Results 1 to 9 of 9
Thread: S14 200SX misfire?
    Newcastle
    261
    S14 200SX misfire?
    After some ideas for narrowing down a bad misfire my engine developed today.
    Was running ok this morning, but when I started it this arvo it sounded like it was dropping back to 3 cylinders now and then. Drove it home and the misfire seemed to cleared at first, then it got worse and stalled a few times. Was lucky to make it back home, sounded like it was running on 2 cylinders.
    Checked the intercooler pipes and none have blown off.
    Suspect dud coilpacks, so pulled them and the sparkplugs out. Coilpacks look fine with no visible cracking. Plugs are very very black, but maybe thats just from dropping a few cylinders.
    Any way to test the coilpacks? or any other thing to check?
    3,455
    can you start the car, and pull 1 coil at a time to narrow it down to 1 cyl? then just swap out that coil pack and see if it fixes the problem.
    Registered User matt b's Avatar
    brisbane,qld
    1,544
    Yep I've had to do this a few times when my CA's coilpacks have died.
    Just start the car and pull one coilpack off at a time. If the car's idle doesn't change for the worse when a coilpack is removed you've found the dud.
    I do not like V slicers.
    "Give it the full rissole son" random old mate 2011
    "If you can't fix it with a hammer it's electrical" Hoops 2007
    Non player character GTSBoy's Avatar
    9,834
    No need to actually pull a coilpack all the way off either. Just pull the loom plug off the coil. Safer too - less prickly.
    The non GTS's were gay
    3,455
    yeah i did it a bit on my pug 405. Had one short thru the boot and one completely shit itself.
    9,968
    Is there any way of checking for error codes?
    I know the procedure for a pulsar GTiR which just requires abit of wire on the console port (right below the inside fuses).
    Quote Originally Posted by MarkMash View Post
    the fact that you HAVEN'T anonymously shat in the managers office yet...
    Newcastle
    261
    running a Power-FC so no factory error codes. Will try and isolate it by unplugging coilpacks, going to be hard when it barely idles.
    3,384
    is it overfuelling? If all the plugs are super black it could be a dud fpr or something of that nature. Blocked return for example
    www.showgroundsphysio.com.au
    www.neillsbikefit.com.au
    out in the boonies...
    4,218
    if you had the hand controller you could check realtime data, like coolant temp, air flow meter and o2 sensor are all working and in spec.
    if the plugs are black, major issue, either it isn't tuned properly to begin with or something has failed.
    Quote Originally Posted by roadsailing View Post
    i like how he had to hire 5 men for the welding, i guess one welds while the others pedal the bike that runs the alternator that charges the batteries that hooks up to the jumper leads that hold the welding sticks.
