Yes i did put it in the wall on the slowest corner. Trying to get the power on early for a quick run down the straight. But it went sideways when i had 2 wheels on the extreme edge of the track. So then i was on the grass and it wouldn't stop. It was only a light hit, but it bent the lower a arm.
The doors come up good. I am happy with them, they are really light, fit well. and open and close as per original.
The old banger mx5 - Phillip Island - 1:50.6 (with 125rwkw's no lsd) Sandown - 1:24.7 (with 110rwkw's and lsd) Winton - 1:36.8 (with 125rwkw' and lsd)
The NA8B 89.3rwkw's - P.I. 1:52.8 -WINTON 1:38.0 - SANDOWN 1:27.6 - WINTON SHORT 1:08.7 -BROADFORD 1:07.9
I actually make the roofs and sell them. The new cars will have more carbon fibre than you can poke a left foot at.
The fun part will be making the wide body moulds.
Fortitudo et Superbiam
Sparta, Rome, The Knights of Europe, the Samurai. They worship strength, because it is strength that makes all other values possible.
Han, Enter the Dragon
Back then the car was very unpredictable making it hard to drive consistantly. It had coilovers in the front with about 1" droop and lowered springs on standard shocks on the rear with about 8"'s of droop. And a viscous diff which would sometimes work, and other times would just spin one wheel. Since changing the coiolovers to a set of new matching ones and installing the torsen i haven't come of yet. Touch wood. Now when it feels like you have pushed it too far, you can get it back. No way you could do that before.
Looking good! Glad you found the forum, not sure if it was from my sig on the mxfag forum!??
I'm on the waiting list for a hardtop.. by waiting list i mean i'm waiting until i can afford it..![]()
No, i will be going to the aroca day on the 3rd of july at phillip island. Need to give the old motor a quick freshen up and pull out the stock motor that is in it. Hopefully i will have it done by then. Should be good for 1:47's.
Still have mould for carbon doors?
Yep.
What kinda $$ are the lid and swinging panels?
Hardtop is $900 bare and $1450 fully assembled with lexan window, lower rubber, side window rubbers, lazer cut brackets and fastners.
Doors are $1250 each - assembled with holes drilled/cut. Extra $100 each for window frames and lexan window.
Clear coat is $200 for the hardtop and $200 for a pair of doors.
I can also do carbon/kevlar combination too.
Yes I did sell an Mx5
I started getting the NB ready for the cage last night. Started at 8.00pm and finished ripping out the softtop, interior and boot by 11.00pm.
Buy an NB, i will have all panels for it. I only have the doors for the NA model. You could use all the front NB panels on an NA though.
At 450hp you will need to spend big $$ on the drive train.
I have gone through 3 gearboxes and a diff and my turbo mx5 race car only has about 250hp at the rears. Also will need to look at drive shafts.
Interested to see how it all pans out.
Neil
I have never broken anything except synchros, and that was my fault. I have 200rwhp and everything on my car was 20yrs old except the motor until recently. Maybe because it breaks traction instead of breaking parts.
No question. Slicks put a lot of strain on the drive train that isn't there with semi slicks.
1995 Mazda MX5 - 2F Race Car
1991 Mercedes 300TE
1990 Mercedes 230E
1990 BMW E30 318is
1977 Jaguar XJS V12
1971 Morris Mini 1100K
1957 Porsche 356A Speedster Replica
In time attack you can only run semi's. Pretty much the only rule except the car has to be a production car.
And it has to have a roughly standard floorpan. I.e. profi's excel is out.
I cant get no sleep...
What the... is a profi's excel????????????
i worked it out, so what have you done to the excel?
No floor pan what so ever.... any chance to run a time attack?
Profi
