Page 6 of 32 FirstFirst ... 234567891016 ... LastLast
Results 151 to 180 of 937
Thread: 13s for $1300
  1. #151
    3,932
    Cambelt would be interested in the sedan. He posted in your ad. I think I need to buy the donk.
  2. #152
    4,955
    historic rego on the other hand, is easier .... to get, and serves the purpose
    not so - your car still needs to be RWC - and be fairly standard.
    and if your club lets modded cars it would /should be engineered as per any normal full reg car mods requiring an eng cert
    street rods (SR) is slighty different - but its signed by an engineer
    if you in sth australia - you cant even have different wheels (i believe) on historic reg
  3. #153
    Sunshine Coast, Qld.
    7,847
    The engine even has two extra injectors in the x over pipe. Perfect for dodgy drag cars.
  4. #154
    3,932
    PM sent.
  5. #155
    480
    I think the rules and competition should be kept to a minimum - too many of these budget based competitions are killed by their own rules.
    Make it the "I'm going to spend $1300 and see how fast I can go and you should too" challenge and you are on a winner.
    Valiants must still be heavy though (1400kg??) is the 265 really that good?
  6. #156
    Registered User dirty_sandwich's Avatar
    1,125
    Bluebird mentioned earlier in the thread for $500
    253 from the wreckers i bought for $300
    Rebuilt trimatic i have market value = $800
    Weld diff $0
    $1600. damn. I agree with changing this to a bang for buck formula.
  7. #157
    Autoerotic Mummification TonyJZX's Avatar
    23,609
    if someone could get a ca18det for a few hundred and drop it into that $500 bluebird, it would probably piss in 13 secs...
    Quote Originally Posted by boxxx
  8. #158
    1,125
    Hmm I'm not up on the jap motors so that would be out for me. Plus this 253 I already have. I'm thinking seriously about this bluebird. Would be good to meet some of you cunts as well.
  9. #159
    12,987
    Quote Originally Posted by sammm View Post
    VH-VK are a tad more than 1400kg.. CMs are 1510ish!
    ill be starting with a VG however, which is around 1220ish
    265s with mild mods are usually good for 13's, however anything better than that can become spendy!
  10. #160
    12,987
    yes and no (in victoria anyways)
    most clubs are alot less strict on rust. the cars still have to be safe though. mild mods are usually ok with the clubs too.
    * in my case, the VG with 265.. the engine is 10ci larger than the largest 6cyl made for them, and is the same engine family.
    *they came with 3speed autos from the factory.
    *they came with borg warmer diffs from the factory, however mine will have 10" drums, 1" larger than factory.
    *they had optional front discs, ill be using later CM front discs, which have alloy calipers instead of cast iron. clubs in vic wont pick that.
    *VG pacers had an optional 4BBL inlet from the factory. mines an aftermarket manifold and holley instead of factory carter. no biggie. will mod factory aircleaner to fit it.
    *will fit 15" falcon rims for the drags (i suspect easier to find slicks to borrow) however for club reg ill run factory hubcaps and 14"s if required.
    so really, apart from the floorpan rust in my paticular car and shit paint.. i think ill shit in historic reg. daves crown with 7MGTE will need to be inspected with original motor and then converted if he wants historic reg.
    if they get snippy with me, ill quietly remind them an older member is running a 245 hemi, front discs etc in an old 1950's plymouth cranbrook? on club reg
  11. #161
    Dreamer millsi's Avatar
    Jul 2006
    Logan Bogan
    3,130
    shitter gemini 500,
    moo conversion 500-800
    profit
    Nope
  12. #162
    2,646
    The more i think about it, the more i think it should be.
    $2000 street car challenge
    1. No nitrous
    2. Within rta capcity guidelines (no big block 120ys)
    3. Safety items not counted in total ie ball joints/wheel bearings
    4. Receipt or fair market value for all parts
    Includes vehicle purchase but not rego costs.
    Must drive to track.
    Fastest car wins.
    /zoomfeature
    So when is this going down? how long does everyone need, who is in?
    2JZ KE20 Corolla 7.97 @ 178
    SR20DET Gemini 8.70 @ 157
    1UZFET KE20 Corolla 9.60 @ 140
    http://www.oke020.com
  13. #163
    5,733
    can the original car be quick? I had a look at a moo powered gemi (hilux diff, all running) out near westlakes when me and a mate were thinking of entering mallanats (skidz an shit) advertised for 2200 but the drugfucked bogan was pretty desparate to sell, sms'd "ill take 1600 cash" after i had left. It was certainly a look at how not to live your life.
    Anyway, if an adelaidian is interested I can give them the dudes number.
  14. #164
    12,987
    finalise rules and regs first.
    im in. depending on how serious this gets, ill need a year
    id prefer it stay at $1300. makes people be more creative and search harder for bargains. i have a feeling bootloosing sales are going to go through the roof!
    zoom feature would be cool
  15. #165
    later
    Queanbeyan, Australia
    4,617
    Quote Originally Posted by SELfor50 View Post
    ALso... no need to. I know a workshop owner in Capitown with a pretty sweet 450SEL that could be got for less than $500. Engine runs fucking ace. And interiors schmick - so you could sell that for $500 which = budget for car is still $1300?? Isn't that how it works??
    Only downside is, it's on LPG....
    Details? What's the story, and if it's John's I may be in trouble since I'm there evey couple of days with stuff for him!
  16. #166
    2,646
    Yeah i'd prefer to stay at the original budget of $1300 but if it goes to $2000 gives me something to do with the cressida i have in the backyard.
  17. #167
    Opens ALLMTR's Avatar
    Newcastlish
    24,131
    Im old school so put me down for 1300. If its too hard for you, just say it Completion date should be April 1st. Moo gemini won't fit rta guidelines
  18. #168
    12,987
    would turbo'd r31's?
  19. #169
    Newcastlish
    24,131
    Yep
  20. #170
    Bush Mechanic mick.wheelz's Avatar
    Aug 2010
    Brisbane AU
    18
    I'd be keen although i have half the shit already which i guess is cheating :s
  21. #171
    Registered User Imposter Forg's Avatar
    Jun 2010
    France
    4,271
    what about a VN "floorpan with wheels" ?
  22. #172
    12,987
    Quote Originally Posted by Imposter Forg View Post
    not exactly registerable
  23. #173
    Jun 2010
    France
    4,271
    nah in the ACT it doesn't matter, if it's rego'd before just don't get defected and you can keep getting rego renewals, sp start with a rego'd one
  24. #174
    15,179
    does a moo Gemini meet the ncorp, or what ever the national guidelines are called, cause gassed250 said in his V8 sigma thread that its up to the gingerbeer in NSW, not to mention different rules in different states.
    I suggest using the Ncorp shit as part of the rules as it gives everyone equal rules, weights from wikipedia to be used.
    Make the builds public, and links receipts for parts or the car must be posted, if a part you have in stock is to be used a couple of links to similar parts are required to justify the price you are claiming for it, also ebay parts the postage must be included in the purchase price as it stops people buying a $2 part and paying $500 postage for it
  25. #175
    [DIRTY31] lysdexia's Avatar
    Apr 2005
    Bunbury
    2,435
    no, the idea is that you have to build a registerable car
  26. #176
    Newcastlish
    24,131
    The "free/already have one" thing would need to be managed somehow. If you did honestly, genuinely get the car/component for free then you shouldn't be penalised for that but . . .
  27. #177
    Jun 2010
    France
    4,271
    registerable fucks the rules up because no cool hacked together POS's will be eligible, and those are the best kinds of cars
    stuff like a 454 shoehorned into an old civic for less than $1300 etc
  28. #178
    Newcastlish
    24,131
    RTA rules would give everyone equal rules plus you could actually register it in NSW, QLD, SA and QLD (where the majority of the competitors would come from)
    Paying for postage is a bit pedantic (next you'll want fuel to the wreckers added)
    If someone really wants to cheat then that is a matter for them (and the ensuing lynch mob)
  29. #179
    Newcastlish
    24,131
    Registerablish is one of the best parts of it
  30. #180
    Jun 2010
    France
    4,271
    so pretty much a '75 volvo with a big turbo
    NCOP says no to anything with a turbo added after '75 cause of emissions
X vBulletin 4.2.5 Debug Information
  • Page Generation 0.21060 seconds
  • Memory Usage 9,127KB
  • Queries Executed 11 (?)
More Information
Template Usage (36):
  • (1)SHOWTHREAD
  • (1)ad_footer_end
  • (1)ad_footer_start
  • (1)ad_global_above_footer
  • (1)ad_global_below_navbar
  • (1)ad_global_header1
  • (1)ad_global_header2
  • (1)ad_navbar_below
  • (1)ad_showthread_firstpost_sig
  • (1)ad_showthread_firstpost_start
  • (1)ad_thread_first_post_content
  • (1)ad_thread_last_post_content
  • (9)bbcode_quote
  • (1)footer
  • (1)forumjump
  • (1)forumrules
  • (1)gobutton
  • (1)header
  • (1)headinclude
  • (1)headinclude_bottom
  • (1)im_msn
  • (30)memberaction_dropdown
  • (1)navbar
  • (4)navbar_link
  • (1)navbar_noticebit
  • (1)navbar_tabs
  • (3)option
  • (1)pagenav
  • (1)pagenav_curpage
  • (8)pagenav_pagelink
  • (1)pagenav_pagelinkrel
  • (30)postbit_legacy
  • (30)postbit_onlinestatus
  • (30)postbit_wrapper
  • (1)spacer_close
  • (1)spacer_open
Phrase Groups Available (6):
  • global
  • inlinemod
  • postbit
  • posting
  • reputationlevel
  • showthread
Included Files (28):
  • ./showthread.php
  • ./global.php
  • ./includes/class_bootstrap.php
  • ./includes/init.php
  • ./includes/class_core.php
  • ./includes/config.php
  • ./includes/functions.php
  • ./includes/functions_navigation.php
  • ./includes/class_friendly_url.php
  • ./includes/class_hook.php
  • ./includes/class_bootstrap_framework.php
  • ./vb/vb.php
  • ./vb/phrase.php
  • ./includes/functions_facebook.php
  • ./includes/functions_bigthree.php
  • ./includes/class_postbit.php
  • ./includes/class_bbcode.php
  • ./includes/functions_reputation.php
  • ./includes/functions_notice.php
  • ./packages/vbattach/attach.php
  • ./vb/types.php
  • ./vb/cache.php
  • ./vb/cache/db.php
  • ./vb/cache/observer/db.php
  • ./vb/cache/observer.php
  • ./mobiquo/smartbanner.php
  • ./mobiquo/include/classTTConnection.php
  • ./mobiquo/smartbanner/head.inc.php
Hooks Called (71):
  • init_startup
  • friendlyurl_resolve_class
  • init_startup_session_setup_start
  • database_pre_fetch_array
  • database_post_fetch_array
  • init_startup_session_setup_complete
  • global_bootstrap_init_start
  • global_bootstrap_init_complete
  • cache_permissions
  • fetch_threadinfo_query
  • fetch_threadinfo
  • fetch_foruminfo
  • load_show_variables
  • load_forum_show_variables
  • global_state_check
  • global_bootstrap_complete
  • global_start
  • style_fetch
  • global_setup_complete
  • showthread_start
  • showthread_getinfo
  • strip_bbcode
  • friendlyurl_clean_fragment
  • friendlyurl_geturl
  • forumjump
  • cache_templates
  • cache_templates_process
  • template_register_var
  • template_render_output
  • fetch_template_start
  • fetch_template_complete
  • parse_templates
  • fetch_musername
  • notices_check_start
  • notices_noticebit
  • process_templates_complete
  • friendlyurl_redirect_canonical
  • showthread_post_start
  • showthread_query_postids
  • showthread_query
  • bbcode_fetch_tags
  • bbcode_create
  • showthread_postbit_create
  • postbit_factory
  • postbit_display_start
  • bbcode_parse_start
  • postbit_imicons
  • bbcode_parse_complete_precache
  • postbit_display_complete
  • memberaction_dropdown
  • pagenav_page
  • pagenav_complete
  • forumrules
  • navbits
  • navbits_complete
  • build_navigation_data
  • build_navigation_array
  • check_navigation_permission
  • process_navigation_links_start
  • process_navigation_links_complete
  • set_navigation_menu_element
  • build_navigation_menudata
  • build_navigation_listdata
  • set_navigation_tab_main
  • set_navigation_tab_fallback
  • navigation_tab_complete
  • fb_like_button
  • showthread_complete
  • page_templates
