Need to get a spacer made up before next weekend so I can get the Lancer to Wakefield with a working alternator. Anybody able to make up this oversized washer for me?
Outside diameter - 21.5mm
Inside diameter - 17mm
Thickness 7.3mm
Thickness 7.3mm
I could but will be away most of this week....sorry.
Damn your in sydney, I could have whipped it up in my sleep
Stainless Alloy or Bright steel?
Doesn't have to be anything fancy, it is to space the alternator pulley away from the body.
Any chance you could make it up and shove it in an express post bag for some dollars? Nobody in Sydney is replying![]()
Cool I'll sort something out tonight
if noone helps you out i can whip one up for ya , let me know.
Suzuki Swift Lover
It's done... PM me where you want me to send it
Why you giving your car an engagement ring?
Thanks heaps! PM Sent.
I don't think this will cost the same as the wifes engagement ring.... just need to make sure that the pulley is spaced out from the bearing and only sitting on the centre of the bearing, not the outside part that turns. It doesn't look like it was hitting, but I would rather be safe then sorry. It was also be better then using three washers![]()
HUGE thanks to PHULL! Just got my engagement ring in the post, now I understand the commentExpress post bag was slighlty oversized for it...
Don't forget the bank details so I can send some beer money![]()
Hey PHULL, I'd like a big alloy turntable so that I can drive straight into the carport, turn the car around and then drive straight out. I'll get some specs in the morning and PM my address
