Page 5 of 11 FirstFirst 123456789 ... LastLast
Results 121 to 150 of 316
Thread: Cheapest brake rotors! Fast delivery!
  1. #121
    gslrallysport.com gslrallysport's Avatar
    Mar 2007
    475
    Quote Originally Posted by Boxer View Post
    Just wanted to give this Supplier another shout out!
    Greg and his team have fantastic product and service,
    My Cayenne needed new brakes at its last service and whilst it was on the hoist at Porsche Centre Gold coast - the dealer rang with the price for new pads. After I picked myself up off the floor, I rang Greg and he had a full set of front pads made to OEM spec complete with electronic sensors dropped into Porsche that evening for fitment the next day.
    All at one quarter the price and the performance is every bit as good as genuine
    Thanks guys!
    Cheers mate, no dramas at all!
  2. #122
    Mar 2007
    475
    Quote Originally Posted by spiller View Post
    After prices on:
    RDA slotted rear rotors for 2005-2008 WRX Sti plus shipping to SA, 5082
    Also performance friction PFC01 pads to suit CP9A evo REAR.
    Cheers
    Hi mate,
    RDA Rear slotted rotors to suit STi are $319 for the pair. Alternatively DBA Street Series are $165 per rotor (almost the same price) or 4000 Series, which will last a lot longer due to their higher carbon content and heat treatment are $231 per rotor.
    PF we don't stock, no particular reason except generally PMu is generally better and cheaper. The V8's have the choice of PFC01 or H16-03 on the front, and all bar 2 teams choose the H16-03. H16-03 to suit rear of Evo would be $465.50 for the. Or the 98% as good Club Racer I spoke about above would be $322.05 for the set.
    Any other questions just let me know!
  3. #123
    Registered User spiller's Avatar
    1,474
    Is it just the one part number for the STi rotors Greg (ie. same spec rotor for 2005-08)? I think I may have asked you this previously but i lost the email so forgive me. The only reason i was after the PFC01 was because i was given some for the front to try (mismatched car) and wanted to match the compounds. Nevetheless, the club racer seems like a good option.
  4. #124
    Registered User EDMONTY's Avatar
    Jun 2004
    penrith
    356
    price on DBA 506s rotors ,in the street series , do these come in the 2 piece rotor also?
    EL GHIA
    GT3582R
    WOLF3D
  5. #125
    MacGuyver stockymcstock's Avatar
    Sep 2004
    3,385
    Quote Originally Posted by gslrallysport View Post
    Going up from the A1RM I'd jump to Project Mu, which are the stand out leader in the absolute top end stuff right now. Choice of all bar about 2 V8 Supercar teams. I'd go the Club Racer pad, which is VERY similar to the H16-03 (V8 Supercar pad), but tempered a little differently, so no where near as expensive. To suit your GTiR would be $331.55 for the front, and $303.05 for the rear. You'd probably have to allow a month for manufacture though as I wouldn't imagine they'll be available off the shelf.
    What rotors were you running the A1RM on?
    I had the pads on vented standard size rotors - i think they are RDA but not sure. I spoke to you on the phone after i'd melted them and you mentioned that the discs had to be machined before fitment if they'd had a cheap pad on them before - incompatibility of the A1RM pad material with the thin layer of melted pad material already on the disc you suggested may have been the issue. So i got another set from you (A1RM's) and took them down to the guys are RaceBrakes here in Yarraville and spoke to Howard who reckoned that couldn't possibly have been the problem and they'd simply overheated as the rotor was too small and the car too fast. They never machine the rotors unless they're warped when fitting these pads apparently - fucked if I know!
    So I don't know what to do haha! I have a set of the A1RM's here to put on front and rear, but if they're just going to melt again on the first two laps then I don't want to waste my time. The obvious solution is a brake upgrade with a larger rotor and bigger wheels but that's an expensive upgrade for a car that only occasionally sees the track.
    Project Mu pads sound good but the price and availability doesn't. Does QFM do a higher temp pad?
    edit; I should mention the car is actually a nissan NX-R coupe, not a GTIR pulsar, but it shares the same pad/disc/caliper combo.
    I am a Spinal and Sports Physio based in Flemington, Melbourne. Insane discounts for PF members!
    www.showgroundsphysio.com.au
    I also retail do high-level professional road bike fitting and retail Speedplay pedals and SMP seats - cheapest you'll find them anywhere.
    www.neillsbikefit.com.au
  6. #126
    lonewolf
    Guest
    can do a 280mm twin piston upgrade that fits under n15 sss wheels i believe
    should be a bit of a step up...
  7. #127
    Mar 2007
    475
    In DBA rear it's the one part from 01-08 as they double drill the stud pattern. RDA there's a different number for 01-04 and 05-08.
    Yeah either or. The Club Racer should be heaps. For reference the V8's run either H16-03/PFC01 in the front, and one of the rear options is DS3000, and I'd liken Club Racer to DS3000.
  8. #128
    Mar 2007
    475
    Quote Originally Posted by EDMONTY View Post
    Hi mate,
    - Street series slotted would have to be made, allow 2-3 weeks, and $181.50 per rotor.
    - 4000 series slotted are in stock at DBA, $247.50
    - 5000 series (2 piece) were available, but currently no stock, and no ETA. Could back order if you liked and that would speed it up a little, $536.25 per rotor.
    Did you need pads, lines or fluid at all?
  9. #129
    Sep 2004
    3,385
    Quote Originally Posted by lonewolf View Post
    easy to do? which discs/caliper?
    main thing is retaining the N15 wheels!
  10. #130
    Mar 2007
    475
    Quote Originally Posted by stockymcstock View Post
    WOW... is all I can say to that. We've had numerous occasions of people fitting A1RM on rotors which had previously had TRW pads on them, and the A1RM performed pathetically... To say that changing pad materials on the same rotor doesn't affect it's performance it to not understand the very basic of the pad/rotor interaction.
    Project Mu pads sound good but the price and availability doesn't. Does QFM do a higher temp pad?o.
    QFM does, but they're not really worth it... As they're 1/2 the price of PMu, but will last 1/4 as long. Next step up would be the Comp 9 front/Comp 2 rear combo, which are $179 per set front or rear, and allow 3-4 weeks for manufacture.
  11. #131
    Sep 2004
    3,385
    Strange - hard to know what to think with this, as apparently Howard was one of the two guys who originally designed and tested the A1RM pads years ago. What I might do is take the car down, get them to machine the rotors all round and fit the A1RM's, then go do a track day and see what happens. Hopefully all is well - then we will have some more real-world insight into the problem.
    If they melt again, I'll try ordering some of the project Mu pads.
    Thanks again for the help and advice greg - appreciate it!
  12. #132
    Suspended
    mebourne
    3,406
    Do you have a distributor in Melbourne that does it trade? I'm in the industry and will be constantly buying sets of pads.
  13. #133
    Jun 2004
    penrith
    356
    yeah i'll need pads to , i'll need track pads , whats good in pads these days, currently running bendix SRT pads , not sure the part number of the calipers , there AU 2 calipers twin piston ones ,
    Hi mate,
    EL GHIA
    GT3582R
    WOLF3D
  14. #134
    lonewolf
    Guest
    twin piston caliper from fto/early evo, with 280mm rotor from clio sport
    some info on pulsar forum
  15. #135
    Mar 2007
    475
    Quote Originally Posted by snavy View Post
    Hi Snavy,
    Sorry for the really late reply. Anything urgent its always best just to call us.
    We do not currently have a physical outlet in Victoria yet but we are working on it. Depending on what it is you want to order, most of it can be over nighted from a supplier that is closest to you. If you have any other questions, please don’t hesitate to pm or call.
    Regards Matt
  16. #136
    Mar 2007
    475
    Hi Edmonty,
    We can supply the QFM A1RM pads which are good for about 780 degrees for $119 inc gst for the set.
  17. #137
    Registered User Fraud's Avatar
    Dec 2005
    1,968
    ok, I'll give it a shot
    BF Falcon ute in need of new front rotors, stock ones are ~86,000 old and shudder badly at highway speeds. Pads look to have plenty of meat in them (I think they've been replaced in the last year or so), and rears seem fine.. Gets used mostly for dragging my fat arse around but occasionally takes some gear in the back
    Fanboys on AFF all say DBA slotteds (except the tightarses who say RDA)... Will DBA street slotted rotors chew the pads that are in there? (most likely OEM replacement things) If so, what pads would you put with them? How much for both?
    Can wait for them to be shipped (Sydney) or whatever, but would ideally be invoiced before 30/6
    Quote Originally Posted by myshortyboomba View Post
    I've had many gauges in cars. I always found the conrods react faster than a gauge.
    you can always hear them when they break and they stop the engine immediately so you can't do any more damage.
  18. #138
    too old for this shit Kiahatsiu's Avatar
    Brisbane/OkTedi
    1,455
    Just bought a set of pads for my Liberty GT off these chaps. Great price and great service. A++ will stink up their shop again in the future.
    Torque sells tow cars.
    Horsepower wins horse races.
  19. #139
    Rallyist
    Queanbeyan: Canberra's Bitch
    1,541
    Quote Originally Posted by Fraud View Post
    Fraud, given how busy Greg is, probably best to give him a call. 1300 884 836
    Right now I'm eating scrambled egg. With a comb! Out of a shoe!
  20. #140
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    8,123
    Quote Originally Posted by fro View Post
    QFT- or email : sales@brakesdirect.com.au
    Greg- thanks for the pressie in the post too dude
    see you on the dark side of the moon
    1998 VT projectfckinwhooshRallyodore-unfinished shed ornament
    2006 D40 STX navara TD of 160 km/hr towing
    1986 AE82 Corolla 20valve track hack-cannot kill it with fire
  21. #141
    Mar 2007
    475
    Yep, guys just at the moment if you can call us then that's heaps better! Kinda busy with our sale at the moment.... which reminds me....
  22. #142
    Mar 2007
    475
    ### DO NOT REPLY TO THIS THREAD, WE WILL NOT HAVE TIME TO REPLY! IF YOU WANT TO TAKE ADVANTAGE OF THIS DEAL, CALL US!!! ###
    Brakes Direct and GSL RallySport EOFY Sale 2012!
    Half the year is gone, and it's that time already: The GSL RallySport (and now Brakes Direct!) end of financial year 20% off sale! Starts now, ends this FRIDAY, JUNE 29 5PM AEST!
    - To celebrate bringing Brakes Direct to the GSL RallySport group this year, brakes will be 20% off our everyday amazing prices! Whatever your requirement, Prestige to Performance, 4WD to Fleet, Trade to Commercial, and of course Competition, Brakes Direct and GSL RallySport has you covered with Australia's largest range of automotive bracking compoents!
    - Next up suspension! 20% off our entire range of suspension, from trade servicing and OEM replacement, to performance and prestige, and competition, GSL RallySport has you covered!
    - Then to wrap up the financial year it's 10% off everything else we do! So if you need race gear and apparel, sports and in car camera's, lubricants (including PM Lubricants, the ONLY Australian made oil ever to be trusted by an Indy car team!), clutches, HID kits and much more, then Friday is your day!
    For the full list of available brands and days they're on sale, scroll down!
    As always, any questions and to order, give the team a call (contact details below)!!!
    Happy New Financial Year!
    GSL RallySport and Brakes Direct Team!
    www.gslrallysport.com
    www.brakesdirect.com.au
    Contact Numbers
    GSL RallySport Australian Hotline - 1300 884 836
    Brakes Direct Australian Hotline - 1300 724 943
    Brakes Direct New Zealand Hotline - 9951 5726
    Brakes Direct NQ (07) 4422 0303
    Brakes Direct SE QLD (07) 3177 0806
    Brakes Direct NSW (02) 9191 9387
    Brakes Direct ACT (02) 6171 2025
    Brakes Direct VIC (03) 9938 8221
    Brakes Direct TAS (03) 6111 0500
    Brakes Direct SA (08) 7070 1402
    Brakes Direct WA (08) 6500 0151
  23. #143
    Forum Adnimistrator
    6,077
    A+++ Will buy again. Thanks Greg.
  24. #144
    hotel vast horizon
    8,123
    A+++ many cheers to nathan for his helpage this morning via annoying email etc.
  25. #145
    Moderator Cal's Avatar
    Brisbane, Queensland
    16,270
    I someone missed this thread completely. How much for DBA 4000 series fronts for a 95 MX5?
  26. #146
    hotel vast horizon
    8,123
    Quote Originally Posted by Cal View Post
    seriously Cal, call the boys- they are absolutely flat strap, cos of the dale and will not have time to look at this thread today.
  27. #147
    16,270
    Thanks mate, I won't waste their time. I don't need them anything like soon.
  28. #148
    Sidetracked BMWTurbo's Avatar
    Aug 2004
    3,045
    +leventy... Ordered a set of front rotors this morning.
    Rung rather than waiting on e-mail response.
    20% off = win.
  29. #149
    Registered User Gussy's Avatar
    Oct 2008
    443
    Got the A1RM's last week. A+, will smash face off windscreen again.
  30. #150
    hotel vast horizon
    8,123
    another shoutout to the boys.. & the dudes at RDA
    so RDA 750S (258 x22 ,4 stud) rotors arrived last wednesday direct from RDA warehouse. wife accepts delivery, places inside front door. Rowdy takes to shed and places on bench, thinking MMM. weekend is coming soon, will look at them then, still waiting on cheap arse calipers.
    Rowdy opens package, sunday morning, opens rotor box and notices rotors are 5 stud and biigggg... like 300x 32 mm - look at code on box, google search- Skyrine rotors.. hrmmm... no good for me...
    Email nathan at brakesdirect monday morning. He calls RDA, RDA calls me about 20 minutes later very apologetic- my rotors are on the other side of canberra, and I have the other persons rotors in a packaging stuff up. Lady with skyrine rotors hadn't opened the box yet, so she was quite thankful I did! . Couriers are arranged. tuesday morning the skyrines are gone from my possession. Corolla's arrived with me today.
    RDA guys were great to deal with, and brakesdirect were very prompt in getting the ball rolling.
