I'm slowly getting together the parts I need for the fuel system to fit EFI to my Camaro. I was thinking of using a Ryco Z373 filter ( found on EB-AU Falcons) because it's pretty cheap, a nice size, and it can take M14 x 1.5 fittings. Can anyone see any issues with this?
I also need to work out how to mount the filter as I didn't want to have it supported just by the aluminium hard line that I will be using. The filter body is 55 mm in diameter. Is there a bracket in the Falcons that holds the filter in place that I might be able to get from a wrecker? If not then does anyone have any bright ideas on nice way to mount the filter?
