Results 1 to 21 of 21
Thread: ebay spot welder
    Jul 2007
    western nsw
    986
    ebay spot welder
    so i bought one of these. http://www.ebay.com.au/itm/BRAND-NEW...item2ebd318fd2
    anyone used one before ? i'm about to do a heap of spot welds on a smelly old falcon.
    I didn't choose the thug life.
    Brobdingnagian Member Passion-Fingers's Avatar
    Darwin, NT
    1,695
    hm no, but ill be very interested to see how it works for you!
    edit: nevermind read add properly and answered my own question..
    '06 Mitsu Pajero DiD - Daily and Boat tow rig
    HQ SS - rollin' on 14's
    Darwin, NT
    1,695
    You tried this thing out yet? The pics of the spot welds on the ebay add look good, im keen to see how it translates in reality.
    Jul 2007
    western nsw
    986
    not yet. i'm having a crack at some scrap soon. i'll put up pics when it happens.
    The letter g Sucker's Avatar
    Apr 2007
    Somewhere in Straya
    3,276
    Doesn't look to promising. Hope it works though.
    Rides-
    1984 toyota coaster bus
    2009 mitsubishi evo x mr
    wtd-
    vr,vs or vu ute. The cheaper the better, pm me.
    4,669
    Wow.
    Have you seen what an actual spot welder looks like?
    Jul 2007
    western nsw
    986
    Wow.
    i used one in high school. i don't know how well it'll weld, but for the price i'll give it a go.
    4,669
    It normally takes quite an incredible amount of pressure to hold the panels together to get them to weld.
    I am interested to see how it goes- might make me look like a dick I guess.
    blinks ... Billzilla's Avatar
    Jan 1970
    21,318
    The only one I've ever used was back in high school and it had two huge arms that clamped down on the sheets, just like you say, to hold them together to pass a heap of current through.
    It didn't look anything like the one in that ebay advert.
    Contact me for -
    3D printing in ABS plastic.
    http://www.billzilla.org
    Scaramouch seedyrom's Avatar
    2115
    1,068
    I cant see how a weld with an electrode from one side will do that.
    Unless it makes an absolute meal of the unseen side
    Apr 2007
    Somewhere in Straya
    3,276
    We have a few "single" sided ones at work, like $10k plus ones. Basically you attach a earth clamp to the job and push the gun onto the panel and pull the trigger.... But they are a lot more powerful then the one pictured and only used where you can't get behind the work area to use the clamp/double sided ones. I don't have much confidence in the ones we have at work and would rather mig the area and only use it to give the original "look".
    Rides-
    wtd-
    Jul 2007
    western nsw
    986
    i bought a heap of vise grip c clamps to pull it all together. i'm not sure about how strong or good the spot welds will be either. i'm certainly well positioned to find out ! sucker, how good is just drilling holes in the top piece then migging them together ? does it make it harder to get apart again ?
    as for you looking like a dick muz, you do a good enough job all by yourself.
    Jul 2007
    western nsw
    986
    i had a bit of a go at this. the steel i used was galvanised which made it gay. the plan is to cut up an old panel, clean it up and try it on that. what is a good test for spot weld strength ? as long as it can't be pulled apart easily it's ok ?
    Feb 2009
    town & country-adelaide SA
    2,536
    Try to separate the 2 sheets with a cold chisel/BFH...weld should tear through the top sheet if its welded with good penetration.
    RIP ROOKIE IPRASA #33
    2 June 2012
    Sydney rAmR0d'
    3,325
    Yer MIG plug weld would probably be stronger, just doesn't look original, but I doubt this things spot welds would look too original either?
    as short as possible
    Retired Finger Painter Karnage's Avatar
    Feb 2009
    Northside Brisbane
    723
    Quote Originally Posted by seedyrom View Post
    The internals are spot welded to the inner door frame before the outer skin is attached.
    2010 State Colouring in Champion
    Jul 2007
    western nsw
    986
    did a bit with this today. cleaned up a couple of pieces of ae82 bootlid. clamped them together and went to town. first few were shit. didn't stick at all. here is some pics of some better ones.
    top side
    bottom side
    top of bottom piece after separating.
    bottom of top piece.
    it took some hammer and cold chisel action to get them apart. not as much as i would have liked though. i'll give it another go and if it's still gay i'll just plug weld with the mig.
    Apr 2007
    Somewhere in Straya
    3,276
    Got hotter then i thought it would. Looks like it is melting the top material and pushing it out of the way, resulting in only a thin bit joined to the lower piece.
    Rides-
    wtd-
    Jul 2007
    western nsw
    986
    i reckon that is tied up with what muz was talking about. i'm not able to get the pressure needed to press the metal together properly. it seems to work ok for what it is. i've literally done about 15 spot welds with it. higher amperage and moving quicker seems to work best. another thing is i have an inverter welder. i might try out an ac one and see if it's better. for the radiator support and skirt on the falcon i reckon i'll plug weld with the mig.
    Darwin, NT
    1,695
    What about somehow integrating gas shielding aswell? Welds look ' dirty' like a gasless mig.
