Results 1 to 8 of 8
Thread: Basic stuff, workshop workbench
    Registered User Glenno's Avatar
    Hiding
    6,043
    Got started on this today.
    Frame is 40x40x2 and 25x50x2 Top is folded 1.6mm galv with 15mm CD ply underneath. One side is setup for sitting at hence the missing bar. Splashback is 150x50x2 galv
    Works out to be around 1017mm high, 2400mm long and 750mm deep
    Tacked togethor and ready to check for square before welding everything. Then it needs a few bits added like the bars that go underneath the ply to support it and some stuff for shelves and a drawer.
    www.DRIVENFX.com Performance Engine Building, Auto Electrical (Wiring Looms, ECU Installs, Diganoses and Repair), Custom Automotive Electronics, Car Preparation, Car Setup, Trackside Services,
    PM me for more info
    419
    Heh, I put something sort of similar together in December to try to teach myself to weld.
    I only used 4 uprights but used 40x40x3 and used a sheet of 6mm steel bolted to the top rather than the ply and gal.
    Then I got lazy and only got around to getting a bit of chipboard for the bottom shelf last weekend so it should finally be together this weekend.
    The welding is pretty ugly but I'm kind of pleased with myself for a first try, it's definitely structurally sound.
    Hiding
    6,043
    Got the main structure finished today, bench top riveted and glued down, loaded up the top with weight so it can set overnight. Will bolt the vice on in the morning and dynabolt it to the floor and its ready to use for now. Will finish the shelves and drawers after I use it to finish a few jobs.
    PM me for more info
    419
    Any reason you are bolting it down?
    496
    Bench looks good, but now that it has a bunch of gear on the top it will never be usable again.
    Hiding
    6,043
    Mister black bolting it down so the bench won't move when you lean on stuff in the vice, will probably just put 2 dynabolts on opposite corners.
    Garvice I see you are familar with the primary purpose of workbenches.
    PM me for more info
    419
    Quote Originally Posted by Glenno View Post
    Thought so, I'm hoping my 100kg steel benchtop provides enough weight that I don't need to. We'll see how I go I guess.
    Thanks.
    Hiding
    6,043
    Done for now, shelves and drawers to come at a later date, need to use it to make some money for now.
    PM me for more info
