Results 1 to 18 of 18
Thread: Best method to extend a caravan drawbar
    Registered User TurboRA28's Avatar
    806
    Howdy, we've got an old 70s viscount caravan that has a stupidly short drawbar. i would like to extend so can mount some pushbikes on it. so not much weight 25kg extra or so.
    Trying to work out best method.
    either cut existing one off completely and use new 50x100 rhs.
    Build a new one kinda alongside the existing one welding along the length of it but as it gets longer the angles etc Will create a gap at some point between new and existing so couldn't weld entire length.
    Or i could use some C shape metal and weld it onto the existing bar wrapping around it kinda.
    Might need pictures to help those ideas make sense.
    Ideas?
    Registered User Glenno's Avatar
    Hiding
    6,043
    Cut the old one off and replace it.
    www.DRIVENFX.com Performance Engine Building, Auto Electrical (Wiring Looms, ECU Installs, Diganoses and Repair), Custom Automotive Electronics, Car Preparation, Car Setup, Trackside Services,
    PM me for more info
    Loving teh titties.. carcrazy's Avatar
    2,607
    Longer drawbar?
    Quote Originally Posted by Einstein
    The definition of insanity is repeating the same action and expecting a different result
    Registered User Momus's Avatar
    1,316
    Photo would help here..
    I need more cylinders! nine2nine's Avatar
    Gympie, QLD
    1,160
    Cut it off, and weld on new one. The only way it wont look really bad, and probably the easiest way too.
    Projects:
    '90 2jz-gte 929
    '02 twin-locked TD42 GU Patrol
    806
    Will get some photos to confirm plans.. What is the usual wall thickness in 50x100 for a drawbar these days?
    806
    1,316
    Fuckin short all right, would be a cunt for jack knifing on turns..
    OK, drawbar weight should be only around 100 Kg max so a massive structure is not required.
    Prime coated rhs is 350 Mpa minimum which is handily strong. I'd go for 3 mm wall in that 100 x 50 section.
    As far as extending it goes you could look at letting a suitable piece of 100 x 100 x 3 in between the apex of the two legs of the 'A'.
    The hitch should fit that and be secure if you crush tube the mounting holes.
    Here, tomorrow I'll be There
    944
    Check what your drawbar weight is by sitting an axle stand on a bathroom scale. Some caravans have stupidly high drawbar weights to compensate for other design flaws and stop them getting the arse wobbles when they're towed.
    If it's already heavy adding gear to the front will make it worse, better to put the bikes on the back
    No 1gz no care Cracka's Avatar
    Laying 11's
    3,536
    Cut the cuts out of the existing towbsll mount. Weld length of 100x100 in and gusset appropriately to existing bar angle. Weld new hitch into top of 100x100. Will look like a 'A'with an 'I'in the middle and out the top.
    Member of PF v12 club incTM
    806
    Like this? Red being new bit.
    806
    Or like this but not as long and with it extended back more..
    Forum Adnimistrator
    6,200
    Like the MS paint mockup. Probably doesnt even need to extend further than the start of the van. Did it to bosses caravan years ago. Cracka
    Quote Originally Posted by brasher View Post
    go home helicopter, you're drunk.
    806
    So the forces on the extension are only up/down for the weight of the van.. as the towball swivels around anyway so cant be much side to side force on it. ?
    Registered User Dave75's Avatar
    Feb 2009
    town & country-adelaide SA
    2,567
    10% of the van/trailer weight is the usual accepted tongue weight.... 1500.kg trailer=150kg tongue weight.& van loaded properly is more important.
    RIP ROOKIE IPRASA #33
    2 June 2012
    806
    Hey what thickness wall in the 100x100 do you reckon? I was going 4mm but think it might be bit heavy/overkill.. Would 3mm suffice?
    Edit.. everyone already told me 3mm.. So 3mm?
    806
    Hey all, decided the 100x100 through the guts isn't going to work as it will get in the way of the hitch cable brake system and don't really want to go electric brakes.
    So i'm thinking i'll cut the existing one off and start again.
    50x100x4mm with some flat bar or angle for gussets where possible and just try and replicate where it was tied in to the chassis before.
    It seems there isn't a whole lot of areas to weld an a-frame to the chassis as it only crosses such a small section.
    Any other tips?
    Where it all joins at the front, seems they put a thick arse plate over the top and bolt the hitch to that?
    806
    My easter break...
