Results 31 to 60 of 101
Thread: Twin Turbo MFI 2JZ Altered - Unda Presha Racing
    Dont know nothing UndaPresha's Avatar
    36
    Got the intake manifold cleaned up and tighten in place. Need to order a few fittings this week to finish off the port fuel lines. Fuel tank cleaned out ready for a tank for of methanol. Turned over the motor to prime the oil pump and filter. Made a couple of adjustments to the nose cone to get it to fit.
    Going EE/AA racing...
    MFI Twin turbo'd 2JZ Altered
    http://www.undapresharacing.com/
    https://www.facebook.com/undapresharacing
    1,102
    This makes me feel nice. Is it 1mm oversize so 3.1 litre?
    36
    Quote Originally Posted by oliveoyl View Post
    To be honest I couldnt tell you. I never removed the head. Only check bearing wear after I brought the motor.
    36
    Had another big day working on the car. Finished making all the port fuel lines, tighten both turbos and fittings, fitted the intake pipe work. Pretty much just need to add fuel, some water and give it some ignition. Hopefully I get the chance this week to fire it up
    5,261
    3067cc
    The letter g Sucker's Avatar
    Apr 2007
    Somewhere in Straya
    3,277
    Looking good.
    Rides-
    1984 toyota coaster bus
    2009 mitsubishi evo x mr
    wtd-
    vr,vs or vu ute. The cheaper the better, pm me.
    36
    Spent a few hours over the weekend paint stripping the steering arms, brake arm and cam covers back to bare metal. This only leaves the chassis, diff housing and wheelie bar to be sand blastered. Once these are done and look good to leave bare, I think I will leave them that way.
    36
    Been pretty quiet lately. Cash is always a good indicator on how much work you can get done. Got the chassis, wheelie bars and diff housing sand blastered recently. Started sanding back and steel wool the steel work today on the wheelie bars and diff housing. Got the wheelie bar done and finished. Started putting the diff housing back together, just need a couple of new "O" rings and it also should be finished.
    Hopefully start the chassis next weekend
    36
    Chassis now ready for assembly
    New shifter and transbrake button fitted
    New Wilwood brake master cylinder
    New tread fitted
    Queensland Performance Automatics Powerglide - http://www.qldperformanceautomatics.com.au/
    Mar 2011
    Mooloolaba
    27
    Looking good. What bellhousing are you using?
    36
    Thanks. Not real sure as I brought it with the motor but I think its a Dellows if my memory serves me right.
    Registered User Brad88's Avatar
    Oct 2008
    42
    this is very fucking cool
    36
    Had a great weekend working on the car. Dont get to do much on it at the moment (might have something to do with no money lol) but I got to spend a few hours each day over the three days off. Managed to accomplish some jobs and put back in the Qld Performance Automatic Powerglide, shifter with datalogger and AMS1000, run the wiring, fuel line, install the EGT temp into the gearbox sump and change over the transbrake / gear shifter buttons on the steering wheel.
    Now just need a diff centre (currently with Ray at Western Suburbs Diff) and a rebuilt motor and than I am off racing. Well only if it was that easy
    36
    The motor has been rebuilt and now back in place. The journey begins to piece it back together. Hopefully wont be too long we hit the track.
    747
    Looks absolutely mental. What kind of power will this thing be putting out? With the hardware its got looks like 1000hp+?
    Apr 2003
    Roleystone
    2,202
    Will be interesting to see if you get anywhere near the boost your after with those GM coils, Id save your self much pain and upgrade to a good CDI and 6 quality coils now.What is seen in the pics is a budget road setup sorry. Good luck with the project.
    36
    As the motor is a distributorless motor and I have chosen to go with mechanical fuel injection, the ignition is from Electromotive Engine Controls. Changing the coils aren't an option with this ignition. I am only chasing about 1200HP on about 40psi once tuned. Since I'm not chasing high boost the ignition should be ok. If not, I will set up and run a belt drive distributor off the cam shaft with a MSD Digi ignition. I dont like to follow others so no EFI.
    Apr 2003
    Roleystone
    2,202
    Ive had problems with the GM coils by 600hp, Just trying to help as Ive done this many times before. Methanol and boost really need a lot of Spark.
    36
    That's cool. I'll give this a go and go from there.
    13,678
    No chance if those coils doing the job,, just swap em out for 6 ls1 coils..
    Registered User prasac's Avatar
    Dec 2009
    Little Sudan
    1,039
    we tried the LS coils in the brother's 2JZ KE70 setup a couple years ago, it didn't like it too much around 36psi (1200hp) E85 EFI it had a 2ms dwell time which we think it couldn't produce enough spark, it was blowing spark out around mid track when it hit full boost. just went back to the M&W CDI and coils and it was fine.
    you might have better luck.
    Apr 2003
    Roleystone
    2,202
    LS coils need 4+ dwell time. I use them often.
    13,678
    i have used them on twin turbo ski boats making 1700hp for a hour at a time and have no spark problems,
    even my car had no spark problems at 36psi and fuck knows how much power..
    5ms is the magic number
    4,672
    I hope Mr Presha realises that he is getting free advice from two of the best in the business.
    No 1gz no care Cracka's Avatar
    Laying 11's
    3,474
    What's something like this going to run, ballpark times?
    4,672
    Would be mid sevens at 170 ish with 1200 at a guess.
    Apr 2003
    Roleystone
    2,202
    SR20 powered rail in WA is close to 7s with about 450rwhp, Slicks and Converter dont give a clear reading on the Dyno tho.
    Apr 2007
    Somewhere in Straya
    3,277
    Would think low 7s high 6s with a bit of development and track time?
    Laying 11's
    3,474
    Faaaaaaasaark
