psi)
- 2-3 bar map sensors
- Thermocouples
I have an MSD branded 3 bar map sensor spare, i only have it as some full sick at rocket told me it was a 5 bar, will need to go pillage a vn commodore for a connector though,can also supply a diag to make a 5v voltage reg if you need to power it, unless the pcs does that
Cool, will take it, are there any VNs at wreckers or are they all still on the road. I assume the 6al2 will power it, if not will just follow their instructions.
jaycar etc have cheap 5v power supplies, i think i paid 20 bucks for mine. Yeah its cheaper to build one, but my gas torch wont turn down that low lol.
nope, I need them to fit the 4" dump pipe![]()
powercruise 2010?
you bringing your car out fag?
that makes tim cranky (especially when I am right), will you get cranky
um, coca cola seems to do a pretty good job on its own, the mixing in the tent strategy worked wonders, the leaving the eski behind the car one didn't. Not going to go tectaloy again?
This thing is going to be the new definition of awesome at powercruise 2010.
Fucking classic!
Haha that is funny as fuck
Nice tidy up, she really sparkles in the light!!
I survived the great 2v vs 4v debate.
