Results 1 to 13 of 13
Thread: FS KE20 Project setup for Turbo 1UZFE...farkin
    2,642
    I need to move some long term projects as my little business wants to take over my shed.
    This car is at risk of being shoved around the side of the house under a car cover so figured might guage any interest in it. Obviously i wont be wanting the world for it as its but it has some decent bits in it.
    I have sold the engine box out of it and used the turbo on my cressida. The car is a 1974 KE20 corolla pretty much setup for a turbo 1uzfe, i can probably include the mild steel turbo manifold setup.
    Most of the panel work is now done but its currently all sorts of different undercoat / filler colours, i have alot of parts for it, chromes, 2 sets of doors, grills, etc, some stock seats various interior bits, glass etc. Car is actually quite rust free. Engine bay has been seem welded some point in its life. Gearbox tunnel is from a skyline.
    It has custom adjustable front struts with koni adjustable inserts, the lower struts are ra60, the disks/hubs are slotted vt commodore, i have vt twin spot calipers to suit. I have put a KE55 crossmember and moved the lower control arms in 30mm to correct the track. I have converted the car to rack and pinion using a ke70 rack, it all works but i have no tierod ends on it yet.
    I have clearanced the front end to make a large aluminium VL radiator fit and it can be included also.
    The diff is a shortened 4.44:1 locked 10 bolt salisbury with drum brakes, the rear tubs have been extended at full height to the outer guards so you can get a pretty decent size tyre under there and still have it low. Car is holden 5 stud pcd all round and has 4 x 15" pursuit rims on it.
    Looking for offers, keep in mind the front struts and brake setup cost over $1200 etc.
    Car has some history, used to have a 308 in it and won a few burnout comps at archerfield etc, think it ran into the 11s back then with the 308 in it, was then sold to a friend who fitted an rb20det to it, i bought it back a few years ago now.
    here are some pics
    2JZ KE20 Corolla 7.97 @ 178
    SR20DET Gemini 8.70 @ 157
    1UZFET KE20 Corolla 9.60 @ 140
    http://www.oke020.com
    2,642
    For shits and giggles
    Back in the burnout comp/308 days
    and crazy rb20 conversion days
    Non player character GTSBoy's Avatar
    9,825
    This seems all shades of sensible. GLWTS!
    The non GTS's were gay
    Opens blackbart's Avatar
    The block brudda
    4,102
    If I didnt have three projects already...
    2001 Suzuki GSX-R 1000
    2002 VX SS
    2004 Nissan El Grand
    2001 Land Cruiser
    23,055
    Is the firewall cut up and how many mods to the rear tubs?
    23,055
    Any pics of tunnel/tubs?
    2,642
    Will have to get some, rb20 guy welded the front cut r32 tunnel in, overlapped and double welded. The firewall is 95% stock other than where the tunnel graft has been made. The wheel tubs are standard inner but the top outer has been extended to the outer panel see dodgy ms paint picture below
    Nay sayer Mr Ed's Avatar
    14,642
    I can think of no better idea in the world than Chuck buying and finishing this.
    10,027
    Stupid question here, I would guess that this would in no way be regoable for queensland roads?
    logan, brisbane,qld
    78
    seen you car in zoom y not finish this 1 and put in there also
    2,642
    I was letting fate decide, so far i am getting to keep it
    23,055
    How are the pics coming? My mate who did the conversion on mine is a Uz head and is keen for some pics. Are the mounts for the Uz done? Mainly after tunnel and tub pics to see if the engineer will sign off on them.
    2,642
    tubbs wont be an issue, the tunnel, well depends who looks at it i guess. Never intended it to actually be street legal
