Results 1 to 9 of 9
Thread: VT Commodore. VX Engine transplant. Any problems ?
    Smoking is bad for tyres Crash Dummy's Avatar
    Hunter Valley, NSW
    3,135
    Hey PF
    This one's totally out of my league. I'm used to bikes with carbies and stuff. So here we go.
    A friend has a VT Commodore which has a tired engine. He's got the chance to pick up a VX motor and gearbox for very cheap that's in good nick but we're a bit concerned about the compatibility on installing a VX engine into a VT body. My understanding is the VX didn't have any major changes in the engine but somehow picked up a few ponies, uses less fuel and had a different shift strategy for the auto.
    Is this as simple as bolt it in and it'll work flawlessly or do we need to do a ECU / BCM swap as well. Or would we be so lucky that we just get the VX's memcal and then everything is hunky dory from there on ?
    Cheers.
    p.s
    Sorry for such a boring question.
    p.s.s
    This needs more LS1 but that isn't going to happen.
    - Gary
    MX83 Cressida (1UZ on the way eventually maybe)
    K2 Suzuki SV650S (because it works and it'll kill me if I'm stupid)
    It is better to say nothing and be thought a fool than to open one's mouth and remove all doubt.
    11,223
    sr20
    10.83 @ 125
    Registered User Glenno's Avatar
    Hiding
    6,689
    Really late model VT's had the gen 3 anyway didn't they?
    PM me for more info
    14,382
    They did Glenno but im sure its a V6
    Member guidos's Avatar
    437
    i think it should be a straight swap for you. i recently put a vy v6 into a vt. sump had to be swapped (as it was changed on the VY - your VT and VX should be the same). everything else just fit. the only problem we had was the Idle air control motor was different on the VY throttle body - the chamber is longer so with the VT IAC it would wind out the plunger. solution was to swap the whole VT throttle body over.
    Autoerotic Mummification TonyJZX's Avatar
    23,609
    VT VX are largely the same
    swap should go fine and any half decent mechanic should be able to sort out any issues
    Quote Originally Posted by boxxx
    Hunter Valley, NSW
    3,135
    Cool guys. Thanks for the heads up. I'll get on top of it
    - Gary
    Peoples Champ Fatboy's Avatar
    11,298
    The loom was slightly different and had to be swapped. You could have just asked...
    Sep 2003
    408
    buy my vx and burn your vt
