Results 1 to 24 of 24
Thread: Daily: misfire (pic of plugs shows which cyl)
    あなたの母親の肛門 Shifty's Avatar
    8,785
    hey guys
    i have a 4cyl TE magna as a shitter. it's a single cam 4G thing.
    anyway it's developed a misfire, none of the plugs looked any different so i put in a new set and took it for a drive for 20 mins & this was the result.
    Any insights into general condition (plugs 1-3) and most particularly the reason that cyl 4 looks different.. fair to say that it's the one misfiring although i suppose it could always be all three of the other cylinders, just intermittently.
    a little rough on idle & off idle, very light load (eg. take off down hill) it's fine but taking off on a flat bit or uphill, or any real load, it misses. high rpm free-rev it seems to clear out.
    Registered User Peter UC's Avatar
    Eastern subs Melbourne
    115
    I would first be looking at leads, distributor cap or rotor button. Had a similar problem on my old 626 turned out to be the leads
    blinks ... Billzilla's Avatar
    Jan 1970
    21,353
    Pots 1 -3 are too lean.
    #4 looks okay.
    Contact me for -
    3D printing in ABS plastic.
    http://www.billzilla.org
    8,785
    Is there a consensus on that being the case?
    Might grab a fuel filter and see if there's any improvement..
    Feb 2012
    Newcastle
    28
    Yeah the white deposits look lean. Does the fuel come into the rail at the #4 end? This might explain the 1 neutral looking plug. The filter makes sense as does the pump but its more expensive / difficult to replace.
    8,785
    Yeah that's what I was thinking, the rail inlet is at #4 cyl... hopefully just filter.....
    749
    So it has a miss on idle? Have you tried narrowing down which cylinder isnt firing properly? Check the leads, cap and rotor like others have said. Changing fuel filter may help but its rare to have a missfire unless its completely blocked.
    Kangaroo flat!
    6,418
    #4 looks okay.
    quite often you will get that result if a cylinder is missfiring, because the misfiring cylinder will be throwing fuel into the exhaust. the oxys think the engines running rich, so the computer leans out all cylinders, hence 1-3 look lean.
    Quote Originally Posted by Sathanas View Post
    Ballarat is as fun as putting my nads into that press
    Quote Originally Posted by Russell View Post
    Ballarat people are generally mongs who need twice as long to do the simplest of tasks.
    You know you're a real shit cunt when jmac starts ragging on you too.
    '73 KE25 corolla - race car
    8,785
    Ok well it has a new fuel filter.
    No improvement.
    Kangaroo flat!
    6,418
    like someone else said. check cap, rotor, leads etc. swap plugs in cylinders to see if the problem follows the plug or stays with the cylinder. do a comp test.
    are hairy dogsballs's Avatar
    3,056
    my vz does this (if the cunt runs). i had shit leads even though the resistance read ok.
    Blowjobs are like pizza - even when they're not that great they're still pretty good...
    Real life axe man JohnMcSandyVag's Avatar
    1,100
    #4 looks okay.
    x2
    White = not good.
    Does said shitter have an air flow meter?
    Quote Originally Posted by theblacktexta View Post
    I've always had a thing for girls in wheelchairs. Dont need to spend $$ on exotic cocktails, - just need to apply the handbrake.
    8,785
    Quote Originally Posted by JohnMcSandyAxe View Post
    x2
    White = not good.
    I generally try to avoid looking under the bonnet, but fairly sure is afm.
    Dreamer millsi's Avatar
    Jul 2006
    Logan Bogan
    2,421
    Needs more fuel heater
    I had a 4gxx magna and it did the same thing but only at idle, never fixed it though the leads did like to come off the dizzy when under load sometimes.
    8,785
    solution fit 1uz & turbo?
    1,100
    Clean the air flow meter!@ Wd40 and a paint brush worked for mine but apparently there is a specialised AFM cleaning sprey available from supercheap that doesn't leave a residue.
    Might be lucky.
    Registered Fuckwit oioioioioi's Avatar
    Feb 2007
    Newcastle
    1,475
    Non residual electrical contact cleaner. Not WD40...
    Electrical shop or maybe Supercunts.
    8,785
    hotwire type i assume you are referring to?
    Forum Adnimistrator
    Feb 2005
    6,075
    Brock Polarisor will get it running smooth
    5,557
    It's a magna and you work in insurance. Burn it and laugh all the way to the dealers to buy a less shit car.
    Here's a novel idea. Go fuck yourself
    Need plumbing for new construction, shop fitting or commercial maintainence?
    Call Plumbing Perfection on 1800 088 699
    8,785
    Years of poor financial decisions see a Magna as a necessity rather than a choice
    Kangaroo flat!
    6,418
    Dont say that dude. Magnas are never a necessity!
    Forum Adnimistrator
    Feb 2005
    6,075
    Quote Originally Posted by Shifty View Post
    This is incorrect.
    I just sold a one owner reliable registered serviced subaru liberty in great nic with great interior and faded paint for $400.
    Mshitsubishi can die in a fire.
    go home helicopter, you're drunk.
    4,676
    Trying to read the plugs is futile when it is misfiring.
    Try swapping leads, clean the wire in the afm (not with wd 40 for fuck's sakes, use contact cleaner or acetone or something), wiggle all the plugs around.
