Page 4 of 6 FirstFirst 123456 LastLast
Results 91 to 120 of 168
Thread: SWB Pajero L67
  1. #91
    I need more cylinders! nine2nine's Avatar
    Gympie, QLD
    1,160
    Projects:
    '90 2jz-gte 929
    '02 twin-locked TD42 GU Patrol
  2. #92
    Gympie, QLD
    1,160
    A bit of of an update with this thing.
    Has been serving as my wifes work car since it was finished, has been extrememly reliable, but a thirsty pig.
    Has had 1" body lift, tyres touched the mudflaps on flex.
    Went to Landcruiser park, twas good, cheap chinaman cv joint sheared off in the middle with very little abuse, so was a 3 wheel drive for the weekend, genuine reconditioned mitsubushi cv going in next week.
    I have some good vids, but need good internets to upload.
    These are the only still pics i took, so forgive the ghey flex shot pose.
    minor damage to the plastic, i will admit the door and sill are crumpled metal underneath.
    Also went in the local burnout comp, have 2 vids to upload, locker worked well, 31's were not the ideal tyre size to smoke, but it did a good skid.
    Pic i found on boostlosing...
    Projects:
    '90 2jz-gte 929
  3. #93
    Gympie, QLD
    1,160
    Forgot too, was on the way to the gold coast after cruiser park and cough splutter, run out of fuel with 1/4 still showing on the gauge.
    Jumped under the back of the car and the tank capacity has shrunk somewhat, with an especially large dint where the sender is.
    So that was a great walk for the missus and myself, luckily only about 3ks from a servo. so now she has to fill the tank up at 1/4 cos thats where the gauge stops moving.
    Projects:
    '90 2jz-gte 929
  4. #94
    Gympie, QLD
    1,160
    z
    Projects:
    '90 2jz-gte 929
  5. #95
    Gympie, QLD
    1,160
    In this vid the passenger side cv is already broken and removed, and I forgot to put the rear locker in, but it is a cool video.
    Projects:
    '90 2jz-gte 929
  6. #96
    ruddvegas
    5,562
    Thats good for a laugh. Still sounds like boosted moo though.
    P.S dont forget your locker
    Quote Originally Posted by <---cop View Post
    Here's a novel idea. Go fuck yourself
    Need plumbing for new construction, shop fitting or commercial maintainence?
    Call Plumbing Perfection on 1800 088 699
  7. #97
    Gympie, QLD
    1,160
    No updates for awhile.
    Lots of offroad has happened, car is covered in dints and scratches, and looks real abused.
    Rear locker has stripped all the teeth off, so it doesnt work anymore, might be time for an air leaker.
    Projects:
    '90 2jz-gte 929
  8. #98
    Gympie, QLD
    1,160
    Projects:
    '90 2jz-gte 929
  9. #99
    Gympie, QLD
    1,160
    Cape york TO DO list. We leave 21st of June!!!
    towbar (for camper)
    Manifold / supercharger / tappet cover, re-seal engine leaks.
    Remove rotten and abused carpet.
    Front wheel bearings replaced
    Rear locker working
    Replace pinion seal rear.
    shockies rear fitted
    shockies front fitted.
    Oil change
    Sump damage welded up (slow leak)
    Sump bash plate strengthened and re-fitted
    New engine belts
    Aircon gassed and working
    coolant in radiator
    Mount top of radiator properly
    cruise control wired up
    cargo barrier made
    Washer bottle working
    New UHF fitted
    Stereo working better
    New pitment arm
    New inner tie rod
    new fuel filter
    Rear diff breather extended
    Snorkel finished
    Tarp for front end
    Tolene to add to fuel for 98 octane.
    Will cross off as i go! Some things have been started now
    Projects:
    '90 2jz-gte 929
  10. #100
    Apr 2012
    Atherton
    7
  11. #101
    Gympie, QLD
    1,160
    Cool, cheers mate, will have to get a map out soon and see where i am being led to.
    Pulled out the interior to remove the carpet, pretty rotten, it didnt even come out in one piece. Gave the floor a good scrub and hose out, ready for paint.
    Bought some speakers from jb hifi on the weekend, they had a 30% off sale. So 4" for the dash, and 6 x 9 for the rear sides. didnt spend much, but sounds good.
    Existing cd player now mounted properly, instead of with duct tape.
    Projects:
    '90 2jz-gte 929
  12. #102
    Check it cunts! 80DGY's Avatar
    Awesomeville
    33,611
    Bed here in the big Tville too if you need one old mate
    Quote Originally Posted by choppo View Post
  13. #103
    Apr 2012
    Atherton
    7
    Elliotts probably pretty keen to catch up with ya, bringing your bike with you?
  14. #104
    Gympie, QLD
    1,160
    cool, sounds good. spoke to crew cheif, thinking atherton is a good distance from mackay (our first stop) at approx 8hrs. Thanks for the offer bodgy
    No bike, too much other junk to carry im thinking.
    Been busy. Floor painted in 2 pack with a brush and roller.
    I eventually decided to mount the amp for the stereo on the back of the passenger seat.
    Flat surfaces are hard to find in the swb, so its either the seat or the floor, the floor is likey to go under water.
    Snorkel done too.
    How it joins in the engine bay
    Mounted uhf ariel as well.
    Pulled rear diff centre as the oil was full of metal.
    Factory rear air locker is stuffed, only 6 teeth left on one of the sides of the lockers meshing teeth.
    tough day.........
    Projects:
    '90 2jz-gte 929
  15. #105
    bus wankers! crack's Avatar
    BNE
    1,515
    snorkle getting an air filter? what you got planned for the diff?
  16. #106
    smilin' for the camera MRMOPARMAN's Avatar
    Oct 2004
    Kangaroo flat!
    6,602
    engine block for jack stand... love it
    Quote Originally Posted by Sathanas View Post
    Ballarat is as fun as putting my nads into that press
    Quote Originally Posted by Russell View Post
    Ballarat people are generally mongs who need twice as long to do the simplest of tasks.
    Quote Originally Posted by VE Safari View Post
    You know you're a real shit cunt when jmac starts ragging on you too.
    '75 international acco fire truck!!
    '70 VG sedan - current project, now 13's for $1300 project
    '70 dodge yoot, current project - mothballed long term
    '73 KE25 corolla - race car
    '74 KE25 corolla - back on the road!
    '89 BNR32 skyline - mothballed..
  17. #107
    Brown Cunt MR-PUNANNY's Avatar
    3,435
    fARRRRK WHAT A BEAST!!! love it man!
    Love the staffie toooo
    Quote Originally Posted by The Property Guru
    Quote Originally Posted by oxy View Post
    No, that's asians
    A80 Supra
    80 Landcruiser
  18. #108
    Gympie, QLD
    1,160
    Thanks!
    Factory pajero airbox is in the engine bay.
    Looks like it will get an arb air leaker as eaton make nothing for the pajero.
    So I picked another diff up off ebay for $50.
    I needed a complete diff as the factory locker axels are different to normal.
    My crownwheel and pinion are worn out as well, due to all the metal floating in the oil.
    I replaced all the interior screws with stainless, the rusty old ones were not easy to undo.
    I made a plate to bolt to the factory towbar position, then welded the trailer hitch to it.
    I dont have a towbar, so this is easy.
    The missus new car that allowed me to have the pajero back.
    Projects:
    '90 2jz-gte 929
  19. #109
    Registered User rash's Avatar
    Aug 2010
    Nambour
    51
    Quote Originally Posted by nine2nine View Post
    you forgot to mention how insanely fast this thing is!
    $50 for a complete Paj diff!!! wish toyota diffs were this cheap...
  20. #110
    Registered User vet 180's Avatar
    Sep 2008
    Dubai
    1,433
    Very very cool car. Seems to be a weapon. I am thinking of grabbing something for the dunes was thinking about one of these, but a little scared by people saying the are very unreliable. Hows the reliability power with the stock donk? The heat is high here. Pootrols and cruisers are stupidly over priced here.
    Quote Originally Posted by Babalouie View Post
  21. #111
    Gympie, QLD
    1,160
    Yep rash 14.2 @ 100mph time to fit a chute!
    The stock engines have head issues, mostly corrosion but also bhg's mostly due to lack of maintenance / overheating.
    I would buy one either with bhg's ready to fix, or with reciepts to say it has been done.
    the 3.0 has no torque and relys mostly on revs to get anywhere, not ideal in a 4wd.
    The 3.5 is much better, more power, more torque, and a heap better fuel economy.
    They are not known to overheat at all under load or hot conditions so that should be no worries.
    Todays efforts, me tired.
    New diff pulled apart. Crownwheel has some wear, I will get it looked at by someone who knows more than me.
    One new inner tie rod and idler arm fitted today.
    Front shocks $260 delivered pair.
    Fitted.
    Projects:
    '90 2jz-gte 929
  22. #112
    Gympie, QLD
    1,160
    Projects:
    '90 2jz-gte 929
  23. #113
    Aug 2010
    Nambour
    51
    nice, you waiting for dog to unwrap it for you? haha
    you fitting this tomorrow? when is compressor comming?
  24. #114
    Gympie, QLD
    1,160
    Still need to order the compressor so far, thinking i might get a decent one. Might do something about fitting it today lots of bearings to press on / off.
    Was thinking about doing the rear wheel bearing while the axels are out too, looks like a mission though...
    Projects:
    '90 2jz-gte 929
  25. #115
    Registered User GMMAD's Avatar
    nowra
    244
    very cool mate..any plans for more power tune ,intercooler more boost?
    VT clubsport LS1 M6
    VK calais LS1 turbo M6
    3.8 4runner
    2wd 4runner prerunner style build
    KTM 520/540 BB
  26. #116
    Gympie, QLD
    1,160
    thanks mate.
    Yeh i have dreamt of more power, even got semi- serious at times with the research. The corolla would need to be finished first though.
    So the list would be:
    Air/air intercooler
    mafless tune
    18 psi pulley
    hopefully one day...
    Projects:
    '90 2jz-gte 929
  27. #117
    Registered User E-Z's Avatar
    sunshine coast
    1,066
    putting carpets back in or running the painted floor? looks pretty good i reckon, i might do it to my 4wd
  28. #118
    nowra
    244
    thanks mate.
    Air/air intercooler
    mafless tune
    18 psi pulley
    sounds good you will need to add injectors to that list
    hows the gearbox holding up?
    VT clubsport LS1 M6
    3.8 4runner
    KTM 520/540 BB
  29. #119
    Gympie, QLD
    1,160
    injectors, where do they run out?
    Gearbox is good, no problems at all. I really should have a temp gauge on it though, if it dies that will be why. Beach driving seems hard on it in particular.
    Projects:
    '90 2jz-gte 929
  30. #120
    Gympie, QLD
    1,160
    Running painted floor, apparently its pretty noisy though. Will see how it goes.
    I am going to chase up some rubber i can put down thats easy to pull out, and hose out.
    Projects:
    '90 2jz-gte 929
