Page 1 of 3 123 LastLast
Results 1 to 30 of 66
Thread: DC electric water pump. Use DC controller or control with V88 ECU?
    Sunshine Coast, Qld.
    5,741
    I am using an EWP115 on Crackas V12 shitter. The EWP and Fan controller looks like a good thing but I don't want to bother with it if the ECU can do the same functions easily.
    Opinions?
    Registered User Rz's Avatar
    4,668
    i had a ewp and fan controller last all of 5 minutes , so i changed it to a solid state relay run by a ecu.
    4,668
    actually the only thing the davies craig thing did was pulsed the water on/off until it was up to temp , whereas with the ecu i just have it run at different speeds.
    5,741
    What is this relay you speak of? That's what I want to do, run it at different speeds. I was thinking of using a fuel pump controller but something simpler would be good.
    4,668
    jaycar have them. your keeping the thermostat right ? cos without one i cannot run the ewp slow enough to keep water temp on a cold night. something i suspect the davies craig may be able to do.
    2,874
    Quote Originally Posted by Rz View Post
    Are you sure? I seem to recall that it pulses at 3v or something like that at cold temperatures, then increases the frequency until the engine reaches temperature. Once the engine reaches operating temperature, it starts to ramp up the voltage.
    The controller I had on the mr2 (older style screw adjustable) was awesome, it hit normal temperature by the end of the driveway then never moved again.
    5,741
    Not having a thermostat, there wasn't one on the engine or a housing, part of the reason to go electric.
    Are the alloy housing pumps better than plastic?
    4,668
    nah it distinctly had on/off at 6v , then ramped straight to 12v continous (like you say) once you hit the 85 or 95c presets.
    they do have a pdf on the website that outlines its operation. i was so furious after it shit itself i just threw the cunt in the bin.
    4,668
    hmm ok , no thermostat is a bit of a cunt. has been on my 2j anyway.
    meziere do make a sweet all-alloy-no plastic shit 55gpm pump with a built in thermostat , id go that route over pump controllers and crap if i did it again.
    4,668
    actually you can get me on 0421 878 092 if you want any more dribble on the subject.
    Feb 2010
    sydney, canada bay, australia
    541
    I run one of these through my m800. It has a 3d table that lets it run just like there is a thermostat in the cooling system(i dont use/have a thermsostat).
    Basically when cold it cycles very slowly and as it warms up it gets faster. When it reaches a certain temp it runs flat out or close too it.
    13,681
    Yep that's how I set them up on the Haltech too, Bernie's rx7 runs it like that, 15% duty at 20deg and 100% at 85deg and it works perfectly,
    Jaycar solid states are shit and I would reccomend you spend a little more and get one from moech or Haltech..
    Jul 2006
    483
    Is there a way to tell if the pump stops working (I.E. Seized/blown fuse etc)? Do they have a flow sensor in them or do you just alarm/shutdown on a high coolant temperature?
    Feb 2010
    541
    If you are running a pdm you can configure it to send a warning to your adl if the pump seizes(high current draw/ circuit overload) and pop a warning light so you can read the warning message displayed.
    13,681
    Quote Originally Posted by garvice
    With our spending $4000 on a pdm setup you can use the good old water temp gauge!
    Apr 2003
    310
    Quote Originally Posted by garvice View Post
    Put a dash light tapped into the pump power - I will be doing this in the new year on a comp truck - no time to watch the temp gauge while picking lines.
    Sup Kyle's Avatar
    Apr 2004
    Muswellbrook
    4,733
    Better way is to fit up a flow switch I reckon?
    Feb 2010
    541
    You could also do that.
    4,668
    the one jaycar sells is the same one on the haltech website.
    5,741
    How does this solid state relay work? Is it a relay that can do PWM voltage control?
    13,681
    nah they are not... trust me.. the jaycar ones dont work properly with the ecu... tried them on bernies car and threw 2 of them in the bin...
    13,681
    put as low current PWM input in and it will output a high current PWM output..
    ie you can run like 20 injectors or a water pump etc off a low output PWM driver..
    4,668
    hmm fuck , well ill keep that in mind.
    it was good when i dynoed the car , but havent driven it a whole lot since.
    13,681
    they work flat out and thats it.. no speed control from memory...
    13,681
    does yours have a red light on it??
    4,668
    no light but its got the exact same markings and part numbers on it as the haltech one.
    had no trouble running the pump at varied speed via the autronic.
    matty did put a diode across two of the terminals though , to stop back "EMT" or something ?
    13,681
    ok your jaycar must have different stock to my jaycar.. the ones we had had red lights on them..
    you need the resistor across it to stop them holding the pump on flat out when you turn the key off
    13,681
    ok found it
    the SY4084 is the only ones jaycar used to sell,
    they now have the SY4086 which is the right one..
    Resident Leftie UZZ31's Avatar
    Sep 2007
    2,819
    Where is the Haltech one on their site, i cant see it?
    Need one to drive water injection pump as the Adaptronic PWM outputs arent rated high enough current
    [edit] nm will just get that Jaycar one ^
    1994 V8 Soarer
    1991 V8 Soarer
    The 5k project track hack
    Interested bystander
    348
    ok found it
    He he, you're getting AC/DC mixed up there Dale. Jaycar sell both and the 4084 is for switching AC, it wouldn't have worked well with DC.
