Results 1 to 20 of 20
Thread: shit flange + belt sander = profit
    Registered User Gruelius's Avatar
    Apr 2011
    1,399
    tl;dr
    got shitty ebay tubular manifold for ~$150.
    Cut single flange bank into two 3's one shifted a few mm soon as i finished cutting it.
    Flange surface looks like pizza face teenager.
    instant gasket + gaskets to head does not stop le exhaust leak.
    Belt sander to each flange to flatten surface might help, no shops will want to mill it apparantly as it would be a proper cunt to set up.
    if i fuck it up ive got a simpler stock cast manifold turbo adapter id like to try.
    here is a pic of manifold before being cut in two, the surface on mine is worse
    Old e30: m20b23 T3/T4 turbo MS2E 3.73LSD
    New e30: m40b18 single pegger
    Jun 2006
    Ararat
    2,926
    piece of cake on a surface grinder
    Sydney rAmR0d'
    3,339
    Flat bastard
    as short as possible
    Digging shit out of the ground state.
    5,550
    Get some tanged graphite laminated gasket material, google Garlock 3125SS that's the shit you want.
    Sent from my iCoyote using Road Runner
    'The trouble with quotes on the Internet, is that Bam bam bambbbbbb bahhhhhhhhhhhhhhhahhhahhh'
    -Jean Claude Van Damme
    Apr 2011
    1,399
    you know anyone my way that might give it a go for beer money?
    WTFaaark ChrisS's Avatar
    ACT, Australia
    3,700
    How much is it out?
    I wouldn't respect her restraining order
    1934 Reo Hot Rod build
    1975 TX Gemini track car (EX RRS Rally car)
    1932 Ford (Unfinished, on hold)
    MY93 Subaru Legacy Wagon GT Twin Turbo
    Visit RacingReady.com.au for information on upcoming motorsport events and show!
    FJ20DEBT NISMOgemini's Avatar
    Brisbane, QLD °° AKA: Gene FJ20DET °°
    3,787
    why did u cut it?
    May 2010
    I joined long before PF was famous in 2002.
    400
    surface grinder is abit of an overkill,wack it on a mill and take a cut.
    Apr 2011
    1,399
    Quote Originally Posted by NISMOgemini View Post
    why did u cut it?
    was told its the good thing to do with shittily constructed manifolds as it will crack if not done.
    the two flanges are on slight seperate angles so they would need to be milled seperately. if i get a flat flange surface the gaskets will make up for the difference, the banks move when bolted down,will know when i see where the leak is on the head/manifold for sure.
    migtht just try find some old school shop to do it. otherwise ill just go cast iron setup.
    Tastes like victory EVOSTi's Avatar
    Copenhagen
    2,180
    I've used one of those bench belt sanders, worked mint.
    Apr 2011
    1,399
    and yeah before the abuse for buying cheap shit begins, i got t he manfiold, turbo, intercooler, box of piping, box of couplers + hoseclamps and a boost controller for $400 lol
    Quote Originally Posted by EVOSTi View Post
    yeah seems the go, will just touch it up, getting it milled means paying for someone to rig it up, apparantly its a proper cunt to do.
    Liiive action! Mr Jones's Avatar
    Opium den
    1,977
    I would have thought it would pull up with the bolts if it's only a few mm. I would just smooth the surface with something like a belt sander so the gaskets have a good surface to seal on but not try to get them level.
    Have you checked that your bolts/studs aren't bottoming out before the manifold pulls up to the head?
    Other way to the tweak out of the manifold might be to bolt it to a head then heat it in a few strategic locations red hot then let it cool slowly before unbolting
    Hold it flat cunt
    Apr 2011
    1,399
    yeah i think one of the nuts wasnt properly tightened so it may have warped and lifted that area too but ill see how i go. will be ovbious when it ake the manifold off, will hopefully see a black stoot line where its failing to seal
    oh yeah flange is about 1.25cm thick at least... pretty beefy.
    Newcastle Knights in 2013 Nathan Tinkler's Avatar
    4,816
    Mirage manifold.
    They really thought that name through.
    "If you get a boost in power it's a Mirage"
    Copenhagen
    2,180
    Quote Originally Posted by Mrs Jones View Post
    You would think so, but after my turbo manifold blew a few gaskets I put a straight edge on it, barely out 1mm and it's only a 4cyl. Machined it and it was fine for quite some time, until it warped again
    Apr 2011
    1,399
    may be binning that for this
    I am getting .4bar of boost creep in 3rd with internal WG. its a worry because i plan to run about 1 bar and the sensor runs out of measure at 1.4~ bar so its important i dont go past that as itd run waaay lean.
    Could it be that i am too retarded (running 16-14 degree at high rpm 180-210kpa).
    Also forgive these dynoryder IQ level threads, i really know fuck all about cars but i am trying to learn quick lol.
    1,316
    Quote Originally Posted by Gruelius View Post
    tl;dr
    Bolt the cunt to an old head, or the head, and heat the tubes close to the flange to red. This is a known fix.
    Milling them is almost impossible- a big belt sander, probably found in a wood workers workshop, is how a lot of this stuff was surfaced OE.
    Registered User EDMONTY's Avatar
    Jun 2004
    penrith
    366
    ive done mine about 4 times on a big belt sander at the local exhaust shop cost me about $80 ,as mine keeps warping cheap piece of shit
    EL GHIA
    GT3582R
    WOLF3D
    5,550
    MAKE SOME DECENT BLOODY GASKETS like what I suggested above!!
    http://www.garlock.com/products/?product=163
    That is a Garlock sheet on the bottom and the shit house Clevo exhaust gaskets that come from Felpro on top.
    1,316
    Hmm. Decent exhaust gaskets are often multi layer stainless steel shim type now.
