Page 5 of 16 FirstFirst 12345678915 ... LastLast
Results 121 to 150 of 473
Thread: 2004 IPRA Monaro 6 litre
  1. #121
    Registered User choppo's Avatar
    Nov 2009
    What a riot!
    1,468
    So joined the box to the bellhousing to the block and inserted in car. Man that is a prick of a job to do by yourself!!!! Got it in, minimal scratches and the good news is it fits.
    Solid engine mounts look fine
    Started on gearbox mount
    Quote Originally Posted by ZammoTheChoppa View Post
    is there a joke i am not getting ? is puns short for punctures ? why are so many people getting the joke or the punctures ? my head hurts ?
  2. #122
    Newcastle Knights in 2013 Nathan Tinkler's Avatar
    4,817
    Paint underneath is way too flash!
    Not allowed to seam weld?
  3. #123
    Nov 2009
    What a riot!
    1,468
    Nah, just 'neat' so i can see any tell tail traces of oil/grease if and when they happen
    Yep can seam weld as much as i want
  4. #124
    4,817
    The rails look like they are crying out to be stitched in to the floorpan?
  5. #125
    Nov 2009
    What a riot!
    1,468
    Yeah, thats what i was going to do when it was on the rotissary but we decided not to. We want to keep the rear end pliable. The only seam welding done is the firewall, around the strut tops front and rear. We even go to the extent of using all standard rear end bushes and standard swaybar.
    The cage goes to the front strut-tops and they are seam welded (as they usually seperate from the chasis after some time).
  6. #126
    Registered User full_noise's Avatar
    perth
    27
    Nice pics choppo, what weight do you think you'll be at????
    Any pics of the cage???
  7. #127
    Nov 2009
    What a riot!
    1,468
    Quote Originally Posted by full_noise View Post
    .... what weight do you think you'll be at????
    Fuck knows lol. Everything is heavy on these things. Try lifting a diff or even a door or boot!. Everything is bloody heavy. That said, within reason, i have removed as much as i can. All the underbody/inner body deadener, tags and lugs etc etc all gone.
    But then i go put another bar in the cage that negates all that work.
    What part of the cage you after pics?
  8. #128
    Nov 2009
    What a riot!
    1,468
    Waiting on parts so decided to clean the oil tank. Boring for some, but for others who are interested, this is what is in a Peterson Oil tank
  9. #129
    Nov 2009
    What a riot!
    1,468
    Dummy fitted the dry sump tank, surge tank and reg
    More pics of surge tank
  10. #130
    Apr 2010
    32
    Are you going to use a standard fuel tank or will you have a custom one built for it??
    I would love to do my car as well as you have done this, its fucking unbelievably awesome
  11. #131
    Nov 2009
    What a riot!
    1,468
    Quote Originally Posted by ova400 View Post
    Thanks Ova,
    Funny you ask, the plan all along has been to use >>>> http://www.ebay.com.au/itm/ATL-17111...item43ac33b20d and build a steel box around it ala-NASCAR-. But im so god damn aware of safety, i dont really want to be carrying around 20/40Ltrs of fuel inside the boot. I seal the rear bulkhead pretty well, but in the event of a (another) big prang i would rather the fuel under and outside the car.
    So in short, only yesterday i decided to use the original tank for the timebeing at least. I only use approx 20ltrs of ULP per race so i might do some research on something that is only that big and fits under the rear drivers side.
    I'll finally get those cage pics up this arvo too!
  12. #132
    Nov 2009
    What a riot!
    1,468
    Not sure what you did today, but i managed to get 1/2 a gearbox mount done lol.
    Seriously took me 6hrs after mocking up bits and pieces, going and getting some 5mm steel and trial fitting...
    Mock-up version 1 and 2 in Al.
    Finally happy with a shape for the base part
    Tack weld all together
    Can't believe how long it took and it ain't even half done!
  13. #133
    Nov 2009
    What a riot!
    1,468
    Finally picked some other stuff up.
    2 x front heated screens
  14. #134
    Nov 2009
    What a riot!
    1,468
    A couple coolers arrived. One for diff and other for g/box. Both with inline pumps.
    Note the trick mesh someone made up for this
  15. #135
    Nov 2009
    What a riot!
    1,468
    I promised some detail pic of cage etc
    General cage pic
    Rear cage pic
    Behind firewall pics. For the knockers, yeah the bar aint straight, but impossible in my situtation to do otherwise
    Cut the floor out for tall blokes lol
    Note the tailshaft loop i incorporated into the trans mount area - rules are rules
  16. #136
    4,817
    I think this thread would get more views if the title was accurate.
    Car looks mint.
  17. #137
    Nov 2009
    What a riot!
    1,468
    Car looks mint.
    Title is an old gag. Probably should change it.
    How does one do this?
    Cheers for comps btw
  18. #138
  19. #139
    Nov 2009
    What a riot!
    1,468
    I'll do it- What model is it? Engine?
    Probably best to call it 2004 IPRA Monaro???? People who are interested in racing will get the idea. It's 6ltr, but that's the class limit anyhow.
  20. #140
    perth
    27
    Thanks for th car pics chopp looks great!!!
    Are you planning on running side exhausts or a full system??
    With the holinger how far back is the shifter from the firewall???
    Cheers
  21. #141
    Feb 2009
    town & country-adelaide SA
    2,569
    You are missing 2 compulsory Backstays between the top bend of the main hoop & the rear suspension p/u point [Diagram j4 in Schedule J
    RIP ROOKIE IPRASA #33
    2 June 2012
  22. #142
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    8,172
    Quote Originally Posted by Dave75 View Post
    true that! also the "windscreen spreader" is below the steering column which is not allowed.
  23. #143
    Nov 2009
    What a riot!
    1,468
    Fark!!!!
    To be honest i had not reviewed the new Schedule 12 as the cage was done so long ago.... anyway, ill have to get that done. Whilst there im going to removed the semi vertical member spanning the drivers door opening. I't way to close to my hand on the steering wheel. Looks good but shit design for this car and seating position.
    Rowdy, nah the bar is above the steering column. The pics dont have a steering column in there - you can see the hole in the firewall for the column and its way under the column. Getting the bar over the column was major pain!
  24. #144
    hotel vast horizon
    8,172
    so it is... will have to get my eyes checked
    you won't be allowed to get rid of the sainz bar- it's compulsory now on door openings as big as are on commodores/monaros.. you can put a bend it in in front view to get it away from the wheel- which is what mine has..
    overall though, very nice cage..
  25. #145
    Nov 2009
    What a riot!
    1,468
    Cheers
    I'll run a side pipe again i think. I've got my last one sitting here on the floor actually.
    Funny enough the gear stick is in the same place as original. Mind you i purchased a new Al. bellhousing to suit a Commodore, so im assuming it was designed with the length to suit. I've not had to touch a thing with the tunnel nor gearstick opening. I shoot up a pic when i finish the mount today.
  26. #146
    Nov 2009
    What a riot!
    1,468
    I noticed something like a max 20deg bend in there somewhere.... i've just printed out Schedule 12 and will grab my tape and do a comprehensive check today - fingers crossed!!
  27. #147
    Feb 2009
    2,569
    The Saintz Bar is supposed to be a single tube only, welded at the top & the base.... & inside of the door bars.
    Not the way you have it with 2 bars/4 welds through the top door bar...weakens the top door bar a bit.
    Also,,a short bar at right angles to the Saintz bar ,forward to the windscreen hoop...makes 2 more triangles in the front corners
    ^^^ this one is not "compulsory" but adds a bit more strength with not much more added weight.^^^
    Still a very nice ROPS.
    2 June 2012
  28. #148
    Nov 2009
    What a riot!
    1,468
    Thanks Dave. Understand on all points, i appreciate your input!
    I've got all my seat mounts ready so i might temporarily put the steering column and seat in and take some pics showing the clearances to my hands/legs.
    Agreed on single piece Saintz bar and perpendicular member - i don't think the single piece is compulsory but is logical. I’ll see how the clearances go this arvo.
    Thanks again
  29. #149
    Registered User womblesti's Avatar
    May 2004
    1,100
    Awesome car!
    I was worried about the hand clearance on my Sainz bar (maybe 10cm clearance) but when driving it was never an issue.
  30. #150
    Nov 2009
    What a riot!
    1,468
    Dave, whattya reckon on the legality of the roof bars..... i'm not hopeful
    Also confirming the 'backstays' as you pointed out earlier. They need to connect to the main hoop at 'roof level'. Not 1/2 down as done here.
