Page 4 of 16 FirstFirst 1234567814 ... LastLast
Results 91 to 120 of 473
Thread: 2004 IPRA Monaro 6 litre
    Apr 2003
    Roleystone
    2,202
    800hp was so 2010, We are in 2011 now so 1000hp is the standard power output for V8 IP cars.
    Registered User tinkerbell's Avatar
    2,843
    yeah - updates?
    Opens profi's Avatar
    Feb 2009
    1,866
    Chop, updates asap.
    Profi
    Feb 2009
    1,866
    Pics of cage around dash?
    Profi
    Registered User choppo's Avatar
    Nov 2009
    What a riot!
    1,414
    Righto, movthis is finally happening.
    New hubs and studs
    Grabbed a dummy block to make some gearbox mounts for the Hollinger
ID:	56581   Click image for larger version.
    Quote Originally Posted by teamtoken View Post
    In the era of smartphones now, different story. Makes me scared to get shitfaced and chase cunts around with my dick out now because it could be seen by more than 20 people
    Nov 2009
    What a riot!
    1,414
    Brakes back in, K-Frame back in
ID:	56583   Click image for larger version.
ID:	56584   Click image for larger version.
    Nov 2009
    What a riot!
    1,414
    My new invention... The DDD (Diff Draining Device)
    Apr 2003
    Roleystone
    2,202
    Better make a few checks on the cabin size, Theres some info claiming the roof is to low for IP. Check and if under fill out the application form to make sure you have no problem. Its a NSW guy that found this info out.
    Nov 2009
    What a riot!
    1,414
    So this arvo.
    I need a diff cooler. Last 1hr race i boiled the diff oil. You don't want to do that to a KAZZ. So thread/tap for future fittings (-8) and 1/2" for Bosch sensor.
ID:	56587   Click image for larger version.
ID:	56588   Click image for larger version.
    Nov 2009
    What a riot!
    1,414
    I have my tape measure out as i write this
    Apr 2003
    Roleystone
    2,202
    We went thu shit with Luigi Decunta over Ashlys S14, we had to go thru the process, A guy from NSW found Monaros are 51mm lower than S14s and made some noise about it. Not Gary C by the way.
    Id hate to see you go thru Mr Decuntas shit like we did.
    Nov 2009
    What a riot!
    1,414
ID:	56607Luigi is Mario's brother yeah?
    He can suck Mario's dick, make mouth babies then challenge me if he wants to.
    Anyway, replaced rear studs today....
    Nov 2009
    What a riot!
    1,414
    Righto, tip for other Crommie owners.... DO NOT remove your rear hubs if you want to change studs! Spent all day trying to solve a problem i created
    Bad idea and now im now going to have to pay for someone to re-seal the whole hub. Did the drivers side without removing the hub and was simple as - hindsight is a wonderful thing
    Rear rotors were not 'floating' on the hats (semi rusted in) so removed the hoops and next job is to clean them all up along with the rotors.
    Nov 2009
    What a riot!
    1,414
    Emery cloth + orbutal sander FTW
    I might gease the faces of these so they don't rust again
    Registered User TOTAL's Avatar
    Jan 2011
    Shepparton
    34
    Not sure if im going to re-load this porn or up the anti immediately...
    Do stack do the the ITB for LS3 yet?
    Nov 2009
    What a riot!
    1,414
    Dunno. But i wouldn't bother with the ITP* in IPRA. Pain in the arse to get cold air into them under IPRA rules for no real gain. Also you need endless cheap tuning hours on track to get it sorted 100%
    It is way easier/cheaper to get the good 'ol OTR cold air induction and off ya go.
    *i like em and they look 'race car' so i'll keep em
    Jan 2011
    Shepparton
    34
    Whats not hard with IPRA rules.....
    Kinda need more air with the new engine.
    Nov 2009
    What a riot!
    1,414
    Rghto, a bit boring but for those following.... in order to fix the 'removed rear hub mistake i made the other day', i decided just to buy a whole new rear frame. Commwreck and $200 FTW. Only need the passenger trailing arm but on a positive note, at least i have a nice collection of spares building (not that im going to need them)
    Also new (used) Ebay $38 engine mounts (the aluminium bits) and new Harrop diff mount (bent the shit out of the previous one). Diff hat and bushes are fine, just mangled the mount in the prang.
    Nov 2009
    What a riot!
    1,414
    I can't win a trick at the moment... Put the 1st rear rotor/ hat back together and (long story short) found i have a bent hat. Piss me off!
    That said, listening to the ANZAC stories on the radio makes it pail into insignificance...
    1,298
    Press disc hat straight gently, examine carefully for cracks and turn true.
    Probably a bit late now for this. There is a direct fit tapered roller bearing upgrade from the AWD or Crewman that about doubles the rear wheel bearing capacity.
    Polishing a couple of thou off the drive flange journals in a lathe so they are a slip in fit with the bearing makes things a lot easier when working on these.
    Nov 2009
    What a riot!
    1,414
    Quote Originally Posted by Momus View Post
    Nice idea but not for me.
    Off to Bo$njak for a new pair of hats (another spare part for the cache).
    Nov 2009
    What a riot!
    1,414
    So today's drama and a reminder why i should dummy-fit before final install.
    The Ebay seller of the gearbox/clutch/flywheel said this frizbee would fit
    Jan 2011
    Shepparton
    34
    Looks like a SBC flywheel to me....no it will not fit.
    Who the fuck buys a Holinger of e-bay anyway ;-)
    On a side note I see your using Procomp heads, Have been told to stay clear of them, did you have any troble with them?
    weirdo F|sh's Avatar
    Bunbury
    4,680
    procomp states!= procomp aus
    Royalpurple Oils
    Nov 2009
    What a riot!
    1,414
    Quote Originally Posted by TOTAL View Post
    Looks like a SBC flywheel to me....no it will not fit. Who the fuck buys a Holinger of e-bay anyway ;-)
    It waz goin for cheap man an wasnt left in d rain or nofin cince it waz in a supacar
    Am i? Where did you see that in the pics ?
    Nov 2009
    What a riot!
    1,414
    Edit- double post
    Jan 2011
    Shepparton
    34
    Quote Originally Posted by F|sh View Post
    Thats the problem, procomp oz = shit. but procomp USA seam to be ok.
    Jan 2011
    Shepparton
    34
    You fucker Choppo.
    Been looking for one but didnt bother with e-bay.
    One of your pics shows the end of a Procomp head. One photo also shows an Iron block? Must be used just as a dummy fit.
    Nov 2009
    What a riot!
    1,414
    You fucker Choppo.
    LOL - nah man, it's not an Ebay buy (hence the italics). From a PF Member actually.
    Heads are ETP
    Nov 2009
    What a riot!
    1,414
    Solid engine mounts arrived....
