Well I still haven't bleed the brakes! But I have got all the parts on the inlet dummied up. Just waiting for the correct silicon joiner before welding it all together. Also made up a TPS mount for the new TPS on the M30 throttle.
I have also started to modify the fuel rail. Normally the fuel reg pipe goes down the inside (ghey) so I have removed the fuel reg and will be welding on fittings either end for the supply / returns and then running a different fuel reg (probably a Subaru one as I have heaps of them :crazy )
I got out my spare E30 alternator mount and looks like this is going to work better than the E36 one. Because of the way I made the take-off plate for the oil system I need to space it off the block, but this won't be a big dealSo thats nutted out. And as I mentioned got an idea sorted for the swaybar. That leaves mounting the new radiator (when it comes), mounting and plumbing up the accusump and the electrics.
