Page 2 of 2 FirstFirst 12
Results 31 to 38 of 38
Thread: Torque steer - how to improve?
    12,317
    Sorry by suspension symmetrical I mean that the offsets and contact patch and scrub radius is the same side to side.
    Former hairdresser Captain_Slow's Avatar
    9,085
    It is mostly about wheel centreline vs steering axis, or the offset between the centre of force and where the virtual pivot line is, the further the steering axis is from centre of contact patch the worse it will be as it creates a torque couple on the hub, that is why the new focus with "revoknuckle" can put power down better without torque steer as the steering axis is just about in the centre of the contact patch.
    I'm not quite sure what a torque couple is but that generally makes sense, thanks. Is there any particular influence on whether it goes left or right?
    Single spinners club TMM's Avatar
    Mexico
    368
    Quote Originally Posted by Nathan_Tinkler View Post
    Yeah but when the wheels turn they are not parallel to each other (the inside wheel usually turns in harder, i think?), and different levels of camber are introduced due to body roll and castor. Someone correct me if i'm wrong.
    On a perfectly level, smooth, straight road with two perfect tyres and equal length drive shafts, you'd not get torque steer regardless of the wheel geometry. But the world isn't perfect, so one slight variation and you get torque steer.
    mang mang mang
    Jul 2009
    Inner Westside/Sydney
    1,224
    After managing to loose part of my post twice [EDIT] and having someone post in between.
    weight distribution will have some influence, as the castor/camber combination means the jacking due to turning creates different loads & moves pressure centres on tyres, if it is all really close they driveshafts/CVs will obviously have more influence. If it is actually at the point of wheel slip/traction loss side to side you obviously then have a significant unbalanced force from the side that is getting drive pulling that wheel/hub forward (assuming non perfect equal torque split from diff as even open centres have internal resistance, & not perfectly straight steering angle & contact patch will have moved relative to wheel centre due to tyre distortion, member flex etc).
    As soon as you are not 100% dead straight steering angle the combination of camber, castor, scrub & body roll (or suspension travel over road imperfections moving the wheels to different parts of the suspension stroke & thus changing the geometry & moving pressure centre of tyre on road slightly & moving the steering axis) means you have an unbalanced in the torque acting on the hub on each side of the car. So realistically most will pull both ways depending on the circumstance.
    In theory if you have 100% traction both sides, dead flat road, same driveline resistance to each wheel (obviously effected by CV angle, brake drag etc) you will have no torque steer with conventional suspension geometry.
    Or if you neutralised the usual suspension parameters (no scrub or mechanical trail) you could have one wheel on ice & one fully gripped up (obviously need an lsd or spool to deliver more torque to the wheel with grip than that created to overcome the inertia of the wheel spinning up with an open diff if you wanted to go anywhere) you would have zero torque steer. Alternative way of looking at the same thing, put enough weight in back corner of car to remove one front wheel & keep it off the deck, spool diff to get drive, normal geometry it would pull hard to the no wheel side, neutralise scrub radius & trail & it wouldn't pull on the steering at all straight or turned.
    Conventional strut or double a arm suspension designs that are cheap to make give scrub radius (some is ok, basically contrained by where it is convenient to put rotating joints in) & mechanical trail in combination with castor (very desireable, provides self centering & some weight which allows you to feel how much grip you have as well at the camber change on turning due to castor keeping appropraite tyre contact)
    TOKEN AUSSIE BOGAN tut's Avatar
    stupid sexy flanders
    6,544
    to improve torque steer, add more torque
    More rabbit less turtle!
    http://www.Tutter.net
    Registered User tinkerbell's Avatar
    3,018
    Quote Originally Posted by tut View Post
    such pure, honest beauty in your comment...
    Automotive sadist Typhoon's Avatar
    Oct 2007
    Out there
    701
    Urethane control arm/radius rod bushes help this a LOT. All these FWD passenger cars use big, soft rubber bushes.
    I changed the lower arm bushes on the TW to urethane and it cured so much shit like torque steer on uneven surfaces, tramlining etc. NVH barely went up at all.
    Life's too short to drive boring cars.
    3,018
    ^ this also reduces tramping...
