Results 1 to 30 of 30
Thread: Show us your DIY tools, workshop equipment.
    piss taker of the piss Uncle Arthur's Avatar
    10,985
    Might be an idea to keep all this stuff together so it's all currently accessible? Anyway here is my modest contribution, a home made wheel lifter for those awkward big wide wheels. Made from a kids bike fork and office chair caster wheels. Place the wheel on top, position it, line the wheel stud holes up and roll the wheel on.
Name:	wheel lifter 001.JPG
    Nov 2006
    Wallsend/NSW/Australia
    404
    Home-made flycutting tool for pistons - the valve head has a bit of tool steel welded on and shaped into a cutter, set the adjustable stop on the valve stem to the correct height, attach an electric drill and away you go..
    Jig for cutting and shutting a Datto L-series bellhousing onto a Nissan S15 6 speed gearbox. Jig holds the S15 bit of the bellhousing in place, L-series bit bolts to the back of spare block. It would work for any gearbox conversion - the jig locates in the main bearings of a spare block, and in the input shaft bearing hole in the bellhousing, with a flange perfectly square to the centreline of the jig bolted up to the bellhousing. This all ensures that he bellhousing is both square to, and inl ine with, the crank.
    WTFaaark ChrisS's Avatar
    ACT, Australia
    3,678
    dave1600, Both are damn clever!!
    Do you have a pig of the cutter?
    I wouldn't respect her restraining order
    1934 Reo Hot Rod build
    1975 TX Gemini track car (EX RRS Rally car)
    1932 Ford (Unfinished, on hold)
    MY93 Subaru Legacy Wagon GT Twin Turbo
    Visit RacingReady.com.au for information on upcoming motorsport events and show!
    Tastes like victory EVOSTi's Avatar
    Copenhagen
    2,144
    Nice work Dave1600.
    I have a box full of spanners heated and bent with an oxy, does that count?
    Nov 2006
    404
    Flycutter wasn't my idea - a fellow Datsun owner used something similar, I just modified it a little.
    I can get a picture of the cutter, but its basically just a bit of tool steel about 3mm square and 10mm long, cut off a lathe tool with an angle grinder, brazed onto the underside of the valve head with a few mm hanging over, then sharpened to a cutting face on the bench grinder.
    Mar 2006
    Not Mt Druitt
    492
    I'll steal a few from the metal shaping forums
    435
    Quote Originally Posted by ChrisS View Post
    I have seen similar but they cut grooves like teeth into the head of the valve to make the cutter.
    Oct 2005
    adelaide
    388
    Balancer puller, made it out of some P20 tool steel, running a M20 thread in the middle,
    Registered User 2JLUX's Avatar
    Mar 2008
    Perth Australia
    77
    Simple yet very effective
    Height adjustable with built in tig torch holder.
    May 2010
    Shoalhaven
    1,418
    ghetto spec stud mount valve spring compressor, had to macgyver this up one night after finding out i had lent my other one to some cunt that dont like to return tools
    This beast turned out to be easier to use than the proper one
    diff housing jig
    2013 Focus ST
    TE Cortina, 250 c4 9" n2o
    GH Sigma EFI 351
    1978 Ford Transit Sundowner, 100 spoke wheels
    512ci BBF PG and 9" under construction
    Oct 2005
    adelaide
    388
    this is to hold the yok on a BW diff when torquing up the nut on the end of the pinion gear shaft.
    Oct 2005
    adelaide
    388
    Quick Cam shaft instalation tool i made today.
    Mar 2011
    Quindanning WA
    89
    my ghetto line boring rig... cost me $100 for some bright shaft and bearings vs $400 a machine shop wanted to put it on the horizontal boring machine or $2k a mobile line borer wanted.
    Oct 2005
    adelaide
    388
    Quote Originally Posted by kneelo View Post
    Love seeing this sort of stuff.
    similar sorta set up to this guy.
    http://www.youtube.com/watch?v=cl_kXgxS6Fk&feature=plcp
    Kangaroo flat!
    6,415
    had to make a vice at trade school this week.
    not as cool as alot of the other creations here, but it does the job
    Quote Originally Posted by Sathanas View Post
    Ballarat is as fun as putting my nads into that press
    Quote Originally Posted by Russell View Post
    Ballarat people are generally mongs who need twice as long to do the simplest of tasks.
    You know you're a real shit cunt when jmac starts ragging on you too.
    '73 KE25 corolla - race car
    Jul 2006
    483
    Was sick of tripping over my mig and having to carry the bottle around. Cheap bunnings trolley and some scrap metal I had laying around.
    RNJ Fabrication
    cedar vale
    2,066
    Had an old dishwasher lying around. Wanted a sand blaster.
    So far cot is nill. But I need to buy gloves and screen and light. Already have a portable sandblasting kit I'll be using inside.
    RNJ Fab.
    milling, machining, turning, welding, design.
    ACT, Australia
    3,678
    Nice effort guys
    RNJ Fabrication
    cedar vale
    2,066
    Started with this
    Cut and made holes
    Ended up with a end sand blasting unit.
    Also
    Small tool for the lathe.
    That's all for now
    RNJ Fab.
    ODF
    2,016
    I have a few ill take some picks just hand tools.
    Nov 2006
    404
    Quote Originally Posted by SLO78U View Post
    OK, I'm intrigued. What is it ?
    947
    Quote Originally Posted by dave1600 View Post
    looks like he is machining brake discs or something to that effect
    "1000 safari suits and matching blunderbuss, along with a 1:56 scale diorama of a porn movie set" was what I originally figured you were hiding, but I'm guessing it's probably an E30.
    RNJ Fabrication
    cedar vale
    2,066
    Quote Originally Posted by PHULL View Post
    Bingo.
    Allows you to turn both sides parallel. You skim one side with the tool then change tools to skim the other side.
    In the past I have just turned the disk around and then used the dial gauge to get it parallel. Time consuming but effective. It's little jigga saves me heaps of time.
    RNJ Fab.
    5,416
    Made this tiny vice.
    KEEP CALM.
    Nov 2006
    404
    Ahh, vey good.
    Oct 2012
    cental coast australia
    40
    Good work man! That's pretty good! What were you line boring? We use sub zero at work and they do great work but priced accordingly!
    Mar 2011
    Quindanning WA
    89
    Quote Originally Posted by kyle_b View Post
    Its a top mount attachment to fit a rock breaker to an excavator.
    Suspended
    mebourne
    3,406
    Bingo.
    Shit I've machine heaps of rotors and prob can do it with my eyes closed but I have no clue how that little jig works!
    ODF
    2,016
    Quote Originally Posted by snavy View Post
    It appears you machine one side then undo the lock swing the jig around and machine the other side of the rotor.
    Jul 2007
    Newcastle
    67
    Bingo.
    A mate has a nice little tool with both a left and right cutter and a dial to set the distance between them - it does both sides at once.
