Results 1 to 3 of 3
Thread: arp bolts truetrac-motive gears
    Feb 2009
    victoria
    73
    righto cunts
    I have been supplied the wrong bolts by a dopey fuckwit salesman. I have a 9" truetrac centre and motive diff gears. The bolts i have been supplied are to long in the shank and dont hold the flange on the truetrac. they are 250-3002. anyone got a idea or what ones will suit. flange thickness is 10mm and hole depth in gears is 16mm, 7/16 thread
    thanks in advance
    1,298
    There are 2 std lengths for 9" applications; LSD and non LSD.
    You need to measure what length is required for a non OE applications and request that.
    ARP supply various 7/16" fine bolts. Ford flywheel bolts can be in the mix of possibilities. There can also be issues with the 12 point heads on some ARP bolts fouling counterbores. If you get stuck, and have head clearance to the carrier, 7/16" unbrako capscrews will work well in that application.
    Sceptic.
    Feb 2009
    victoria
    73
    got some non lsd pinion bolts and they are suitable. however for those who care arp 250-3003 will also do the job
