Results 1 to 6 of 6
Thread: Current draw of Toyota integral ignitor coils
    8,413
    Picked up some new coils for the race car, and wanting to wire them in to a single DT plug so that when i switch over to the new ECU it can be integrated into the loom nicely.
    However the spec sheets for the Deutsch DT connectors give a 13A maximum for each connector.
    Anyone know roughly what current draw the ignitors take, so i can figure out whether i want to use 1 or 2 of the pins for power on a 6pin connector.
    Or should i just use a separate DTP connector for the power?
    I cant get no sleep...
    AE86 race car thread is finally up to date | Supposedly i have a new daily project too
    207
    I think you should be right. In a ZZE123 all four coils run from the 15A IG2 fuse. I'm sure there's other electronics that run off IG2 in that chassis also.
    Sidetracked BMWTurbo's Avatar
    Aug 2004
    3,051
    Ignitors don't draw much power, they switch EARTH to the coils, so the +12 is supplied from the power feed to the coils via a seperate circuit.
    8,413
    These are all in one though, so ignitor and coil powered from the same source.
    Four from the IG2, sounds good.
    8,413
    Aug 2004
    3,051
    Quote Originally Posted by takai View Post
    Ahh sorry, you are right, I didn't pick up on the 'integral' in the title.
