Results 1 to 13 of 13
Thread: Land Rover Discovery 300TDI
    Radelaide
    3,458
    Heres my new bus, I bought it from my dad with a suspect BHG and flogged suspension.
    Abit of money and time later and it now has:
    -New design cylinder head with MLS gasket
    -New hoses/belts/fluids
    -Unblocked Radiator
    -Upgrade timing belt kit (how LR let engines out of the factory with the setup they had is beyond me)
    -Silicon turbo hoses (not in the country yet)
    Suspension/body wise:
    -2in Ironman lift kit (cheap)
    -All suspension bushes replaced apart from rear A link - will do this along with the upper ball joint later.
    -new steering damper
    -new steering rod ends
    -oem size BFG AT's
    -somesort of ARB looking bull bar, cheap off gumtree
    Driven it to work this week and it has gone well, will need atleast one of the diffs rebuilt as there is abit of slack in the drivtrain (280000kms) might do a locker of somesort at the same time.
    In the future ill give it abit more go with a center muffler removal, boost and fuel tweak (fitting egt, boost and water gauges) and I want to try water injection. I have a spare set of steels that will recieve 265/75/16 buckshots or something cheap. Other stuff like lights/radio/tints will happen when i can be bothered.
    Cheers,
    Jeff
    Tow car/daily: 2011 D40 Navara ST 6sp diesel.
    In the build: U2L IPRA Honda Integra
    Distraction from the above: KE20 13B
    Where coal meets the sea
    23,795
    Good stuff looks same year and setup as mine.
    645
    Replace that coolant reservoir (they split along the seam) and fit a low coolant sensor as well. Otherwise all your hard work will come undone.
    Check out AULRO.com for loads of info and many Land Rover nutters.
    Registered User Dave75's Avatar
    Feb 2009
    town & country-adelaide SA
    2,536
    Famous last words... the Disco is 17 years old/280000kms... the coolant tank hasn't split yet.
    RIP ROOKIE IPRASA #33
    2 June 2012
    Radelaide
    3,458
    Ill replace it just cause its still got mud and shit in it from the old cooling system, and also because everyone on AULRO.com says so
    Clubman CXTdreamer's Avatar
    3,925
    What sort of money would a setup like this cost buying through carsales?
    WWPBD
    Quote Originally Posted by InsaneAsylum View Post
    first time i was in sydney, i asked the cabbie to tell a bit about the place. he said "this here oxford st, you see 2 man, they are poofter"
    Fuckwits Incorporated
    Feb 2009
    2,536
    $5000--$6000 maximum
    Jeff's has only done 280000 in 17 years [ we have had it 13+ years ]...was originally a Demonstration vehicle in WA so probably did 10 Canning Stock Route trips before I got it.
    Only ever had new clutch,rear crank seal, 2 heads, but as Jeff said rear diff needs attention.
    For a 2.5litre TDi @ 2.3 tonnes, they do a good job.
    AC needs regas. heater core needs replacing...full dash out to do job...$700..$800 labour
    2 June 2012
    744
    Quote Originally Posted by Dave75 View Post
    Read fucking slow.
    I have had a couple of disco's/rangies.
    If you are looking for one you are better spending the extra coin on a well maintained one than one that has been neglected
    As gutless as the 300tdi is, they are a good little engine if you don't let them get hot and change the timing belt regularly.
    Just don't be in a hurry to get anywhere
    Ban low performance drivers not high performance cars
    Radelaide
    3,458
    They are definately an enthusiasts car, but I think they are a rewarding drive when working
    Its fast enough for a daily, I've got the bike if I'm late for work.
    Ive got a few parts/ideas lined up to make it abit more capable in a few months time
    Feb 2009
    2,536
    Quote Originally Posted by turbo510 View Post
    Read fucking slow.
    Speed limit is 110
    2 June 2012
    pissed off irsa76's Avatar
    2,405
    If you think the TDI is slow, try the 2.0 MPI!
    744
    Speed limit is 110
    Yes, in some areas it is.
    I just like to be able to pull out and accelerate to overtake when you are stuck behind someone doing 10kmh under the limit.
    A 300tdi struggles with that unless you get a really long run up and has very little chance of overtaking anything while towing.
    They are definitely a rewarding car when working, my 300tdi Rangie had lockers, 75mm lift and 32's. An exhaust and some extra boost helped but it was still painful doing long distances on single lane roads. Not many overtaking lanes are long enough for a 300tdi but on dual lane highway's it was bearable.
    Interestingly it actually performed better with the taller tyres on it and fuel economy stayed pretty much the same.
    Radelaide
    3,458
    Its fine on the HWY, just drive it like its powered by a rubberband - wind it up for long enough and you might make the gap
