Results 1 to 28 of 28
Thread: Cigweld transmig 175i for home
    Registered User Dansedgli's Avatar
    3,017
    What does everyone think about these things?
    They do mig tig and arc bit look a bit like a toy compared to transmig 200's which are in the same price range.
    I want a new mig and don't know what to get. Mainly for car stuff and the odd steampipe manifold if I feel ambitious.
    It does drop down to 10 amps compared to the bigger units at 30. Is this a benefit for panelwork?
    3,017
    4,674
    I think you linked the wrong machine.
    That is the 'plant only' code.
    You want a CIGWW1005175.
    They are about a grand and are perfect for what you want to do. The 200s are more hardcore with a higher duty cycle but they are only a copper transformer and the multi process will weld heaps better (albeit at a lower duty cycle) as they are an inverter.
    We have sold heaps and get rave reviews of the multi process machine.
    8,327
    DC only? Or do they do AC too?
    I cant get no sleep...
    3,017
    That's the one muz. I was rushed posting that link. The same place does the full kit for $970. I don't think that includes the tig torch though.
    Sounds like a good thing, thanks for the reply.
    Oct 2005
    adelaide
    388
    DC only
    3,017
    That's only an issue for welding alloy isnt it?
    Am I better off getting a cheaper mig and a china tig like the blokes on here seem so fond of?
    New Zealand bro BoganDAVE's Avatar
    Dec 2004
    Powernats
    3,944
    china mig = fail because mechanical.
    Get a fema (sip) machine if you want a cheapy, either that or buy a second hand WIA off Al for cheap
    3,017
    Cool, Ill check them out. I dont really think Ill be welding much alloy anyway.
    Went and had a look at the transmig 175i at total tools and the tool shop linked above. It seemed alright, they were $970 and $995 without the tig torch. The total tools bloke reckons they are pretty good.
    Its my birthday in a few weeks so ill get one then. Turbo LS1 will ensue.
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    8,122
    Quote Originally Posted by BoganDAVE View Post
    Having had my SIP fuck out on me this week, I'd say get the transmig
    4,674
    SIP is and always will be shit.
    CIG is not necessarily the best but SIP sucks. I'd rather play ebay roulette than buy another one.
    3,017
    Hey Muz,
    In Mig form the 175i a lot better than the cigweld 135's and 150's?
    I'm thinking it might be worthwhile putting the extra $500 towards an AC tig in the future if they do the same job.
    http://www.justtools.com.au/prod6510.htm
    4,674
    No comparison. The two small machines are shite.
    3,017
    Thanks mate, I've just ordered the 175i.
    Registered User gmh265's Avatar
    Qld
    1,166
    What are they like to weld with, having no wire feed adjustment? Do they need 10A or 15A feed?
    You only need two tools in life - WD-40 and duct tape. If it doesn't move and it should, use the WD-40. If it shouldn't move and does, use the duct tape...
    Oct 2005
    adelaide
    388
    15A feed since it says 15A plug
    wire feed adjustment could probably be controled via the current control knob!!
    4,674
    Yeah they say 15a but everybody makes a dodgy 10 to 15 amp plug and they are fine.
    The current and wire feed controls are connected and there is a chart of suggestions based on wire size and thickness. They work great and once you get used to the idea of only having one dial you will love it.
    4. Amperage Control (Wirespeed)
    The amperage control knob adjusts the amount of welding current delivered by the power source. In
    MMAW (stick) and GTAW (TIG) modes, the amperage control knob directly adjusts the power inverter to
    deliver the desired level of output current. In GMAW/FCAW modes (MIG), the amperage knob adjusts the
    speed of the wire feed motor (which in turn adjusts the output current by varying the amount of MIG wire
    delivered to the welding arc). The optimum wire speed required will dependent on the type of welding
    application. The setup chart on the inside of the wire feed compartment door provides a brief summary
    of the required output settings for a basic range of MIG welding applications.
    http://thermadyne.com/IM_Uploads/DocLib_4658_0-5143.pdf
    Opens Babalouie's Avatar
    6,310
    Would something like a Lincoln 180 be worth the extra dosh over one these?
    3,017
    Started welding today. Pretty easy to setup, now I weld like a boss. Compared to my shitty arc welding anyway.
    I got mig welding gas but half tempted to get a 2nd bottle for tig playing. now I need to find something useful to make rather than welding scrap together.
    15,650
    Maybe a pair of log manifolds for an LS1. . .
    I won a $500 voucher at Toolies last week and today picked up a unimig 180 "mini mig". Have no idea if they are any good. . .
    3,017
    That's the plan.
    The ute is going back to NA today so Ill be making an exhaust for that out of the spare HSV system Ive got otherwise it will be too loud.
    Then VX rego and turbo manifold time.
    Jun 2009
    284
    I have one of these and and could not rate these high enough. Made my average welding into much better. I am in sydney if you wanted to have a go on it, gasless at the moment however
    1,945
    just got one of these lincoln 180c from gasweld for $865 delivered (melb).
    well delivered next week .
    cant wait to get going,
    ....rust never sleeps....
    hmmm sounds like an album an old hippy would put out ....
    Ipswich
    120
    I am looking to get a mig in a month or two as well, only ever owned a $100 stick welder and reading here the Cigweld 175i seems to be a goer for rust repair and other car stuff, maybe learn to do exhaust stuff? Is it overkill for a welding newb?
    Dec 2004
    Powernats
    3,944
    I reckon tig is better for most car stuff and i reckon easier for occasional welding. Tig + cheap arse gasless mig for tacking would what i would do if starting out again and on a budget. If you are going to build big shit its hard to beat mig tho.
    3,017
    I really like mine.
    Havent used the tig torch yet.
    Welded some panels up the other day using the mig. It worked good.
    Ipswich
    120
    Hmm tig/mig. Any recommendations on tigs? Are running costs similar?
    Reservoir Vic
    8
    Yeah well they're good welders the 175 but they're noisy buggers.
