Page 1 of 6 12345 ... LastLast
Results 1 to 30 of 157
Thread: Cordless rattle guns and drills that aren't shit?
    1,868
    So thanks to the amount of time I spend on the internet I am turning into more of a lazy ADD child with every passing day. Since I can't be fucked cracking my own wheel nuts anymore i've started looking around for a decent little cordless rattle gun to make changing wheels a little easier now that I am swapping to semi slicks at track days. Currently I am just using a breaker bar and cordless drill with a socket attachment to crack and get the nuts off a bit quicker but I want to fuck off the breaker bar and do things faster with just the gun and torque wrench to tighten.
    If a cordless drill could crack the nuts itself then that would be perfect but I don't know if there are any out there that can do it. So a rattle gun might be necessary but I don't want to spend huge money on something I only have for one purpose. I would be more open to the idea of spending big on a cordless drill tho cause I kinda want a better one anyway.
    tl:dr
    1. Has anyone got a cordless drill (w/chuck & clutch) that can crack wheel nuts?
    Or
    2. Can anyone recommend an inexpensive cordless rattle gun that will do the job? Supercheap have a 12V corded one that was priced about right and that might end up being the best option but i'd like to look around a little more and see what battery powered ones can be got for first.
    Suspended
    mebourne
    3,939
    Don't trust the rated torque of impact wrenches. My first impact was a ryobi 1/2 inch drive and it was rated at 250nm. Total crap could not even undo a wheel nut.
    1,868
    Duly noted, that's the kind of stuff I want to know about. The ones I were looking at today had those figures written down (Bosch one said 340Nm from memory) but i'd like to hear from people that have used them. Stuff like that Ozito shit you can buy at bunnings I wouldn't touch but there are a couple of budget brands out there that will probably do what I need just fine, I don't need a tradies setup but I do want something that will last more than 1 use.
    Jul 2009
    Inner Westside/Sydney
    1,239
    If a drill could crack them without an impact mechanism you wouldn't be steering the car for a while afterwards.
    Probably doesn't help you much due to cost, but I know the snap-on ones go for years in a workshop environment, you might find you can pick one up second-hand from someone who is looking at a different career direction or a workshop being liquidated.
    Opposed to the PFAD Bill
    Feb 2005
    9,420
    Ryobi was your problem.
    I've sheared off a wheel stud with my makita 450.
    1,153
    When I change wheels at the track, after the car is jacked up, I just use a cheap ass cordless drill with an adapter to fit whatever the wheel nut size is. Usually 19mm or 21mm for me.
    Before I jack the car up, I just loosen the wheel nuts with a strong socket.
    Then tighten with the socket again quickly when on the ground.
    Registered User FIVETEN's Avatar
    206
    Makita! the 18v ltx range! They are the business!
    1,868
    Quote Originally Posted by nelsonian101 View Post
    That's exactly what I am doing at the moment. I just want to cut out one of those steps to make things a little easier.
    1,153
    Sorry, didn't read the first post fully.
    What I do is only change the rears (which are illegal grooved slicks) at the track becasue I am lazy. For the trip to the circuit, I put road legal semi's on the day before when I change my front brake pads and camber adjustments etc.
    17,797
    I've got 2 snap on ones... They are about the only good tool snap on makes,
    Malakia Industries
    Κάλυμνος
    2,292
    True that. Ive had my 1/2" Snap On electric gun for about 4 years now and it gets used all day 5 days a week. Its more or less fucked now. Been dropped and kicked thousands of times but still does its job. Ill probably just send it in for a service/whatever they do and a couple fresh batteries and it'll go another few years.
    #sydneydents Blow's Avatar
    Apr 2007
    Somewhere in Straya
    3,960
    How long do the batteries last before they need charging with the strap on ones? I have a smallish snap on cordless drill and battery life is shithouse between charges.
    1,868
    A 300Nm cordless power drill with switchable impact function, keyless chuck and variable clutch. Who makes them? Am I dreamin`?
    12,368
    Makita entry level; 230nm li ion.
    http://www.makita.com.au/products/lx...wrench?Prodid=
    Makita Pro; 440nm
    http://www.makita.com.au/products/po...nch?Prodid=120
    Bosch entry level; 180Nm but tiny.
    http://www.bosch-pt.com.au/papocs-au...1253/index.htm
    Bosch Pro 650Nm;
    Cordless 18v Li Ion HT GDS18V-LIHTSkin Only
    http://www.bosch-pt.com.au/papocs-au...5596/index.htm
    We sell this one to semi trailer workshops. They still generally have to crack the nuts with a huge bar but the big 3/4 drive pneumatics barely looseen them anyway and these cordless tools are tough as nails and you don't have to drag air lines around.
    Email me on our website for a deal of the century on any of these tools;
    http://cdaets.com.au/Bosch-Power-Tools
    http://cdaets.com.au/Makita-Power-Tools
    http://cdaets.com.au/index.php?route...mation/contact
    Mention pf.
    12,368
    The new bosch and makita li-ion batteries last longer than it takes to charge the other battery so it's kind of a moot point.
    If you haven't used one yet have a go. You'll be genuinely shocked at how hard they go and for how long.
    Suspended
    mebourne
    3,939
    That's why I have a makita btw450 now as well, proven from users it's a tough brother.
    But today was the first time the 450 failed me, balancer bolt must be tight as it did everything previously with ease.
    Suspended
    mebourne
    3,939
    Yeah I'm surprised how long the makita batteries last as well!
    Malakia Industries
    Κάλυμνος
    2,292
    Quote Originally Posted by Sucker View Post
    I have a small 3/8" SnapOn impact gun and its rubbish, battery lasts half a day. But my 1/2" used to last me 2 full days of proper use, its 4 years old now and I probably get 1 day out of it but its down on power too.
    australia
    1,404
    I have a Chicago pneumatic one and it is pretty good but pricey.
    The guys in the shop with snap on ones grab mine when theirs arent strong enough.
    I would probably get a makita one of ebay if i had to get another.
    Old Pac
    6,752
    Have been using this one for ages for doing wheel nuts, works a treat and is ~$100 http://www.4wdworld.com.au/Handy-12v-Impact-Wrench.html
    Use a torque wrench to tighten them the last bit though of course.
    1,868
    Local Supercheap Auto is selling this for $49.99, but i've got a feeling it's junk. All of the boxes on their shelf have been opened and re-packed. Suggesting they've all been returned. Specs on it are good but I'm not gonna buy something if it's not going to do the job.
    http://www.supercheapauto.com.au/onl...pc#Description
    Registered User ar3nbe's Avatar
    Mar 2008
    440
    Looking at the pic I think its the style were it "charges up" and then does one large impact to take the nut off. From experience it does 3-4 of these charges to take the nut off.
    I bought something similar years ago and it was ok but slow. I did end up killing it.
    no one ever, is to blame Howard Jones's Avatar
    Jul 2005
    2,525
    i had 2 expensive ass de-walts
    one broke, one worked forever
    go with bigmuz's advice as hes in the trade
    Smrt.. Kyle's Avatar
    Apr 2004
    nsw
    5,874
    Do it once, do it right, buy the makita btw450. You'll never complain again
    723
    There is a group buy on Aus300zx going at the moment on the Hitachi WR18DL Cordless 1/2-inch Square-Drive Impact Wrench, anyone got one? Any good?
    1,868
    Link to the group buy? Cost??
    1,868
    Quote Originally Posted by ar3nbe View Post
    Yea ok so that looks good for the price but perhaps a little too slow for my liking. I want something that can crack and whip a wheel nut off in a couple of seconds.
    723
    Quote Originally Posted by Reedy View Post
    http://www.aus300zx.com/forum/showthread.php?t=317373
    2-5 = $335ea
    6-10 = $320ea
    11-20 = $305ea
    21+ = $290ea
    Package includes:
    18v Rattle gun
    18v Battery
    Charger
    Without a case or add $15 if you want the hard case.
    And extra batteries are:
    2-5 = $105ea
    6-10 = $100ea
    11-20 = $95ea
    21+ = $90ea
    Delievered to Perth + shipping east coast which say $15 per person to each major city, but ideally bulk shipping to 1 person would save coin.
    Toowoomba
    1,855
    Quality bit of kit these. I know a number of people that use them and no complaints/issues. They can often be had for nothing with magazine subscriptions to various 4wd mags.
    1,868
    Here's a good video of one of those 12V plug in ones in use. That thing is slower than using a wheel brace.
    Also, LOL at the background music in this video. WTF.
