Page 2 of 13 FirstFirst 12345612 ... LastLast
Results 31 to 60 of 371
Thread: 13 for 1300 - Helltruck 4000
    Slanted big_pete's Avatar
    Sep 2003
    Wagga
    2,552
    I'd suggest ditching the dinkywheel diff and fit an entire commodore IRS cradle. That way you won't need a tailshaft and can move the motor and box right back. Commo IRS seems to hook up pretty well too.
    I'm with this guy
    10,168
    Go Chuck. 11s?
    10.83 @ 125
    15,613
    You really need to start attaching images to your posts rather than using fucking imageshack all the time.
    Sorry but I only have tablet access atm and it won't support uploading to PF
    I'll know more about rear suspension once I get the tray off. The rear spring mounts bolt to the chassis which is a good thing. The chassis on these are C shaped rather than box so reasonably light.
    Angry horse Mr Ed's Avatar
    9,330
    I thought they stopped doing that in the 1930s!
    "The trouble with quotes from the internet, is you can never tell if they're genuine."
    - Abraham Lincoln
    Opens HoonBoy's Avatar
    9,807
    You would be stupid to put IRS in a leaf spring car...
    Slap in a bog-warmer diff with a stock shaft as short as you can get and use that for the engine/gearbox position.
    [DIRTY31] lysdexia's Avatar
    Apr 2005
    Bunbury
    1,909
    clearly a welded stock diff with the dual wheels is the go. QUAD LEGGER!
    Registered User TK's Avatar
    Sep 2006
    5,645
    Stock diff is likely to have a short ratio = fast if it'll hook.
    I'd run the dual wheels & just soak the crap out of the tyres with tyre softener for a couple of weeks before racing.
    Dubai
    1,396
    so cool. i would run the stock diff. as tony said the ratio's should be good and you get duel wheels
    15,613
    Can I still run in the 275 class if I use 4 of them?
    Melbourne, S.E. suburbs
    840
    cool as shit project
    will you actually finish it?
    15,613
    History says no.
    Got the tray off this arvo. I'll start dummying up the drivetrain tomorrow
    Where coal meets the sea
    23,791
    i guess running the dualies and softening the tyres up is the cheapest and easiest by far, so with all things considered I say stick with the live axle. change to something else if you can't get it to hook up.
    Your social better.
    2,573
    I can vouch for the short arse diff ratios, i drive a diesel one of these to work every day
    Chuck you're a mad man
    2JZ KE20 Corolla 7.97 @ 178
    SR20DET Gemini 8.803 @ 155
    13s for $1300 FWD: 98 Hyundai Excel Current ET 16.9 @ 78 Total Cost $550
    http://www.oke020.com
    9,807
    For the pics, use the "Links to share this image" and then "Direct" so you can use it like this:
    What are you planning for fuel/spark control?
    Jun 2006
    Ararat
    2,887
    You just leave the vac line off & shift it manually.
    Chuck - a shift kit that you can fit yourself in about an hour is something like $40 - gets rid of the pesky upshifts when the trans decides the motor is revving hard enough.
    I fitted one to the t400 in the tonner in about 1.5hrs up on axle stands - piece of piss.
    or just weld the governor, make it full manual control
    Registered User 2JLUX's Avatar
    Mar 2008
    Perth Australia
    77
    $255 for a set of new slicks.
    http://cgi.ebay.com.au/Go-Kart-MG-Ye...item27b4fcf801
    I must say you have my vote for most difficult 13 for 13 build.
    Good luck with it mate.
    15,613
    Really? Seems to me it will be piss easy. Motor can be mounted back/forth/up/down with ease. No sump/steering/crossmember issues. J pipe I could knock up at home, take it out there and know it'll fit as there is nothing to hit. Dump pipe can be dead straight. Every crossmember from the cab back is rivetted in so if I want to move them forward/backward it's no problem
    Registered User Mini_Me's Avatar
    1,433
    awesome project. best of luck with it!
    Your Commo is not a Chevy 132oft's Avatar
    Jul 2010
    QommunistLanD
    794
    History says no.
    I hope to christ you get this running, fucking classic!
    Quote Originally Posted by <Paul Teutul, JR>
    The hardest thing is I'm always trying to top myself
    Adelaide, South Australia
    409
    I was also wondering why so many people were freaking out.
    If you can get it to 1000kg you won't even need the turbo, should do 13s with a reground cam.
    Radiator at the front with long hoses or back with the motor and some ducting?
    loves the Cressy
    Jul 2005
    Gympie Australia
    1,786
    History says no.
    HAHAHA you're a crack up, Chuck.
    Looks like a mad project - in a good way.
    Let me be the first to say it, just to get it out of the way.
    Finish EEEEEEETT!!!!!
    Cheers, Richard
    - Long Term Jobs
    nudder dirte30 fanboy
    Jul 2010
    Newy Braaah
    674
    definitely another one here hoping this project gets finished. I can see the benefits in your odd choice. Should perform fairly well too!
    15,613
    Started dummying everything up. Everything seems ok except the two foot long tailshaft. . .
    http://img199.imageshack.us/i/20110112154404.jpg/
    23,791
    Uploaded with ImageShack.us
    Your social better.
    23,791
    two feet is heaps. run with it
    It's not like you'll get much suspension movement in the rear with those massive springs.
    did it have a motor in it when you got it? petrol or diesel?
    Your social better.
    15,613
    Nah no motor. Was petrol.
    are hairy dogsballs's Avatar
    3,042
    take a few leafs outta the rear
    Blowjobs are like pizza - even when they're not that great they're still pretty good...
    3,042
    and cut a few coils on the front
    15,613
    Front is torsion bar
    3,042
    does it have a key to drop it then??
