Page 2 of 5 FirstFirst 12345 LastLast
Results 31 to 60 of 135
Thread: Ls1 to Ma70 supra
    Registered User TRD-RT81's Avatar
    943
    ^^^ Winner most hideous gearbox cross member ever!
    muzzytt Mazda_DohC's Avatar
    266
    Quote Originally Posted by TRD-RT81 View Post
    not the best looking one
    97 vvti supra
    Garret GTx3076R for sale brand new
    Angry horse Mr Ed's Avatar
    9,351
    Is there a build thread on that car? Just trying to get my head around exactly what theyve done there. I cant see how they avoided cutting the stock passenger side box xmember mounting point off.
    "The trouble with quotes from the internet, is you can never tell if they're genuine."
    - Abraham Lincoln
    943
    looks to be a SHITLOAD of cutting incl firewall!
    9,351
    I really should get off my arse and roll my gearbox into my car....might do it tomorrow night and take some pics.
    Doubt it'll need any firewall mods considering an A340e fits down there piss easy and here is my T56 with the bellhousing from one.
    - Abraham Lincoln
    9,351
    Oh sorry, THEY might have to cut the firewall.....LS1/T56 bellhousing is a fuckload bigger than what Im using.
    - Abraham Lincoln
    Registered User vet 180's Avatar
    Sep 2008
    Dubai
    1,396
    Quote Originally Posted by Mr Ed View Post
    out of interest what did all the bits for the t56 cost? Obviously you have not done the clutch yet. Shouldn't be hard to get a custom unit made? Should be able to do a 6 speed supra item to suit the t56 spline?
    Quote Originally Posted by Babalouie View Post
    あなたの母親の肛門 Shifty's Avatar
    8,780
    A 6 speed 'seems' expensive but it comes with everything you need and fucking around with a t56 setup will be a similar cost to end up with something modified, other than something that was always perfect.
    PS: LS1 is narrow, but a fucking long motor.
    Fuck don't diss the blue hose here cunts get all antsy
    LS7 Prius = Proper HYBRID Walt Kowalski's Avatar
    May 2010
    Sydanee
    440
    Quote Originally Posted by Shifty View Post
    LS1 is a fucking long motor.
    Uh?
    4 cylinders long.
    9,351
    Box cost me $1,000 (fluke deal I found in the local classifieds), usually more like $1,500
    Adapter plate cost $240
    Bellhousing was sort of free (Worth maybe $50?)
    Shifter will be ~$300 from the US
    Tailshaft mods will probably be $300-500
    Crossmember will be $20 worth of steel
    Clutch/flywheel needs to be narrow to fit in the auto bellhousing, also needs to be push type so the only off-the-shelf things I could use would be a W58 package, re-splined to suit the T56. Im expecting to spend somewhere between $700-1500....will decide how much I wanna spend once I get some quotes/options.
    So fairly cheap for what you get, alot more fucking around than an R154 though.
    - Abraham Lincoln
    9,351
    V160 is spastic expensive and is still a PITA to fit. If you already had one in a JZA80, obviously keep it, but Id never bother using one in a custom install job as I dont like the V160 ratios either.
    My T56 conversion will cost about $2k+ clutch. V160 would be $1,000 more.
    Plus, if I break my T56 a rebuild is $1,800.
    - Abraham Lincoln
    Registered User rob_2JZA61's Avatar
    syd
    888
    to compare, this is what the 6spd getrag cost behind my 2jz
    - box(integrated bellhousing) + fly + used stock clutch = $3200 would usually be $3500 or more
    - custom tailshaft for ma61 (not far off what a ma70 one would be), 2 piece new centre bearing, has upgraded unis and integrated slip yoke in one section, $750 but should have been $1000 guy quoted low and wore it cause hes a champ.
    i know its an ma61 and not the same, but it required cutting tunnel only, no issue with firewall.
    ma61 + 2jz-gte + v160 + 3.5 torsen
    266
    97 vvti supra
    266
    sure there is a thread here you go Mr Ed alot of usefull info in there
    http://www.supramania.com/forums/sho...ySt-s-Build-up
    97 vvti supra
    5,727
    Quote Originally Posted by Walt Kowalski View Post
    Uh?
    4 cylinders long.
    5 Cylinders long but certainly nowhere near as long as a straight 6. Get rid of the stupid massive water pump and it's a lot shorter.
    Old cable throttle LS1, single turbo, tune, 500hp atw. It is easier to get power from a turbo LS1 than a 2JZ. Capacity does that.
    May 2010
    Sydanee
    440
    I don't understand how a V8 is 5 cylinders long. It's 4 cylinders either side of the "V".
    Are you saying it is the water pump that makes it as long as a normal 5 cylinder?
    9,351
    Quote Originally Posted by Mazda_DohC View Post
    Looks like not a bad place to start but theyre still gonna need some work on the chassis side as an A70 mount is nothing like that.
    Cheers, having a read now.
    - Abraham Lincoln
    5,727
    Because the banks are staggered.
    I'm saying that there are two types of water pump, one is a nugget, the other is less of a nugget.
    Now go and have a cup of tea and a lie down.
    943
    part number for non-nugget pump?
    266
    I've been offered a ls1 and t56 complete package with loom maffless tune for $4k. Is thus an ok price supposedly has 69000 kms. Another with auto box same k's for $3k
    Or go auto 2j 2550 ?
    97 vvti supra
    5,727
    Do you want a V8 or a 6?
    The 2J will bolt in with the right sump and engine brackets, the LS will be custom.
    The LS will be something different, the 6 will be same old same old but work, the car will still be worth fuck all with either engine. Power delivery will be quite different.
    Edit : I am so helpful.
    9,351
    I reckon as far as budgets go:
    Upto 350rwhp target = LS1
    Upto 500rwhp target = 2JZ
    Over 500rwhp target = LS1
    Apart from that, LS1 has more rumble goodness, 2JZ is easier and still pretty cool. Neither is a unique job by any means these days.
    - Abraham Lincoln
    5,727
    ^^^Agreed.
    are hairy dogsballs's Avatar
    3,035
    good deal for manualle!
    Quote Originally Posted by FatBoy View Post
    Blowjobs are like pizza - even when they're not that great they're still pretty good...
    No hybrid, No care! <---cop's Avatar
    Nov 2007
    あなたの娘
    4,615
    lolwat?
    Hater, More like 4.25 cylinders long.
    And then..... cunts outta nowhere!
    日産シルビアS13 古い学校 1809cc/131ps - RIP 1989-2013
    The worst disasters of all time;
    1: Cairns loses mobile phone and data services for three hours
    2: The Holocaust
    3: September 11
    Where coal meets the sea
    23,790
    add the block offset and the timing gear and water pump and they are a bit longer than the average 4 cyl. Still way shorter than a 7M/1/2J.
    Cool project!
    Your social better.
  27. #57
    Sep 2008
    Dubai
    1,396
    I kind of disagree with this. Well actually it depends. I agree If you are just talking engines and gearbox. But when considering all the custom crap you will need to put it into a ma70 I dont think an ls1 will be the best budget move. Also I think there will be problems with the bellhousing on the v8t56. You could maybe mount it further forward. Also might need custom headers which are serious coin.
    I guess it is a little silly talking about it as if you want a budget manual ma70 with 350rwhp would be better to use a 7mgte or 1jz with w58. Well the 7m would be hard to beat budget wise i think.
  28. #58
    9,351
    Perhaps, but really.....what kind of faggot builds a supra with a max 350rwhp target in mind?
    - Abraham Lincoln
  29. #59
    3,035
    swede from queen st?!
  30. #60
    Sep 2008
    Dubai
    1,396
    hahaha to true. Couldn't have said it better myself
