Results 1 to 20 of 20
Thread: Porting with a Dremel
    Registered User ar3nbe's Avatar
    Mar 2008
    356
    I wanna do some port work on my exhaust manifold, and a little on my turbine housing. I currently have a Dremel. Is this going to cut it ? Ive heard a few different thoughts, some people say yes, will work but take a long time. Some say dont bother.
    Anyone tried grinding away cast iron with a Dremel before.
    Better just go out and get myself a die grinder ?
    Small Member Crash Dummy's Avatar
    Hunter Valley, NSW
    2,632
    Don't bother dude. Get a die grinder. I wouldn't consider using a dremal on anything harder than aluminum. Cast iron ? It's just not going to happen.
    Die grinder ftw with the right bits. It'll eat the cast iron like butter where as the dremal won't even be able to barely smooth the surface.
    - Gary
    It is better to say nothing and be thought a fool than to open one's mouth and remove all doubt.
    Registered User RB30-POWER's Avatar
    out in the boonies...
    4,218
    never going to happen.
    every manifold and turbine i have ported with die grinder has given the commercial 10hp workshop compressors a flogging.
    die grinding makes even the biggest compressors seem small.
    Quote Originally Posted by roadsailing View Post
    i like how he had to hire 5 men for the welding, i guess one welds while the others pedal the bike that runs the alternator that charges the batteries that hooks up to the jumper leads that hold the welding sticks.
    Mar 2008
    356
    Ah fuck.
    Im a tightass, need to go spend more cash on something now.
    4,218
    dremel is very handy tool to have however, worthwhile having one in the tool kit.
    Mar 2008
    356
    Anyone know of any cheap die grinders. Do GMC or similar make one ?
    I believe in quality tools, but for something im probably going to use very, very rarly, I cant see the point in spend 100s if dollars
    4,218
    i got a supercheap $20 job from memory.
    done about 5 manifolds/turbine housings with it and these were thick restrictive manifolds needing plenty of meat removed, even oil it every now and again.
    seems fine, still like new, although the chuck part might not be as good as a expensive one, but it's the sort of thing for me, i might use once a year and forget about it.
    Rallyist
    Queanbeyan: Canberra's Bitch
    1,561
    Quote Originally Posted by ar3nbe View Post
    I know of a guy who used an electric router the he "lightly" modified for the purpose. Seemed to work quite well for the job.
    Right now I'm eating scrambled egg. With a comb! Out of a shoe!
    Mar 2008
    356
    Sounding better
    Air, or electric ?
    Rallyist
    1,561
    You missed the bit where I said electric router?
    Mar 2008
    356
    Quote Originally Posted by fro View Post
    Your missing the part where I was talking to you
    I love cable ties. Steve's Avatar
    10,145
    I've used a Makita GD0600 Electric die grinder for building and porting an aluminuim inlet manifold. It had good torque when you load it up, and didn't get hot with extended use, but i did wear some welders gloves to avoud the aluminium chips and vibration. Was a lot of hours of careful work, but the results were worth the trouble, and cheaper to buy than pay someone else and I still have the grinder.
    Auto Electrical Accessory fitting in Brisbane!
    http://securityandaudio.hopout.com.au
    Sidetracked BMWTurbo's Avatar
    Aug 2004
    3,050
    Aldi have air tools currently...
    Silly old bugger.. curmudgeon's Avatar
    Motorboating...
    397
    I had an electric Makita die grinder too that I used for years until the nose bearing wore out.. just go to Bunnings or whatever and check out the electric routers. They use a 1/4" collet like a die grinder, you just have to take off the guide thingy. Look for one that isn't too bulky around the business end. I bought a cheap-arse Ozito jobby and so far it's been fine.
    smilin' for the camera MRMOPARMAN's Avatar
    Oct 2004
    Kangaroo flat!
    6,615
    Quote Originally Posted by RB30-POWER View Post
    + 1. got a supershit air diegrinder also. i oil mine religiously though. copped heaps of abuse so far and still looks like new. i recommend getting the grinder alone, as opposed to the kit version they also sell, as the stones are shit.
    Quote Originally Posted by Sathanas View Post
    Ballarat is as fun as putting my nads into that press
    Quote Originally Posted by Russell View Post
    Ballarat people are generally mongs who need twice as long to do the simplest of tasks.
    Quote Originally Posted by VE Safari View Post
    You know you're a real shit cunt when jmac starts ragging on you too.
    '75 international acco fire truck!!
    '70 VG sedan - current project, now 13's for $1300 project
    '70 dodge yoot, current project - mothballed long term
    '73 KE25 corolla - race car
    '74 KE25 corolla - back on the road!
    '89 BNR32 skyline - mothballed..
    Mar 2008
    356
    Small update.
    Mate needed to grind something small today. Needed to enlarge a hole by about 5mm or so. Told him he could use the Dremel.
    Now I see why it would be impossible to do any sort of porting work with a Dremel. It took him about an over, to grind a 5mmx 3mm section of stainless steel. It was about 1mm thick.
    Fark, handy tool, but just not made for any form of metal work.
    Aug 2004
    3,050
    What 'bit' were you using to 'grind' Stainless?
    wants Sloan clone Lonx's Avatar
    Sep 2002
    2,363
    I've cut through 14mm thick high tensile bolts with my dremel.... it destroyed about half a dozen discs on the way but it still got there!! I developed a new appreciation for the strength of those bolts that day - took about 20 minutes.
    PF Gamers List
    Quote Originally Posted by klampykixx
    if a motor has big enough injectors to run say, 7psi but only just starts to max out right on rev limit, will it run more boost lower in the revs without maxing out if you lower the rev limit?
    Mar 2008
    356
    Quote Originally Posted by BMWTurbo View Post
    A pretty rubbish one. It seems Bunnings has a shit range of Dremel pieces.
    It was one in the green packet, small wheel. I dont have it with me to tell you the number,
    It said it was good for everything except ferrous meterials. And yes, I know stainless is Ferrous, but hey..it kinda worked, haha.
    In the end the wheel wasnt worn to much, but the heat caused the glue holding the wheel to the shaft to do fuck all. Result, wheel flying off.
    4,218
    i only just remembered, i ported a few manifolds with a die grinder type bit in the chuck of an electric drill, pressing sideways, chewed the bearings out a fair bit in the drill from side loading the bearings but worked rather well i must admit and proved how tough the 20 year old singer drill is.
    that was before i got the air grinder.
