Results 1 to 14 of 14
Thread: Datto 1600 upgrade
    Chairbourn ranger! Uncle's Avatar
    Newcastle
    5,402
    Datto 1600 upgrade
    I have a set of VY front rotors and calipers here can I use them on my datto?
    Redrill rotors to 114.3 PCD etc.
    Anyone done it?
    Recalcitrant Swill's Avatar
    873
    Caliper will bolt to a late model 180B strut (I think?) though im pretty sure this is right. Disks will need some sort disk to hub adaptor made up.
    Looking for 86 GSXR bits. PM me
    Title pending
    2,718
    Shit caliper
    Need alot of fluid to work
    Jan 2006
    2,945
    Quote Originally Posted by Swill View Post
    yep the caliper/strut bit is on the money. Throw the disks away and buy DBA425 verada rotors and they go onto the dato hub and only require some minor redrilling for locating bolts.
    Combine with an r31 rear disk upgrade and new 7/8 master.
    Pending good pads (and possibly braided lines), No L series should ever burn up that setup.
    Jan 2006
    2,945
    Quote Originally Posted by dattoman1000 View Post
    Shit caliper
    yeh they are not the best but much better then stock and if they are free even better.
    Another advantage of this setup is that I recall the 180b struts are shorter meaning the car is instantly lower while retaining full suspension travel.
    Thinking about it if the 7/8s is no good (I'd be surprised if it wasnt) a 15/16 will definitely do the job and is bolt on pending you are using a dato booster (180b small can is go as its easy to install).
    Title pending
    2,718
    Quote Originally Posted by fly510 View Post
    Big and free isn't actually better
    Think fat chicks here
    The upkeep far outweighs the initial investment
    You'd probably need a patrol 1" and what 28mm thick disc do you think you'd use ?
    Jan 2006
    2,945
    15/16 would easily cover the VT twin sopts & the disc thickness issue is no big deal.
    Dec 2004
    4
    Anyone have a part number for the 15/16" master cylinder? Or the 1"?
    873
    Matty pretty sure a patrol on is 1 inch
    Opens HoonBoy's Avatar
    9,807
    SWB Patrol is 1inch, got one on the Lancer. All I had to ask for was a SWB Patrol cylinder and they knew what I was after.
    Title pending
    2,718
    Theres at least 6 different Patrol masters
    What these guys aren't telling you is that you need one for a G60 series Patrol ... late 70's
    They come in a few different configurations
    Metric threads and Imperial threads (they made this Patrol since 1962)
    They also have bleeders on them which can be on the left or right of the cylinder depending which one you get... might get close to the strut tower
    Also a Patrol has drums all round so you need to remove the residual line pressure valve in the disc circuit
    The most common one to use is a JB1419
    And the 15/16" one that I don't think is available anymore is off the 280ZX and its a JB1361
    Mar 2006
    Not Mt Druitt
    492
    The 15/16th's ones are still available, you just have to do some searching.
    Bleed nipples on the wrong side aren't the end of the world, I installed one like that and just drilled 2 holes in the strut tower.
    Guys have even been fitting S14 and/or R32 non abs masters to datsuns these days with success. Redrilling the booster mount holes and using the right length rod.
    Another part number I saw was CE130.42605 -> 280zx 15/16th master with nipples away from the strut tower on a RHD.
    9,807
    My 1inch has everything in the correct spots
    piss taker of the piss Uncle Arthur's Avatar
    10,975
    Yeh they are cast iron though, heavy little buggers.
