starting to take shape
few more
son will be putting all the clamps on and hooking the electrics back up tomorrow, and welding the diff while I go and race in a hillclimb
just need a couple of 16mm hose tails for turbo drain hose (have about 2 metres of teflon braided hose laying around that I had given to me for RC pattern aircraft exhaust joiners years ago) and fit oil feed line, then take to mates for dump pipe.
love the Silcon Implants :>)
Good luck with it matey. One of my fav's for sure![]()
there are a lot of parts laying around here for my E30 race car that I could have "borrowed" and made life easier, but that doesn't sit well with the repeatable by anyone theme of the challenge, the only exception to that is I may put the locked diff out of the race car in it for the run rather than welding the diff up in this one. not much progress is going to happen in next few weeks, have to go interstate for work, then next weekend I have to get racecar ready for following weekend, it has stuffed rear wheel bearings etc, then race following weekend, then interstate for the week, then holidays, so should have it running and ready to scare Heathcote scrutineers then
turbo oil drain plumbed up, need a different brass fitting for the oil feed, put on a brazzilion hose clamps and then it is ready to start up
Love the home-made oil drain!
Good luck getting it going.
dont blow through the airflow meter, went through this years ago with my old m10, blew the shit out of it, then spent months gluing and screwing it back together every week till i wised up.
going to need $100 worth of hose clamps the way it is going
correct, this motor only has to see the challenge out, then a 2.7 with 325i head and electrics goes in (with the turbo) note in last photo, oil filter can't be removed/replaced with manifold on, I have a 90* mount, but didn't want to add it to cost with this motor
*edit unless next challenge is lap time of race circuit, this should be most suitable if engine is still in one piece
I would have gone to the trouble of pulling the sump myself![]()
And would have had to spend money on a gasket and gasket goup!
When I did the turbo conversion on my V6 VN I took the sump off in the dirt. Drilled the hole, welded the bung and dropped it back on with a squirt of silastic. Ghetto, but safe.
It might be just alloy swarf but the first place it hits is the oil pump and it will damage the pump rotors. The oil filter collects only so much. Once it becomes clogged the oil flow is reduced.
I would have at least covered the tap in grease to catch MOST of the swarf. Then drained the oil, filled the sump with DIESEL, drain again, re-fill with correct grade oil.
You can be ghetto and still do things properly.
meh, swarf that size wont get past te oil pickup screen anyways![]()
'75 international acco fire truck!!
'70 VG sedan - current project, now 13's for $1300 project
'70 dodge yoot, current project - mothballed long term
'73 KE25 corolla - race car
'74 KE25 corolla - back on the road!
'89 BNR32 skyline - mothballed..
it can however score the alloy pump body, but IMHO the damage it will cause with that amount of debris is fuck all. I wouldn't worry either.
Your social better.
Originally Posted by seedyrom
it runs!
will have to wait until friday, dark when I leave for work, and dark when I get home, still got some messing around with air flow meter to get it running better, then get dump pipe made up and tune good enough to run at heathcote
took video with lead light providing hardly any light, but you get the idea...
Sound fair good! Need to put the motor under some load to make that turbo work!!![]()
