Yes with VVT only on the intake cam
well if it is in retard mode normally and does advance in the lower rpm (like I think it does. Most toyota works like this) It is not going to effect max power. What it will do is somehow give more torque and power in the low rpm.
Good choice on turbo's aswell as generally the trust/copy items are a little better at low boost levels that the garret equivalent. But as you say interesting more boost doesnt help. Maybe these engines are exhaust port limited?
Be interesting to see where peak torque is made. I dont think these v12's rev too hard. Ideally you want your converter to be set at least 600rpm or so before peak torque. So if its currently making peak torque at 3800rpm its just wasted spinning up the converter instead of frying tyres.
It makes bulk torque down low, the converter just won't allow it to be measured on the dyno at full load.
I am sus that an extra couple of psi made no measured difference, that is a reasonable indicator that the auto is eating up numbers.
It needs a taller diff anyway. 3500rpm at 100 is not going to be practical and it wouldn't trap very well either as it's only 140kmh where the power falls over. I found a VK56 armada diff for $350US on ebay, the internet says you can hybrid them together easily enough.
Converter too loose?
Originally Posted by Turbo Yoda
Whatever the small probs, all a bit chubish aye?
I am at least semi-engorged.
Fuck yeah.
I reckon I could go the other way with how tall my gearbag ratios are. Except it requires finding a rare aftermarket 4.1 cw/p for the R230 that look to be about $1k a pop.
Maybe a little.
And half the traction.
Originally Posted by GSRman
Originally Posted by T0nyGTSt
Messed around a bit with the VVT this afternoon. The LH cam syncs perfectly, the RH does not. It has some crazy figure like 6323degree showing. I have a feeling that the 1JZ VVT trigger setup I am using won't accept a second cam to control. Waiting for a call back from mark on it.
I may be able to use a xGR V6 trigger instead as it will have dual VVT. Can't find any info on what crank trigger it uses as yet though.
FOund this on motec forums re 2GRFE.
The cam sensors are hall output mag sensors. They use an IC within to change the mag output to hall. The input to the sensors are 5V and so is the output. The crank is a mag sensor (36 minus 2).
Could be suitable, the crank trigger is correct and assuming it uses 120degree cam lobes could work.
I don't know if you can just choose 36-2 crank and then just configure your own VVT settings.
what are 3.7 out of, is that 19th of this month
twin v12 powerplay?
Cheers, Richard
MX83 Cressida Grande - 1JZ-GTE Twin Turbo JZX81 Motor, Fr Suspension in, tailshaft made & installed, bigger fuel pump in, zorst, wiring, fmic done (thanks jzk25)BA rotors R33 Calipers Now REGISTERED going well
'66 Jaguar S-Type 3.8 Auto Sedan - Long Term Jobs
Righto, I now know a fuckload more about Vipecs and VVt.
Fucked around with it and no matter what the RH cam would not sync. Found out how to do the calibrate shit which all worked fine but still no sync. Ended up changing the VVT mode to 1GRFE and it synced up straight away. Then checked the spark delay which was 4degrees at 5k rpm so adjusted the delay figure to 125(microseconds?) and it's nice and stable.
Time to go back on the dyno. I have JasonP's VVT map for a 2JZ VVT but if any gurus(Dale) want to give tips it would be appreciated.
this is what i like about the work you do Al... every time there in an issue you dont just give up and tell the customer... dunno how to fix... you keep playing with it until it works again...
1993 Xtra Cab 1uzfte
Project Poo Cart
http://www.performanceforums.com/for...php?t=67225961
www.millerchassis.com
Ps, hey al what tractive effort did my shitta make on that dyno?
Project Poo Cart
Project Poo Cart
