two quad rotor motors in parallel powering a common crank.
mirror image of each other, rotating in opposite directions.
feeding from a common plenum.
like a V8, but rotary.
would/could it work?
yes!
can you also please give us a picture of your proposed dashboard (preferably at night)
I don't know but I'll say yes in case it works.
Contact me for -
3D printing in ABS plastic.
http://www.billzilla.org
There's not enough crude oil in Saudi Arabia to power this motor
More seals than the Antarctic.
Contact me for -
how are you going to time the rotors to not break your common crank?
what forces is this thing going to generate (and is it going to break engine mounts)?
whats with the clutches?
EDIT - blue thing is the intake, but whats stopping your gears from losing their teeth when something happens?
are you just trying to make us flame you?
oh the humanity (and apex seals!)
Wouldn't the inlets have to be on the outside with a bunch of spark plugs in the middle?
no, this is a semi serious discussion. its an idea i had, it may or may not work, but if you guys can be constructive about it maybe someone who is actually able to, might be able to put one together if only out of curiosity.
I now understand this post
Picked the shit thread coming 8 hours in advance
no no no, you would have to run a e49 cop chip as a standalone charger ecu
CL valiant sedan 245 3 speed
VH dodge utility 215 3 speed, project/ trailer puller
74 chrysler lancer LA sedan, 2.6 EFI turbo, 230kw
chrysler galant sedan, daily
chrysler galant coupe- long term project
mitsubishi starion turbo, cutties, front lip, scrapes and smashes on everything
Hey could you just keep joining rotor housings together to make one really long rotary?
You'd need to make special eccentric shafts and so on.
Contact me for -
yea, i have heard about someone doing that.. i thought by keeping it relatively short, it would/could fit in the majority of engine bays.
http://mestrejoca.blogspot.com/2009/...or-jamaro.html
i found this and thought it was cool.
http://www.thesamba.com/vw/forum/vie....php?p=4389012
In english.
Nice welds!
cool thanks! but stop it you're bringing too much logic in here
I was kinda thinking something along the lines of having 4x3rotors all connected to a massive common turbo with each unit powering a hydraulic pump that powers a motor on the wheels. Awesome 4x4 rx7 drifters FE!
Contact me for -
troll I know but others may be interested. (repost prob).
'06 Mitsu Pajero DiD - Daily and Boat tow rig
HQ SS - rollin' on 14's
Google "Ariel Square Four".
Slightly less powerfull, but same concept.
I always liked the Napier Deltic.
Contact me for -
What cams would you run in these rotors?
